v3i only PWR key not working and auto power on. hi i have v3i water damaged , put battery , phone is auto power on. all keys are working , only PWR not working. problem is not in flex or lcd , i have tested the main board on a working v3i. any solution ? |
I have the same problem. Auto power on when put battery. Only PWR key not work. Any ideas? |
I have same problem here. The phone switches on itself once the battery is inserted. I tried to change the flex cable but still there is no changes. Can anyone help us please its urgent.:confused: |
i have same problem v3 power on when coneect battery every thing ok but not only work power button needs help |
first : change power ic |
:confused:hi I have the same problem. Auto power on when put battery. Only PWR key not work. Any ideas? |
BTW i have return this phone long time ago to the customer ..... problem solved by itself ;) he came back 2 weeks ago with blavk lcd problem , i have changed flex , and see old problem have been solved :) |
:rolleyes: change please keypad flex complet, or change lcd it will be ok |
Hi Fequently for this problem, check first the easier thing, so clean the two connexion beetween : 1: the board and the flex 2: the flex and the display 3: the display and the camera Sometimes there is some water over there. Post result, thanks. |
I had the same problem today and i resolv it by changing lcd. Thanks |
