Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Typhoon Dongle
Old 02-24-2008, 00:55   #1 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Nokia Tools v4.0I - full ASK/RPL cache, NPC/HWC/CCC/Variant CERT Extraction, etc
Hello,
Known issues:
RPL Write may not work through FBUS interface (USB recommended). Will be fixed in official release, as this is public-test only.
Changes:
Backup files is now written when IMEI is damaged (includes ????)
Added full support for ASK/RPL operations.
Cert restore is done clicking just one button (Restore Certificates).
To restore certificate you need activated account on our server with logs inside. Logs prices will be fixed upon official release.
First time you need just click "Restore Certificates". Software will contact our server and download RPL file.
Our software supports certificate request through few ways:
- USB cable (CA-53, DKU-2) via FBUS interface (phone switched on/in local mode)
- USB cable (CA-53, DKU-2) using flashmode BootROM (if phone can't switch on, or go to local mode - its dead)
- UFSx FBUS - if phone working ok
- UFSx FlashBUS - f phone can't switch on, or go to local mode - its dead
Our software supports RPL caching - that means if you will use your account to generate RPL file, it will be stored on server permamently. If you will lose your RPL file, you can re-download it any time you need. Same situation if someone already generated RPL for this PublicID - software will download RPL from server without any fees!
If no RPL file for given PublicID is avaiable on server, software will place ASK file for calculation in queue - all you need to do now is just trying to download RPL file clicking "Restore Certificates".
If your RPL will be finally calculated, software will download it, decrypt and will try to write to phone.
It can repair blocked keypad/fbus counter, damaged SP area (FFFF), SX4 authorization problems (superdongle key), repair DRM keys, repair CMLA keys, and recreate PM from scratch if phone will be damaged somehow.
Don't forget to use SX4 authorization and write good PM to correct calibration problems.
As long as we dont have built-in FlashBUS yet, its not possible to write NPC/HWC/CCC/VARIANT certificates. But we have solution. If our software during writing RPL file will found unsupported certificate - it will be extracted to binary format - so no more problems with repairing damaged IMEI for example (NPC cert) - in BIN format you can write it via HWK in example.
If there is some problems with writing RPL using our software, you can download it and save to HD and write by any Nokia software, even original (we using original NMP format). Just tick "Save RPL to file".
If you have already RPL file in NMP format, then tick "Restore using local RPL file" and point software to local RPL file - so you avoid server transaction.
Please test and post results & feedback,
note you need to unpack RAR to current Nokia Tool directory in order to work properly,
download from: http://www.karwossuite.pl/ks40i_test...D_rpl_test.rar
with best regards,
KarwosGSM.
The Following User Says Thank You to kaisak For This Useful Post:
Old 02-24-2008, 01:36   #2 (permalink)
communication_expert's Avatar
Member: 50511
Sonork: 100.109684
Thanks Meter: 307
thats nice good working keep going ..best of luck
Old 02-24-2008, 01:50   #3 (permalink)
Member: 612330
Thanks Meter: 35
First test
Nokia N70
=> Typhoon Server v9.3+SX4+CRT, (c) 2004-2008 KarwosGSM
-> Sending BB5 Certificates Restore Request... OK
-> ASK Successfully Queued for Calculation. Credits left on account: 0
-> Disconnecting from Typhoon Server... OK
Now waiting for RPL
Reading ASK...
ASK Read Success, Starting Server Transaction...
-> Connecting to Typhoon Server... OK
-> Server error: ASK already found in queue, wait for calculation
then post result
The Following User Says Thank You to Fock3 For This Useful Post:
Old 02-24-2008, 04:50   #4 (permalink)
Chennairam's Avatar
Member: 372320
Sonork: 100.113211
Thanks Meter: 2,661
Great Work karwos Team
Old 02-24-2008, 10:39   #5 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 188
whats the cost for the rpls then?
Old 02-24-2008, 14:03   #6 (permalink)
Member: 245626
Thanks Meter: 21
Possible to use this sevice with Multibox and how buying crédits.???
Tested but need account.
Old 02-24-2008, 14:50   #7 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
@all
prices will be fixed tomorrow
if any need test log can contact me through PM
both multi-box and typhoon are supported so all what is needed to activate/upgrade account is typhoon/multibox sn
Old 02-24-2008, 19:03   #8 (permalink)
AYMAN SHAMAYLH's Avatar
Member: 146798
Sonork: 100.1576177
Thanks Meter: 24
very good mr karwos
good update
more success
Old 02-25-2008, 07:10   #9 (permalink)
Member: 232607
Sonork: 100.1585040
Thanks Meter: 260
thanx
Old 02-25-2008, 10:40   #10 (permalink)
huzsolt's Avatar
Member: 75392
Sonork: 100.81199
Thanks Meter: 136
what time is needed for rpl calculation?
Old 02-26-2008, 17:23   #11 (permalink)
thechachman's Avatar
Member: 595947
Thanks Meter: 16
V nice addition ... well done
Old 02-26-2008, 17:25   #12 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
About timearound... from 5mins to 5 days!
But...
who knows,
maybe when our Tucson access will be granted, realtime calc will be added ?
who knows ops:
Old 02-27-2008, 03:23   #13 (permalink)
Member: 146798
Sonork: 100.1576177
Thanks Meter: 24
hope real time calculation
but after test really great add
waiting more typhoon team
Old 02-27-2008, 05:40   #14 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 366
Originally Posted by karwos View Post
@all
inform us the prices for rpl service.
br
Old 02-28-2008, 06:27   #15 (permalink)
Member: 146798
Sonork: 100.1576177
Thanks Meter: 24
What about prices for this service
any news
24-02-2008 Nokia Tools v4.0I - full ASK/RPL cache, NPC/HWC/CCC/Variant CERT! GSMtricks Multi-Box 13 03-07-2008 11:37
24-02-2008 Nokia Tools v4.0I - full ASK/RPL cache, NPC/HWC/CCC/Variant CERT! GSMtricks Multi-box LITE 3 02-24-2008 19:23
New Nokia Tools v4.0D Update, Full SX4 Authorization added karwos Multi-Box 33 02-03-2008 08:26
I'm looking for Nokia 3310 v4.18 full flash file. kevin03 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-27-2001 02:03
Need Nokia 3210 v4.41 full flash with Russian lng ***DIMER*** Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-14-2001 05:50
Page generated in 0.30740 seconds with 9 queries
