3230 Phone Start up Fail Repaired By Typhoon 3230 Phone Start up Fail Contact Retailer Repaired By Typhoon I try to Other Box Still No luck After i used Thphoon By User Fomrat area Phone It will Be ok Here The Log :- http://i123.photobucket.com/albums/o...tByTyphoon.jpg Thanks karwos Br., Ram |
Run the diagnostics, and see what test(s) fail, maybe you broke some pm field , and you need to rewrite it. It can be done with sx4 auth. |
I chage To Customer For my work I am Happy now Br, Ram |
Ah, I missunderstood you, I thought you did "startup failed" with Karwos Suite while formatting ;) |
well nice missunderstanding :D |
but screen shot showing nhl10 modle attached :confused: |
did you try to format manualy phone * + 3 + call + power on this will solve the problem.... |
I did for 3230 "startup failed" FORMAT USER AREA in UFS after UI SETTING perfect working try if manual format not working |
just do format and after dont do full u i setting only simlock and reboot with normal mode do with any box |
