Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Typhoon Dongle
Old 12-21-2007, 07:09   #1 (permalink)
Chennairam's Avatar
Member: 372320
Sonork: 100.113211
Thanks Meter: 2,661
Thumbs up 3230 Phone Start up Fail Repaired By Typhoon
3230 Phone Start up Fail Contact Retailer Repaired By Typhoon
I try to Other Box Still No luck
After i used Thphoon By User Fomrat area
Phone It will Be ok
Here The Log :-
Thanks karwos
Br.,
Ram
Old 12-21-2007, 07:40   #2 (permalink)
huzsolt's Avatar
Member: 75392
Sonork: 100.81199
Thanks Meter: 136
Run the diagnostics, and see what test(s) fail, maybe you broke some pm field , and you need to rewrite it. It can be done with sx4 auth.
Old 12-21-2007, 08:02   #3 (permalink)
Chennairam's Avatar
Member: 372320
Sonork: 100.113211
Thanks Meter: 2,661
After Format user area phone Will Be ok
I chage To Customer For my work
I am Happy now
Br,
Ram
Old 12-21-2007, 08:26   #4 (permalink)
huzsolt's Avatar
Member: 75392
Sonork: 100.81199
Thanks Meter: 136
Ah, I missunderstood you, I thought you did "startup failed" with Karwos Suite while formatting
Old 12-21-2007, 08:39   #5 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
well nice missunderstanding
Old 01-03-2008, 00:22   #6 (permalink)
Member: 281925
Sonork: 100.113915
Thanks Meter: 63
but screen shot showing nhl10 modle attached
Old 01-03-2008, 00:33   #7 (permalink)
usi_golden's Avatar
Member: 506993
Sonork: 100.1580692
Thanks Meter: 1,003
did you try to format manualy phone
* + 3 + call + power on
this will solve the problem....
Old 08-28-2011, 10:36   #8 (permalink)
praji's Avatar
Member: 563648
Sonork: 100.1594523
Thanks Meter: 87
I did for 3230 "startup failed"
FORMAT USER AREA in UFS after UI SETTING
perfect working
try if manual format not working
Old 08-28-2011, 16:23   #9 (permalink)
matcom gsm's Avatar
Member: 106346
Sonork: 100.1577684
Thanks Meter: 1,061
just do format and after dont do full u i setting only simlock and reboot with normal mode do with any box
nokia 3230 phone start-up failed help me palav Nokia Hardware & Hardware Repair 10 08-28-2011 10:34
can mx key repair n73 phone start up failed rockindheeraj MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 01-21-2010 18:47
N85 After Repair SuperDongle Phone Start Up Failed WinD_VteC Universalbox 4 12-04-2009 15:11
n78 phone start up failed how to repair .:M@ster:. Nokia Base Band 5 ( BB-5 ) 0 05-25-2009 22:16
as repair nokia 5800 rm 356 that ignite said: phone start-up failed. cristhian garci Universalbox 4 04-04-2009 05:46
Page generated in 0.18635 seconds with 9 queries
