3250 pb sx4 auth Product RM-38 MCU Version V 04.60 MCU Compilation Date 14-09-07 Product Manufacturer (c) Nokia. Phone is in: Test mode Local mode set OTP IMEI 357934002298692 SECURITY CODE 12345 SEC. CODE BAD ATTEMPTS 0 HWID 1803 PRODUCT CODE 0526397 BASIC PRODUCT CODE 0516114 PRODUCTION S/N MUI118266 MODULE CODE 0202410 BATTERY 100% RETU 32 TAHVO 52 SIMLOCK Server SIMLOCK SERVER VERSION 62 SIMLOCK Network 244070 SIMLOCK Active No SIMLOCK Key Count 0 SIMLOCK FBUS Count 0 SIMLOCK Stat 0000000000000000 Attached OK, Operation took 8 seconds Executing Post-attach procedures ================================================== =============== 1. LCD Pattern settings not found, setting Defaults 2. Found product ADC Channels settings 3. Auto-RPL Backup Backing up Certificate... OTP IMEI: 357934002298692 Entries to read: 10 RPL Read OK 357934002298692_Certificate_115943.pm Written OK! ================================================== =============== Post-attach procedures done Setting Full Factory Defaults Local mode set Factory defaults Set OK, Time 2 seconds Phone is in: Local mode Checking authorization status... Not authorized Receiving phone challenge... OK -> Connecting to Typhoon Server... => Typhoon Server v9.0+SX4, (c) 2004-2007 KarwosGSM -> Sending SX4 Request... OK -> Received SX4 Response OK Sending SX4 challenge to phone... OK -> Sending SX4 Secondary Request... OK -> Server error: Card failure, please try in few seconds again -> Connection closed SX4 Authorization aborted! Phone is in: Local mode Checking authorization status... Not authorized Receiving phone challenge... OK -> Connecting to Typhoon Server... => Typhoon Server v9.0+SX4, (c) 2004-2007 KarwosGSM -> Sending SX4 Request... OK -> Received SX4 Response OK Sending SX4 challenge to phone... OK -> Sending SX4 Secondary Request... OK -> Received SX4 Secondary Response OK -> Server transaction finished, connection closed Sending Secondary SX4 challenge to phone... OK Checking authorization status... Authorized, SUCCESS! Now you can write full PM! Keys in total to write: 196 Phone is in: Local mode Protecting: RSSI Field 1, Key 0, Length 114 bytes Written Failed, Update not accepted Protecting: RSSI Field 1, Key 2, Length 86 bytes Written Failed, Update not accepted Protecting: RSSI Field 1, Key 4, Length 110 bytes Written Failed, Update not accepted Protecting: RSSI Field 1, Key 6, Length 86 bytes Written Failed, Update not accepted Protecting: RSSI Field 1, Key 8, Length 110 bytes Written Failed, Update not accepted Protecting: RSSI Field 1, Key 13, Length 98 bytes Written Failed, Update not accepted Protecting: RSSI Field 1, Key 16, Length 86 bytes Written Failed, Update not accepted Protecting: RSSI Field 1, Key 18, Length 86 bytes Written Failed, Update not accepted Protecting: RSSI Field 1, Key 20, Length 86 bytes Written Failed, Update not accepted Protecting: RSSI Field 1, Key 25, Length 4 bytes Written Failed, Update not accepted Protecting: RSSI Field 1, Key 29, Length 6 bytes Written Failed, Update not accepted Field 2, Key 0, Length 356 bytes Written OK Protecting: Production Data Field 4, Key 0, Length 1 bytes Written Failed, Update not accepted Protecting: Production Data Field 4, Key 1, Length 44 bytes Written Failed, Update not accepted Protecting: Production Data Field 4, Key 2, Length 44 bytes Written Failed, Update not accepted Protecting: Production Data Field 4, Key 3, Length 10 bytes Written Failed, Update not accepted Protecting: Production Data Field 4, Key 4, Length 8 bytes Written Failed, Update not accepted Protecting: Production Data Field 4, Key 5, Length 8 bytes Written Failed, Update not accepted Protecting: Production Data Field 4, Key 6, Length 8 bytes Written Failed, Update not accepted Protecting: Production Data Field 4, Key 9, Length 5 bytes Written Failed, Update not accepted Protecting: Production Data Field 4, Key 16, Length 4 bytes Written Failed, Update not accepted Field 8, Key 0, Length 12 bytes Written OK Field 8, Key 1, Length 12 bytes Written OK Field 8, Key 2, Length 0 bytes Written OK Field 8, Key 3, Length 0 bytes Written OK Field 8, Key 6, Length 4 bytes Written OK Field 8, Key 7, Length 8 bytes Written OK Field 11, Key 0, Length 4 bytes Written OK Field 11, Key 1, Length 4 bytes Written OK Field 11, Key 2, Length 4 bytes Written OK Field 11, Key 3, Length 4 bytes Written OK Field 11, Key 4, Length 1 bytes Written OK Field 11, Key 5, Length 6 bytes Written OK Field 11, Key 6, Length 1 bytes Written OK Field 11, Key 7, Length 2 bytes Written OK Field 11, Key 8, Length 2 bytes Written OK Field 11, Key 9, Length 2 bytes Written OK Field 11, Key 10, Length 2 bytes Written OK Field 11, Key 11, Length 2 bytes Written OK Field 11, Key 12, Length 1 bytes Written OK Field 11, Key 13, Length 1 bytes Written OK Field 11, Key 14, Length 1 bytes Written OK Field 11, Key 15, Length 1 bytes Written OK Field 11, Key 16, Length 1 bytes Written OK Field 11, Key 17, Length 1 bytes Written OK Field 11, Key 18, Length 1 bytes Written OK Field 11, Key 19, Length 2 bytes Written OK Field 11, Key 20, Length 2 bytes Written OK Field 11, Key 21, Length 1 bytes Written OK Field 11, Key 22, Length 1 bytes Written OK Field 11, Key 23, Length 4 bytes Written OK Field 11, Key 24, Length 4 bytes Written OK Field 11, Key 25, Length 2 bytes Written OK Field 11, Key 26, Length 2 bytes Written OK Field 11, Key 27, Length 2 bytes Written OK Field 11, Key 28, Length 2 bytes Written OK Field 11, Key 29, Length 1 bytes Written OK Field 11, Key 30, Length 1 bytes Written OK Field 11, Key 31, Length 1 bytes Written OK Field 11, Key 32, Length 1 bytes Written OK Field 11, Key 33, Length 1 bytes Written OK Field 11, Key 34, Length 1 bytes Written OK Field 11, Key 35, Length 1 bytes Written OK Field 11, Key 36, Length 1 bytes Written OK Field 11, Key 37, Length 1 bytes Written OK Field 11, Key 38, Length 2 bytes Written OK Field 11, Key 39, Length 2 bytes Written OK Field 11, Key 40, Length 2 bytes Written OK Field 11, Key 41, Length 2 bytes Written OK Field 11, Key 42, Length 2 bytes Written OK Field 11, Key 43, Length 4 bytes Written OK Field 11, Key 44, Length 4 bytes Written OK Field 11, Key 45, Length 4 bytes Written OK Field 11, Key 46, Length 1 bytes Written OK Field 11, Key 47, Length 16 bytes Written OK Field 11, Key 48, Length 2 bytes Written OK Field 11, Key 49, Length 2 bytes Written OK Field 11, Key 50, Length 20 bytes Written OK Field 11, Key 51, Length 10 bytes Written OK Field 11, Key 52, Length 2 bytes Written OK Field 11, Key 53, Length 20 bytes Written OK Field 11, Key 54, Length 10 bytes Written OK Field 11, Key 55, Length 1 bytes Written OK Field 11, Key 56, Length 1 bytes Written OK Field 11, Key 57, Length 1 bytes Written OK Field 11, Key 58, Length 1 bytes Written OK Field 11, Key 59, Length 1 bytes Written OK Field 11, Key 60, Length 1 bytes Written OK Field 11, Key 61, Length 1 bytes Written OK Field 11, Key 62, Length 1 bytes Written OK Field 11, Key 63, Length 1 bytes Written OK Field 11, Key 64, Length 1 bytes Written OK Field 11, Key 65, Length 1 bytes Written OK Field 11, Key 66, Length 32 bytes Written OK Field 11, Key 67, Length 32 bytes Written OK Field 11, Key 68, Length 2 bytes Written OK Field 11, Key 69, Length 2 bytes Written OK Field 11, Key 70, Length 2 bytes Written OK Field 11, Key 71, Length 2 bytes Written OK Field 11, Key 72, Length 2 bytes Written OK Field 11, Key 73, Length 2 bytes Written OK Field 11, Key 74, Length 2 bytes Written OK Field 11, Key 75, Length 2 bytes Written OK Field 11, Key 76, Length 2 bytes Written OK Field 11, Key 77, Length 2 bytes Written OK Field 11, Key 78, Length 2 bytes Written OK Field 11, Key 79, Length 2 bytes Written OK Field 11, Key 80, Length 2 bytes Written OK Field 11, Key 81, Length 2 bytes Written OK Field 11, Key 82, Length 2 bytes Written OK Field 11, Key 83, Length 2 bytes Written OK Field 11, Key 84, Length 2 bytes Written OK Field 11, Key 85, Length 2 bytes Written OK Field 11, Key 86, Length 2 bytes Written OK Field 11, Key 87, Length 2 bytes Written OK Field 11, Key 88, Length 2 bytes Written OK Field 11, Key 89, Length 2 bytes Written OK Field 11, Key 90, Length 2 bytes Written OK Field 11, Key 91, Length 2 bytes Written OK Field 11, Key 92, Length 2 bytes Written OK Field 11, Key 93, Length 2 bytes Written OK Field 11, Key 94, Length 2 bytes Written OK Field 11, Key 95, Length 2 bytes Written OK Field 11, Key 96, Length 2 bytes Written OK Field 11, Key 97, Length 2 bytes Written OK Field 11, Key 98, Length 2 bytes Written OK Field 11, Key 99, Length 2 bytes Written OK Field 11, Key 100, Length 2 bytes Written OK Field 11, Key 101, Length 2 bytes Written OK Field 11, Key 102, Length 2 bytes Written OK Field 11, Key 103, Length 2 bytes Written OK Field 11, Key 104, Length 2 bytes Written OK Field 11, Key 105, Length 2 bytes Written OK Field 11, Key 106, Length 2 bytes Written OK Field 11, Key 107, Length 2 bytes Written OK Field 11, Key 108, Length 2 bytes Written OK Field 11, Key 109, Length 2 bytes Written OK Field 11, Key 110, Length 2 bytes Written OK Field 11, Key 111, Length 2 bytes Written OK Field 11, Key 112, Length 2 bytes Written OK Field 11, Key 113, Length 4 bytes Written OK Field 11, Key 114, Length 4 bytes Written OK Field 11, Key 115, Length 1 bytes Written OK Field 11, Key 116, Length 4 bytes Written OK Field 11, Key 117, Length 4 bytes Written OK Field 11, Key 118, Length 4 bytes Written OK Field 11, Key 119, Length 4 bytes Written OK Field 11, Key 120, Length 16 bytes Written OK Field 11, Key 121, Length 4 bytes Written OK Field 11, Key 122, Length 2 bytes Written OK Field 11, Key 123, Length 2 bytes Written OK Field 11, Key 124, Length 1500 bytes Written OK Field 12, Key 0, Length 102 bytes Written OK Field 44, Key 0, Length 1 bytes Written OK Field 50, Key 0, Length 2 bytes Written OK Field 54, Key 0, Length 2 bytes Written OK Field 88, Key 0, Length 36 bytes Written OK Field 92, Key 0, Length 11 bytes Written OK Field 96, Key 0, Length 24 bytes Written OK Field 107, Key 0, Length 21 bytes Written OK Field 107, Key 1, Length 79 bytes Written OK Field 107, Key 2, Length 79 bytes Written OK Field 107, Key 3, Length 70 bytes Written OK Field 107, Key 25, Length 132 bytes Written OK Field 117, Key 0, Length 4 bytes Written OK Field 117, Key 1, Length 3 bytes Written OK Field 117, Key 2, Length 6 bytes Written OK Field 117, Key 3, Length 1 bytes Written OK Field 117, Key 5, Length 10 bytes Written OK Field 117, Key 6, Length 8 bytes Written OK Field 117, Key 13, Length 3 bytes Written OK Field 117, Key 14, Length 3 bytes Written OK Field 117, Key 19, Length 40 bytes Written OK Field 193, Key 2, Length 8 bytes Written OK Field 193, Key 3, Length 32 bytes Written OK Field 193, Key 4, Length 32 bytes Written OK Field 193, Key 9, Length 64 bytes Written OK Protecting: SP Area (BB5) Field 308, Key 0, Length 1 bytes Written Failed, Update not accepted Protecting: SP Area (BB5) Field 308, Key 1, Length 8192 bytes Written Failed, Update not accepted Protecting: SP Area (BB5) Field 308, Key 3, Length 1 bytes Written Failed, Update not accepted Protecting: SP Area (BB5) Field 308, Key 4, Length 1 bytes Written Failed, Update not accepted Protecting: SP Area (BB5) Field 308, Key 5, Length 10 bytes Written Failed, Update not accepted Protecting: SP Area (BB5) Field 308, Key 6, Length 1 bytes Written Failed, Update not accepted Protecting: SP Area (BB5) Field 308, Key 7, Length 1 bytes Written Failed, Update not accepted Protecting: SP Area (BB5) Field 308, Key 8, Length 1 bytes Written Failed, Update not accepted Protecting: SP Area (BB5) Field 308, Key 9, Length 40 bytes Written Failed, Update not accepted Field 309, Key 0, Length 4 bytes Written OK Field 309, Key 1, Length 2 bytes Written OK Field 309, Key 2, Length 12 bytes Written OK Field 309, Key 4, Length 12 bytes Written OK Field 309, Key 5, Length 12 bytes Written OK Field 309, Key 7, Length 12 bytes Written OK Field 309, Key 8, Length 12 bytes Written OK Field 309, Key 17, Length 12 bytes Written OK Field 322, Key 0, Length 1 bytes Written OK Field 334, Key 0, Length 1 bytes Written OK PM Write Done, Operation took 18 seconds Total keys: 196 Written keys: 167 Keys not accepted to update [Skipped]: 29 [29] always failed to write network field 1 and 309 plz any solution to repair this pb?? |
Phone is authorized OK but you forgot to UNTICK "Protect Sec" :D |
