10-09-2006, 21:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | ..:: KarwosSuite v3.0L Released ::.. We are proud to release a next version of KarwosSuite 3 DCT4/WD2 Service Tool for UFSx, also called Nokia DCT4/WD2 Service Tool for Multi-Box !!! Don't forget to uninstall previous version before installing this one !!! Release highlights 1. Added new fully supported phones: 6230i, 8910i, 1600, 6070, 3220 2. Added "Linear Step" function to Audio Tests, for testing spectrum of Your Buzzer/Earpiece 3. Added "Protect Sec" checkbox for Protecting Security Field (FLASH IMEI, WARRANTY IMEI, SP LOCK, etc) while PM Operations (erase/write) 4. Added "Erase PM" Function for erasing PM blocks 5. Corrected many bugs, for example with Rebuilding Warranty Menu on ASIC6 Phones (Ref: http:///vbb/showthread.php?t=338877) and ASIC2 also. To rebuild ASIC6 Warranty menu you must tick Checkbox "ASIC6 Fix" (Automatically Ticking when ASIC6 is detected) 6. Added solution to Read/Write counter of Bad Attempts of Security Code. I guess you caused a situation, when Security Code in phone is 12345 (as KS3 saids), but phone wasn't accepting that! That was reason of 5-bad entries of Security Code. After 5 bad attempts its going to self-lock. This version of KS3 is able to read value of this counter, and reset it if needed. Helpfull, isn't it? 7. Included into installer: FIA TOOL v1.0A, this is used for Reading/Parsing Nokia Flashfiles and UPP/FLASH Loaders. You can also Activate FTD Netmonitor on ASIC2,5,6,7 flashes, Skip Authenthication on Modified flashes, or Correct MCUSW CRC problem on 6610i-7250i units. 8. Included into installer: SLDGEN v1.0a, this is used for generating SLD simlock definitions (for UFSx ) for relocking phone. 9. UFSx INI Generator updated to v1.1, to support newer BB5 phones. Full changelog - Corrected FBUS Frames handling - Added new FULLY supported phones: 6230i, 8910i, 1600, 6070, 3220 - Factory Defaults for some phones (Especially ASIC6) fixed - Fixed Writing of PM, for Fields/Keys larger than 0xFF (255), especially for newer / BB5 phones - Fixed keyboard tests labels on some phones (Clear key != Right navikey) - DelZip.dll problem fixed - Increased default PM-Readout/Erase offset to 512 - Rewritted Reading/Writing PM routine to smoothly changing a StatusBar - Erase PM Function added, use with caution - Calculated Unlock codes are 3 digits separated, to be more clear - Added "Linear Step" into Audio Tests menu, you can test a spectrum of your Buzzer/Earpiece - Fixed few bugs with PM Rebuild Function, added Lifetimer Reset and Writing Security Code after Rebuild process - Added Hints on many Checkboxes/Buttons - Added "Protect Sec" option to Protect Security Fields, while Writing/Erasing PM (includes RSSI, Production Data, Warranty Data, Warranty IMEI, MCUSW CRC, Flash IMEI Data1 Record, DCT4/BB5 Simlock Data) - GUI Rebuilt - Added option "Rst Attempts Cnt", this is used while Writing Security Code, to reset bad Security Code Attempts. Nokia phone is being locked, after 5 bad Security Code attempts, and then it not acceptes even good Security Code. - "Security Code Bad Counter" is readed while attaching phone - Finally corrected problems with writing "Made Date", Purchase Date and Repair date on ASIC 6 units (6230,6230i) - ASIC 6 units are automatically detected and "Asic6 Fix" checkbox is automatically ticked - Fixed while changing Production Date == Purchase Date - Added Typhoon Key Maintenance Tool v1.0b to support TYPHOON2 REV Keys and more Activation Slots - UFSx INI Generator updated to v1.1, newer phones supported: * BB5 N71 [RM-67] * BB5 N71 [RM-112] * BB5 6136 [RM-86] * BB5 5500d [RM-87] * BB5 5500 [RM-106] * BB5 6233 [RM-123] * BB5 N73 [RM-132] * BB5 N73 [RM-133] * BB5 6234 [RM-145] * BB5 6136b [RM-199] * BB5 6151 [RM-200] - Included into Installer KarwosSuite 3 SLD Generator, for making SLD definition files for DCT4 ASICS: 2,5,6,7 Relocking - Included into Installer KarwosSuite 3 FIA Tool v1.0a, this is used for Reading/Parsing Nokia Flashfiles and Flash/UPP Loaders (FIA), You can activate with this tool FTD Netmonitor on ASIC2,5,6,7 phones and correct MCUSW CRC error on 6610i, 7250i units Download mirrors Mirror 1: http://www.karwosgsm.pl/karwossuite_3_0_l.exe Mirror 2: http://www.karwossuite.pl/karwossuite_3_0_l.exe Mirror 3: HotSupport Area Mirror 4: Multi-Box Support Area WBR, karwosgsm.pl team Last edited by karwos; 11-16-2006 at 15:06. |
The Following 2 Users Say Thank You to karwos For This Useful Post: |
10-10-2006, 06:06 | #2 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | Quote:
Thanx Karwos. | |
10-10-2006, 13:09 | #5 (permalink) |
Freak Poster Join Date: Sep 2005 Location: cluj romania
Member: 185422 Status: Offline Thanks Meter: 41 | what is this error? Interface set: UFSx Card disconnected Looking for FTDI Devices... 1 devices found. Booting UFSx#200xx UFxBoot V2.2 (c) SarasSoft 2003. UFS_USB V2.6 (c) SarasSoft 2005. UFSx Authorization Error C3 |
The Following User Says Thank You to georgegsmro For This Useful Post: |
10-10-2006, 13:18 | #6 (permalink) | |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
http://forum.gsmhosting.com/vbb/showthread.php?t=326379 | |
The Following User Says Thank You to karwos For This Useful Post: |
10-11-2006, 17:41 | #9 (permalink) |
Junior Member Join Date: Dec 2004 Location: Phoenix User Age: 42
Member: 99042 Status: Offline Thanks Meter: 1 | Cool Update but Virus Inside Everytime i read your quickly update, since saras goes wrong with their security. Karwos create and update with great support. But Why, since in version 3j my Antivirus warn me if this software contain of virus. Nor about that, i hope in indon [Yogyaponsel] will have the typhoon smart card. so i am not confused to using the next update. Because, i always play with my box |
The Following User Says Thank You to Tutik For This Useful Post: |
10-11-2006, 20:57 | #10 (permalink) | |
The Following User Says Thank You to huzsolt For This Useful Post: |
10-16-2006, 19:26 | #12 (permalink) | |
it is caused by protection used in our SW Ignore it We finishing cards production will be despatched to resellers sooon and official annonucment will be posted here | |
07-22-2007, 14:42 | #13 (permalink) |
Junior Member Join Date: May 2002 Location: middil east Age: 56
Member: 12430 Status: Offline Thanks Meter: 2 | FTD FOR n73 Dear Sir is this applecation can activate FTD on N73 your feed back is highlly Appreciated regards |
The Following User Says Thank You to latetech For This Useful Post: |
..:: DCT4PLUS :: DISCO LIGHTS TEST :: AC TEST :: KarwosSuite v3.0M Released ::.. | karwos | Typhoon Dongle | 16 | 01-08-2007 22:08 |
.: 6230 IMEI Restore Solution :: Lifetimer Reset :: KarwosSuite v3.0J Released! :. | karwos | Typhoon Dongle | 43 | 09-18-2006 20:33 |
..:: BB-SELFTESTS :: ADC :: KarwosSuite v3.0h Released ::.. | karwos | Typhoon Dongle | 21 | 08-20-2006 22:06 |
..:: KarwosSuite v3.0g Released ::.. | karwos | Typhoon Dongle | 25 | 08-13-2006 12:57 |
..:: KarwosSuite v3.0_f RELEASED ::.. | karwos | Typhoon Dongle | 21 | 08-10-2006 19:31 |
