Cnt Install Karwos Suite,,,, hi ,, KARWOS.... . with some prob.. i stop using.. karwos suite.. for 6-7 months.. cause i m on bad. due to some health reasons.. now i download.. typhoon keyinstaller.. from karwos.. site.. or try to update .card. bt i get this msg... so pls.. can u solved it. .. i have tht my ufs 9011.kac file too.... so pls.. teach me .. how to . Card ID: 96******* Card HW Revision: TYPHOON1 Card Activation Slots: 56 Slot #1 Activated (HotSupport) Slot #2 Activated (Nokia DCT4, WD2, DCT4Plus, ADSP & APE Flasher) Starting Card Update process... Connecting to Typhoon Server... Typhoon Server v9.4+SX4+CRT+FIX1, (c) 2004-2008 KarwosGSM Synchronizing Card Services with Server... Services synchronized OK! Slot #1 Activated (HotSupport) Slot #2 Activated (Nokia DCT4, WD2, DCT4Plus, ADSP & APE Flasher) Updating card firmware... Firmware updated OK Trying to pair card with UFSx... Found 2 FTDI Devices Booting UFSx S/N 9011 Cannot open UFSx #9011. This is critical. Can't boot UFSx Signing card with RSA... RSA Signature written OK Disconnected from Typhoon Server No card [FT SCR2000 0] |
Booting UFSx S/N 9011 Cannot open UFSx #9011. This is critical. Try to reinstall UFSx drivers to latest ones (from C: Program files: sarasSoft: ufs_usb_drivers) |
1 Attachment(s) try to uninstall or install ufs proper drivers... but the same thing apper... so here i upload snap.. of error.. |
BR. |
yes.. working proper.. no prob... |
waiting for reply.. prob.. still conti....... |
Problem is in your UFS drivers, let them be reinstalled. |
i try already uninstall.. or installed.. but the same thing.. anyways .. any other idea.. pls.. tell me ..i try it . |
on device manager. on your ufs hardware( universal serial bus controllers section ) right click and update driver. choose advanced. then choose dont search. i will choose the driver to install. after that, dont pick ufs driver choosen by windows. just clik have disk button. then browse your ufs driver that karwos mention it. thanks |
yes try all most all things... but .same error.. or whn.. start dct-4 tool... gives.. this error code.. may karwsos.. u understand. wht is prob.. here.. through... error code.. Error C4 DM2573 Interface set: UFSx 3 Compatible SmartCard Readers present in system. No card [Axalto e-gate 0] Card found [FT SCR2000 0] Card ID: 969914813 [TYPHOON1] KarwosSuite 3 DCT4 is activated (959) KarwosSuite 3 BB5 is not activated Activation Read OK, Authenthicated OK (FW Version 1.16) Looking for FTDI Devices... 2 devices found. Booting UFSx#9011 UFxBoot V2.2 (c) SarasSoft 2003. UFS_USB V2.8 (c) SarasSoft 2007. Licence: True UFSx Authorization Error C4 DM2573 |
Now your UFS is already booted. The problem is http:///showthread.php?t=519926 dont post your card id here. please edit it. you must send your card ID to karwos. after credit for update granted, you can make update. and problem solved. @ karwos please fix me if i'm wrong. Thanks |
@mentari same thing... after all this... my card id is already added... but ..the same error. |
no reply,, or no solutions.. from .. team.. surprised...... wht to do,... ? |
When you got error: Booting UFSx S/N 9011 Cannot open UFSx #9011. This is critical. You were suggested to reinstall drivers which later you said its same error after uninstall etc.. now after this new log i see a different error which is UFSx Authorization Error C4 DM2573, but have you tried to look around this section, this problem has been discussed many times, check this FAQ thread at http://forum.gsmhosting.com/vbb/showthread.php?t=497488 , you will find what to do, so nothing like surpirsing here, this has been discussed many times before ... BR. |
a good informations... When you got error: Booting UFSx S/N 9011 Cannot open UFSx #9011. This is critical. this eroor comes.. whn... u start card... updating... .... or UFSx Authorization Error C4 DM2573 whn.. start nokia exe.... so this is not diffrent error... its. same as i told... typhoon key or ufs is not still paring.. |
