Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Typhoon Dongle
Old 05-14-2008, 07:04   #1 (permalink)
Member: 18057
Thanks Meter: 64
Cnt Install Karwos Suite,,,,
hi ,, KARWOS.... .
with some prob.. i stop using.. karwos suite.. for 6-7 months.. cause i m on bad. due to some health reasons..
now i download.. typhoon keyinstaller.. from karwos.. site.. or try to update .card. bt i get this msg... so pls.. can u solved it. .. i have tht my ufs 9011.kac file too.... so pls.. teach me .. how to .
Card ID: 96*******
Card HW Revision: TYPHOON1
Card Activation Slots: 56
Slot #1 Activated (HotSupport)
Slot #2 Activated (Nokia DCT4, WD2, DCT4Plus, ADSP & APE Flasher)
Starting Card Update process...
Connecting to Typhoon Server...
Typhoon Server v9.4+SX4+CRT+FIX1, (c) 2004-2008 KarwosGSM
Synchronizing Card Services with Server...
Services synchronized OK!
Updating card firmware...
Firmware updated OK
Trying to pair card with UFSx...
Found 2 FTDI Devices
Booting UFSx S/N 9011
Cannot open UFSx #9011. This is critical.
Can't boot UFSx
Signing card with RSA...
RSA Signature written OK
Disconnected from Typhoon Server
No card [FT SCR2000 0]
Old 05-17-2008, 15:10   #2 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
Try to reinstall UFSx drivers to latest ones (from C: Program files: sarasSoft: ufs_usb_drivers)
Old 05-18-2008, 06:07   #3 (permalink)
Member: 18057
Thanks Meter: 64
try to uninstall or install ufs proper drivers... but the same thing apper...
so here i upload snap.. of error..
Old 05-18-2008, 10:53   #4 (permalink)
HONEY's Avatar
Member: 44158
Sonork: 100.64344
Thanks Meter: 143
Is your UFS Box software working properly?
BR.
Old 05-19-2008, 13:54   #5 (permalink)
Member: 18057
Thanks Meter: 64
yes.. working proper.. no prob...
Old 05-23-2008, 09:44   #6 (permalink)
Member: 18057
Thanks Meter: 64
waiting for reply.. prob.. still conti.......
Old 05-23-2008, 09:44   #7 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Problem is in your UFS drivers, let them be reinstalled.
Old 05-24-2008, 09:04   #8 (permalink)
Member: 18057
Thanks Meter: 64
i try already uninstall.. or installed.. but the same thing.. anyways .. any other idea.. pls.. tell me ..i try it .
Old 05-24-2008, 16:27   #9 (permalink)
Member: 39948
Thanks Meter: 68
try this.
on device manager.
on your ufs hardware( universal serial bus controllers section )
right click and update driver.
choose advanced.
then choose dont search. i will choose the driver to install.
after that, dont pick ufs driver choosen by windows.
just clik have disk button. then browse your ufs driver that karwos mention it.
thanks
Old 05-26-2008, 07:42   #10 (permalink)
Member: 18057
Thanks Meter: 64
yes try all most all things... but .same error.. or whn.. start dct-4 tool... gives.. this error code.. may karwsos.. u understand. wht is prob.. here.. through... error code.. Error C4 DM2573
Interface set: UFSx
3 Compatible SmartCard Readers present in system.
No card [Axalto e-gate 0]
Card found [FT SCR2000 0]
Card ID: 969914813 [TYPHOON1]
KarwosSuite 3 DCT4 is activated (959)
KarwosSuite 3 BB5 is not activated
Activation Read OK, Authenthicated OK (FW Version 1.16)
Looking for FTDI Devices...
2 devices found.
Booting UFSx#9011
UFxBoot V2.2 (c) SarasSoft 2003.
UFS_USB V2.8 (c) SarasSoft 2007.
Licence: True
UFSx Authorization Error C4 DM2573
Old 05-26-2008, 16:59   #11 (permalink)
Member: 39948
Thanks Meter: 68
Now your UFS is already booted.
The problem is
http:///showthread.php?t=519926
dont post your card id here. please edit it.
you must send your card ID to karwos. after credit for update granted, you can make update. and problem solved.
@ karwos please fix me if i'm wrong.
Thanks
Old 05-27-2008, 06:09   #12 (permalink)
Member: 18057
Thanks Meter: 64
@mentari
same thing... after all this... my card id is already added... but ..the same error.
Old 06-02-2008, 07:14   #13 (permalink)
Member: 18057
Thanks Meter: 64
no reply,, or no solutions.. from .. team.. surprised...... wht to do,... ?
Old 06-03-2008, 08:40   #14 (permalink)
HONEY's Avatar
Member: 44158
Sonork: 100.64344
Thanks Meter: 143
When you got error:
You were suggested to reinstall drivers which later you said its same error after uninstall etc.. now after this new log i see a different error which is UFSx Authorization Error C4 DM2573, but have you tried to look around this section, this problem has been discussed many times, check this FAQ thread at http://forum.gsmhosting.com/vbb/showthread.php?t=497488 , you will find what to do, so nothing like surpirsing here, this has been discussed many times before ...
BR.
Old 06-04-2008, 06:34   #15 (permalink)
Member: 18057
Thanks Meter: 64
a good informations...
When you got error:
Cannot open UFSx #9011. This is critical. this eroor comes.. whn... u start card... updating... ....
or UFSx Authorization Error C4 DM2573 whn.. start nokia exe.... so this is not diffrent error... its. same as i told... typhoon key or ufs is not still paring..
Karwos Suite 2.4 - Imei Change for DCT4 ??? Dengel Typhoon Dongle 14 12-10-2008 18:12
Karwos suite 3 activation for karwos suite 4? dudelove Typhoon Dongle 8 02-13-2008 11:30
karwos suite telkomsa159802 UFS2 + UFS3-Tornadoflasher 3 08-21-2005 16:46
Page generated in 0.20802 seconds with 10 queries
