Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Typhoon Dongle
Old 01-18-2007, 05:57   #1 (permalink)
Member: 99042
Exclamation Trick for Karwos N version
If have problem with no card detection for ufs without typhoon card, then your karwos sw can not run by ufs you can do like this.
1. Remove old software
2. Install N version
3. Install new UFS USB driver
4. Install Typhone card reader
All you can found at karwos start menu program
Hope it usefull for you.
br;
Tutik
Old 01-18-2007, 13:37   #2 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
br;
Tutik
Thank You for researching a solution - i will stick the thread.
This is simple bug, so if no any smartcard reader installed in system, software will hang, as i told no one need to buy Typhoon dongle - existing KAC file is enough. Other new tools which we're realising - Will need activated dongle.
Bug is corrected in developed now V3.0O
v2.0o, Typhoon Key Installer v1.0a First Release
- New keys added to keyboard test (0x0A and 0x0B - volume up/volume down)
- New feature: IRDA subsystem testing
- Revised & Released: Sleep mode tests - now possible to make [ms] delay then reset/shutdown phone
- Revised & Released: RF Channels Testing (GSM900, 1800, 1900), tx/rx, burst/continous, high/low, etc
- New Feature: auto changes-apply after low-level contrast write
- Fixed phonebook dumping problems on some phones (8800, 6020)
- Phone Usage State now can switch phone to 3 diffrent phone modes: DEFECTIVE (contact service in result), EXCHANGE (new, used in authorized services), NORMAL
- New Feature: Radio Stations Backing Up
- New Feature: Radio Stations Editing
- New Feature: Radio Stations Dumping
- New Feature: Tuning output level of buzzer volume [0..15], usefull in "quiet-buzzer" phones, use with caution.
- Fixed: Program hangsup if no SmartCard driver installed and interface is UFSx, and Auth-Type is KAc (not card)
- New Softwares Included into Installer: SEMC Debugger, Joker-UFSx, Typhoon 3G Inside, All require activated card NOW !
- New item for backup added: Calendar settings
- New feature: testing HF set (additional to earpiece/buzzer)
- New feature: making Audio loops i.e. between Handsfree Microphone to Buzzer - nice effect, usefull for repair, as always
- New feature: MMC Cards Testing
- New feature: FM Radio Testing - note you need HDS-3 in order to initialize Radio (And of course phone must support  it)
- Redesigned: GUI (previous was.. too small)
- New compatible products: NHL-4, NHL-4JX
- Comprehensive (full) Repair added
- Full user manual added, revised.
- Joker-UFSx added into installer, first release
- UFSx Ini Generator updated, added to installer
- All foreign softwares of KS3 were added to installer and key is required now to run SW
- Samsung 3G Inside were redesigned, updates, included into installer
- SEMC debugger Released, Included into installer
- UFSx Activation Tool, Updated, included into installer
- UFSx Cable Tool, Released, Included into installer
- Typhoon Calculator v2.0c, updated, included into installer
- Corrected PP editing on RH_64
Karwos suite 3 activation for karwos suite 4? dudelove Typhoon Dongle 8 02-13-2008 11:30
anyone have DOOR BELL for KARWOS team akshay Typhoon Dongle 7 04-11-2007 21:35
need activation for karwos neil store Typhoon Dongle 3 12-23-2006 09:43
Page generated in 0.14617 seconds with 9 queries
