01-24-2008, 23:16 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 48
Member: 146798 Status: Offline Sonork: 100.1576177 Thanks Meter: 24 | typhoon can find solution for 5300b network no operator but if we change crt region not pm 308 then imei will be 1234560112345 and network then present u can make calls thats mean there is some data in that region blocked 900mhz allow only 800-1800-1900 now phone working but switched off after some time because imei damaged can mr karwos help us to solve this problem what the secrets in that region how to modify 900 mhz without damage crt region it can be first in the world..... may be hope to hear ur opinion |
01-25-2008, 14:12 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Band info is stored in NPC and for now is not possible to recalculate NPC for good IMEI+RAP and desired Band if NPC is erased then phone using all avaiable RAP bands |
01-31-2008, 13:54 | #5 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Spinning on my OWN Orbit
Member: 5358 Status: Offline Thanks Meter: 211 | how about unlock the phone downgrade back up the rpl full erase and flash the old version of 5300 RM-146 . write the rpl back again then write also the pm using sx4 authoriization and flash with the new version. ( note) inthe pm you use RM-146 you should edit the notepad and erase the pm308 because when you forget it phone becomes contact service ) Full factory setings after.. then post here the results of the method |
02-02-2008, 21:41 | #6 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | But RPL file is calculated in Nokia server (salo or tucson) and they recognize band and RPL is band-locked. No way. Most important is NPC right now, not PM "1" or else |
02-03-2008, 07:47 | #7 (permalink) | |
Member: 146798 Status: Offline Sonork: 100.1576177 Thanks Meter: 24 | Quote:
i try with buying new rpl file for 5300b but new rpl also come with band locked to 800\1800\1900 may be can find way to change band information in NPC | |
Please find solution for data_blk_error | zawphyo | HWK | 1 | 04-20-2009 19:52 |
where i can find fullflash for C75 for repait mobile using papua way ? | PSG | S-Gold Based Phones | 0 | 01-11-2006 14:18 |
I can find Program for active hide function for siemens... | tatae | E-Gold Based Phones | 0 | 06-20-2003 03:56 |
I´M So tired, i can´t find solution for high power consumption!!!! | DREAMGSM | Nokia Hardware & Hardware Repair | 4 | 04-07-2003 10:59 |
