Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Typhoon Dongle
Old 01-08-2007, 22:18   #1 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
Angry ..:: Hot Update :: KarwosSuite v3.0N ::.. 08-01-2007
Hello
New Update of KarwosSuite v3.0N is ready!
At first i would like to say THANKS to all persons who support me !
Also SORRY for long time no updates - it was because almost all December i spent in Hospital
But payback time has come
!!! Don't forget to uninstall previous version before installing this one !!!
Full Changelog
v2.0n
- KarwosGSM team welcome back after Hospital ;-(
- New compatible tested phones: 6822a
- New feature: Product_Profile editor introduced, PPU definition files needed (some are included into package, rest of them You can found into NMP installer packages with flashes). You can switch on/off hidden menus/functions by this Editor, i.e. ALS.
- New feature: lost MMC passwords recovery from TIKU phones or other which supports MMC cards. No MMC reader needed.
- Corrected "Invalid ZIP archive" while working with Typhoon Cards
- New feature: Added option to saving calculated Unlock codes to Logfile (StoredFiles\Unlock.log)
- New feature: Power Amplifier Rx/Tx testing - not released, still during tests
- New feature: SIM Card testing
- New feature: Sleep mode test - not released, still need some corrections
- Update: Reset Contrast is possible to make after PM rebuild (full phone Repair)
- New Feature: Reset all phone counters (Received/Sent SMSs, Call Counter, Switch-On counter, GPRS Data Count etc)
- New Feature: Lifetimer editing (you can tune it to any value you want)
- New Feature: Protecting Gallery Objects (from deleting, renaming, etc)
- New Feature: DeProtecting Gallery Objects (from deleting, renaming, etc)
- New Feature: Copyrighting Gallery Objects
- New Feature: DeCopyrighting Gallery Objects
- New Feature: Possibility to auto-read pressed keys after Starting Keyboard Services
- Corrected: Lifetimer Resetting on some DCT4 models (for now 100% supported are such models as 3100,3200,3220,6610,7210,7250i,6630,N70,1600,2310, 6230i,8800 - in result 80% of all Nokia DCT4/WD2/BB5 phones)
- New: Typhoon Key Maintenance v2.0b - CARD UPDATE NEEDED!
- New: Full USER MANUAL included with all descriptions - ENJOY :-) - Sadly unfinished, release next days
- Corrected: Phonebook parsing on some models
- Corrected: UFSx booting time slightly improved
- Corrected: After FULL PM ERASE Program asks if You want to Rebuild phone PM. (strongly recommended - w/o this phone will not work (resetting on boot screen))
- Corrected: RSSI Tuning Write-Back values
- New Feature: RSSI Backup before Write-Back possible
- Minor changes and bugfixes also
- Corrected: Lifetimer resetting after PM erase (software hangup)
- Corrected: AutoRecognising of Typhoon Dongle on some configurations
- Corrected: Dumped Phonebook in HTML format corrected
- Corrected: 0x55 Reset Error (FBUS NOT READY) after some time of unactivity in DCT4/WD2 phones
- New Feature: if software connects to not-100%-supported phone, it asks whether Attach anyway
- Update: New phones supported in "PM Rebuild" procedure - 6070
- New Feature: While phone attach, it automatically read phone battery charging in percents (note to have authenthic readout, you need to connect phone NOT via standard FBUS+BATTERY cable, but DKU-2 (pop-port to ufs/multibox) or easy flash cable)
- New Feature: Reading of Bad Unlock Code attempts reading
- New Feautre: Date/Time syncronizing with PC, note use EasyFlash/Pop-Port cable with PHONE BATTERY or use in phones with internal System Baterry, because after ejecting cable time will be resetted
- New Feature: High-Level (Safe) contrast tuning, Resetting contrast defaults, etc, Remarks: Tested with RH-19, unsure how it works with other products
- KarwosSuite 3 INI Generator Updated to v1.2, remark it needs Typhoon Card with both activated KS3 and KS3-Addons, new supported phones:
RM140
RM146
RM147
RM158R
RM174
RM181
RM209
(7390,5300,5300b,N91-6,5200,5200b,7373)
- New: supported products for PP editing (rest of support you must catch by installing datapackages from nmp): RM-69, RM-166, NEM-1, NEM-4, NHL-2NA, NHL-4, NHL-6, NHL-9, NHL-10, NHM-8, NPL-1, NPL-2, NPM-6, NPM-9, RAE-6, RH-9, RH-18, RH-19, RH-37, RH-59, RH-64, RM-1, RM-4, RM-25, RM-29, RM-30, RM-72
- Fixed: "Black Screen" After PM Rebuild
Download Mirrors
1. http://www.karwossuite.pl/KarwosSuite_3_0_n.exe
2. http://www.karwosgsm.pl/KarwosSuite_3_0_n.exe
BR,
KarwosGSM.PL Team
The Following User Says Thank You to karwos For This Useful Post:
Old 01-08-2007, 22:33   #2 (permalink)
DJ Morgan's Avatar
Member: 120827
Thanks Meter: 130
good work Mr Karows
..W końcu Polak potrafi :]
Old 01-08-2007, 22:46   #3 (permalink)
HONEY's Avatar
Member: 44158
Sonork: 100.64344
Thanks Meter: 143
Hi,
Its not long time & Welcome back Hospitals are not Good
BR.
Old 01-08-2007, 22:47   #4 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Originally Posted by HONEY View Post
Hi,
BR.
Thx
yes
hospitals are terrible ;(
Old 01-08-2007, 23:01   #5 (permalink)
CrKdz13's Avatar
Member: 111121
Sonork: 100.99340 : CrKdz13
Thanks Meter: 487
welcome back , and happy to see u again
Old 01-08-2007, 23:19   #6 (permalink)
Member: 73808
Thanks Meter: 2
and whats about:
Next version of KarwosSuite - v3.0M will be able to full-reset this Security Code Block (both "bad-attempts" and security code), so you will be able to reset Your security code on DCT4PLUS withous loosing anything.
it's from that topic:
http:///vbb/showthread.php?t=347975
hospitals - i'm going tommorow to make some test - i think
Old 01-08-2007, 23:40   #7 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
Terrible but i have strange feeling, that bad hospitals are only ours country - Poland...
Old 01-09-2007, 05:48   #8 (permalink)
Member: 138575
Thanks Meter: 58
Hi,
Welcome back, Wish you a Happy and healthy new year.
I had to format my system for some resons, now getting error UFSx Authorization Error C4 DM7242. Can you help me please.
jackle123
Old 01-09-2007, 07:36   #9 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Welcome,thanks for the update and also I wish you health and not to see any hospital in future Karwos
Old 01-09-2007, 08:09   #10 (permalink)
HONEY's Avatar
Member: 44158
Sonork: 100.64344
Thanks Meter: 143
Originally Posted by jackle123 View Post
Hi,
jackle123
Hi,
Paste again your old correct KAC file & start using, formatting of your system makes no change in ufs-3 box & read this sticky thread about C4 Solution http://forum.gsmhosting.com/vbb/showthread.php?t=326381
BR.
Old 01-09-2007, 08:14   #11 (permalink)
TEHGSM's Avatar
Member: 109729
Thanks Meter: 36
Welcome back man and have a good year
Old 01-09-2007, 09:59   #12 (permalink)
Member: 18057
Thanks Meter: 64
very very good soft.,,,,,,,,,,,,,,,
Old 01-09-2007, 19:57   #13 (permalink)
huzsolt's Avatar
Member: 75392
Sonork: 100.81199
Thanks Meter: 136
There so mcuh updates I cannot even read it
Old 01-09-2007, 22:46   #14 (permalink)
viru's Avatar
Member: 222198
Sonork: 100.102981
Thanks Meter: 3,813
Good Work Karwos.
B.R.,
Viru
Old 01-11-2007, 07:29   #15 (permalink)
Member: 99042
Nice update mr. karwos, wait for uem reader. I hope you strong enough to script it and bb5 wait too.
..:: HOT - FREE unlock RAPIDO BB5 PLUS ::.. zulea Nokia Base Band 5 ( BB-5 ) 340 04-07-2009 16:06
..:: FREE GIFT for KarwosSuite 3 Users ::.. karwos Typhoon Dongle 9 05-04-2008 03:44
08-01-2007 On-line Server Update gsminfo SagMaster Team OLD Products 28 01-25-2007 13:29
Page generated in 0.29641 seconds with 10 queries
