Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Typhoon Dongle
Old 01-12-2008, 22:33   #1 (permalink)
Member: 98881
Thanks Meter: 23
how to repair unrepairable n73 sx4 failed
hi sir, i want to rapair my nokia n-73 sx4 failed i have tyfone, ufs but i dont have hwk any other solution to repair it using other box ?? please help me sirs
Old 01-15-2008, 09:49   #2 (permalink)
Moderator
oblio's Avatar
Member: 59869
Thanks Meter: 120
Do you have JAF?
If yes, try this: 1st in the world solution to repair unrepairable BB5 phones (SX4 failed)
Old 01-15-2008, 14:18   #3 (permalink)
Member: 98881
Thanks Meter: 23
Originally Posted by oblio View Post
this method is with ufs+hwk but i dont have jaf too,, i get it in next week,
but i have mt box
please typhone suporters help me to repair this phone with typhone and mt if posibel.
Old 01-15-2008, 22:30   #4 (permalink)
huzsolt's Avatar
Member: 75392
Sonork: 100.81199
Thanks Meter: 134
If your certificates are OK, than you should write pm with SX4 auth anytime. If you made full erase, and don't have Cert backup, than most probable your IMEI is broken, so you need RPL first. If you have RPL, or cert backup, than you can make SX4 auth.
Old 01-17-2008, 07:56   #5 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 906
but i have mt box
Hi,
Here is described BB5 repair method via MT-Nokia:
If you have certificate backup ( in MT = IMEI backup ) and valid PM308 ( can be readed even certificate is damaged or phone is downgraded ) - then for sure repair with MT-Nokia can be done! Just follow next.
1. Store on save place original certificate ( IMEI backup ) and original PM308 ( or PM1, 308, 309 ect, or full PM if you have ).
2. Erase full ( use BB5unieraseRAP ... )
3. Write desired SW version ( FW, PPM, Userarea ). Phone will power on with IMEI 123....
4. Put in Local ( or Test ) mode and write original PM 308 ( in MT mean 134 ) and valid 1, and 309 fields ( can be from any working N73 phone ).
5. Wait a couple seconds, reboot in next mode - Normal, Local ect...
5. Flash phone again, but use DOWNGRADE button instead of Flash one in MT-Nokia application.
6. After flashing write back original certificate ( MT = IMEI backup ) - voila - you have 100% OK phone... Say tnx to me
WBR, DebeliaMark, BG
Old 01-20-2008, 16:09   #6 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,715
If you have "card failure" only NPC erase fill help you
Old 01-30-2008, 14:25   #7 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
Originally Posted by debeliamark View Post
Hi,
all this operation make it ( for 3250 ) " imei 1234... downgrade buckup crt all.
but always i havn't network
JAF version 1.98.45
Detected PKEY: 90001A89
Card life counter: 65.04%
P-key nokia module version 01.00
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 04.60
14-09-07
RM-38
(c) Nokia.
PCI version:
RFIC version: 17191719
DSP version: pb05w32v37_rm38
Retu version: 32
Tahvo version: 52
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 12345610654321?
IMEI spare to net: 1A 32 54 16 60 45 23 01
IMEI SV to net: 13 32 54 16 60 45 23 11 F5
LOCK STATUS:
CONFIG KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-38.ini
Done!
MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-38\rm38_04.60_prod_core.fpsx
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-38\rm38_04.60_prod_variant_01_euro1.fpsx
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-38\rm38_04.60_LFFS_Image_EMEA.fpsx
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-38\rm38_04.14_prod_core.fpsx
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-38\rm38_04.14_prod_variant_31.fpsx
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-38\rm38_04.14_prod_variant_01_euro1.fpsx
Phone Type:
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-38\rm38_04.14_LFFS_Image_EMEA.fpsx
Backing up CRT data...
Setting FLASH MODE
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
Loader version: 01.1F.00 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
Getting CMT Public Keys...
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
VARIANT CRT empty, skip save...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\12345678901234_CRT_backup _1357301.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Setting local mode...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\12345610654321?_CRT_backu p_1357301.pm
Done!
Backup LCK OK!
Preparing for downgrade...
Phone ready for downgrade!
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006010C192101001101
Asic Mode ID: 00
Asic EM ID: 00000352
Asic Public ID: 23F00106EAD7515674B59055628D195D17F71762
HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
ROM ID: 191EC665DFAAF68F
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
CMT Boot Ready
CMT Flash ID: 22FE00EC -> ST
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
CMT Loader Ready
Operation took 0 minutes 7 seconds...
Erasing...
Operation took 4 minutes 21 seconds...
Writing...
Stage 1
Sending CMT HASH for MCUSW
Sending CMT HASH for SOS+CORE1
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PMM_CONF
Sending CMT PUB KEYS...
Sending CMT HASH for DSP0
Sending CMT HASH for SOS+ISASW
Sending CMT HASH for PASUBTOC
Sending CMT HASH for UPDAPP
Operation took 5 minutes 23 seconds...
Reseting phone...
PPM: C:\Program Files\Nokia\Phoenix\Products\RM-38\rm38_04.14_prod_variant_01_euro1.fpsx
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Erasing...
Operation took 1 minutes 13 seconds...
Writing...
Stage 1
Sending CMT HASH for SOS+EXT0
Operation took 1 minutes 30 seconds...
Reseting phone...
CNT: C:\Program Files\Nokia\Phoenix\Products\RM-38\rm38_04.14_LFFS_Image_EMEA.fpsx
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Operation took 0 minutes 8 seconds...
Erasing...
Operation took 0 minutes 53 seconds...
Writing...
Stage 1
Operation took 1 minutes 21 seconds...
Reseting phone...
Done!
Total time: 15 Minutes, 5 Seconds
DCT4/BB5 counter: 692
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-38, Software version: 04.14
IMEI: 12345610654321?
APE Ver: (null)
Variant Ver: (null)
Product Code:
Setting FULL FACTORY......Setting test mode...
Operation took 0 minutes 9 seconds...
Done!
Done!
Done!
Changing mode...
Done!
Changing mode...
Done!
Scanning RPL file...
NPC DATA OK...
VARIANT DATA OK...
CCC DATA NOT FOUND...
HWC DATA NOT FOUND...
NPC APE DATA NOT FOUND...
VARIANT APE DATA NOT FOUND...
CCC APE DATA NOT FOUND...
HWC APE DATA NOT FOUND...
SIMLOCK DATA NOT FOUND...
SIMLOCK KEY DATA NOT FOUND...
SUPERDONGLE KEY DATA NOT FOUND...
CMLA KEY DATA NOT FOUND...
WMDRM PD DATA NOT FOUND...
Connecting to phone...
CMT Boot Ready
CMT Loader Ready
Writing NPC DATA...
Writing VARIANT DATA...
Restarting phone...
Done!
Changing mode...
Done!
Reading...
MCU SW version: V 04.14
10-10-06
RM-38
(c) Nokia.
PCI version:
APE SW Core version: V 04.14
11-10-06
RM-38
APE Variant version: V EURO1
30-06-06
RM-38
Retu version: 32
Tahvo version: 52
APE HW version: 256
APE ADSP SW version: 256
Camera version: 1028
Content Pack version: V 04.14
24-10-06
RM38_-39\EMEA_LFFS
(c) Nokia.
Product code:
Module code:
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
IMEI plain: 357934002298692
IMEI spare to net: 3A 75 39 04 20 92 68 09
IMEI SV to net: 33 75 39 04 20 92 68 19 F0
LOCK STATUS:
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
Old 01-30-2008, 14:26   #8 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
Writing PM...
Field: 1, Record: 0, Len: 114 -> Error: Need SX4 auth..
Field: 1, Record: 2, Len: 86 -> Error: Need SX4 auth..
Field: 1, Record: 4, Len: 110 -> Error: Need SX4 auth..
Field: 1, Record: 6, Len: 86 -> Error: Need SX4 auth..
Field: 1, Record: 8, Len: 110 -> Error: Need SX4 auth..
Field: 1, Record: 13, Len: 98 -> Error: Need SX4 auth..
Field: 1, Record: 16, Len: 86 -> Error: Need SX4 auth..
Field: 1, Record: 18, Len: 86 -> Error: Need SX4 auth..
Field: 1, Record: 20, Len: 86 -> Error: Need SX4 auth..
Field: 1, Record: 25, Len: 4 -> Error: Need SX4 auth..
Field: 1, Record: 29, Len: 6 -> Error: Need SX4 auth..
Done!
Old 01-30-2008, 14:30   #9 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
after sx4 auth done seccefully i write full pm and passed
Writing PM...
Field: 1, Record: 0, Len: 114 -> OK
Field: 1, Record: 2, Len: 86 -> OK
Field: 1, Record: 4, Len: 110 -> OK
Field: 1, Record: 6, Len: 86 -> OK
Field: 1, Record: 8, Len: 110 -> OK
Field: 1, Record: 13, Len: 98 -> OK
Field: 1, Record: 16, Len: 86 -> OK
Field: 1, Record: 18, Len: 86 -> OK
Field: 1, Record: 20, Len: 86 -> OK
Field: 1, Record: 25, Len: 4 -> OK
Field: 1, Record: 29, Len: 6 -> OK
Field: 2, Record: 0, Len: 356 -> OK
Field: 4, Record: 0, Len: 1 -> OK
Field: 4, Record: 1, Len: 44 -> OK
Field: 4, Record: 2, Len: 44 -> OK
Field: 4, Record: 3, Len: 10 -> OK
Field: 4, Record: 4, Len: 8 -> OK
Field: 4, Record: 5, Len: 8 -> OK
Field: 4, Record: 6, Len: 8 -> OK
Field: 4, Record: 9, Len: 5 -> OK
Field: 4, Record: 16, Len: 4 -> OK
Field: 8, Record: 0, Len: 12 -> OK
Field: 8, Record: 1, Len: 12 -> OK
Field: 8, Record: 6, Len: 4 -> OK
Field: 8, Record: 7, Len: 8 -> OK
Field: 11, Record: 0, Len: 4 -> OK
Field: 11, Record: 1, Len: 4 -> OK
Field: 11, Record: 2, Len: 4 -> OK
Field: 11, Record: 3, Len: 4 -> OK
Field: 11, Record: 4, Len: 1 -> OK
Field: 11, Record: 5, Len: 6 -> OK
Field: 11, Record: 6, Len: 1 -> OK
Field: 11, Record: 7, Len: 2 -> OK
Field: 11, Record: 8, Len: 2 -> OK
Field: 11, Record: 9, Len: 2 -> OK
Field: 11, Record: 10, Len: 2 -> OK
Field: 11, Record: 11, Len: 2 -> OK
Field: 11, Record: 12, Len: 1 -> OK
Field: 11, Record: 13, Len: 1 -> OK
Field: 11, Record: 14, Len: 1 -> OK
Field: 11, Record: 15, Len: 1 -> OK
Field: 11, Record: 16, Len: 1 -> OK
Field: 11, Record: 17, Len: 1 -> OK
Field: 11, Record: 18, Len: 1 -> OK
Field: 11, Record: 19, Len: 2 -> OK
Field: 11, Record: 20, Len: 2 -> OK
Field: 11, Record: 21, Len: 1 -> OK
Field: 11, Record: 22, Len: 1 -> OK
Field: 11, Record: 23, Len: 4 -> OK
Field: 11, Record: 24, Len: 4 -> OK
Field: 11, Record: 25, Len: 2 -> OK
Field: 11, Record: 26, Len: 2 -> OK
Field: 11, Record: 27, Len: 2 -> OK
Field: 11, Record: 28, Len: 2 -> OK
Field: 11, Record: 29, Len: 1 -> OK
Field: 11, Record: 30, Len: 1 -> OK
Field: 11, Record: 31, Len: 1 -> OK
Field: 11, Record: 32, Len: 1 -> OK
Field: 11, Record: 33, Len: 1 -> OK
Field: 11, Record: 34, Len: 1 -> OK
Field: 11, Record: 35, Len: 1 -> OK
Field: 11, Record: 36, Len: 1 -> OK
Field: 11, Record: 37, Len: 1 -> OK
Field: 11, Record: 38, Len: 2 -> OK
Field: 11, Record: 39, Len: 2 -> OK
Field: 11, Record: 40, Len: 2 -> OK
Field: 11, Record: 41, Len: 2 -> OK
Field: 11, Record: 42, Len: 2 -> OK
Field: 11, Record: 43, Len: 4 -> OK
Field: 11, Record: 44, Len: 4 -> OK
Field: 11, Record: 45, Len: 4 -> OK
Field: 11, Record: 46, Len: 1 -> OK
Field: 11, Record: 47, Len: 16 -> OK
Field: 11, Record: 48, Len: 2 -> OK
Field: 11, Record: 49, Len: 2 -> OK
Field: 11, Record: 50, Len: 20 -> OK
Field: 11, Record: 51, Len: 10 -> OK
Field: 11, Record: 52, Len: 2 -> OK
Field: 11, Record: 53, Len: 20 -> OK
Field: 11, Record: 54, Len: 10 -> OK
Field: 11, Record: 55, Len: 1 -> OK
Field: 11, Record: 56, Len: 1 -> OK
Field: 11, Record: 57, Len: 1 -> OK
Field: 11, Record: 58, Len: 1 -> OK
Field: 11, Record: 59, Len: 1 -> OK
Field: 11, Record: 60, Len: 1 -> OK
Field: 11, Record: 61, Len: 1 -> OK
Field: 11, Record: 62, Len: 1 -> OK
Field: 11, Record: 63, Len: 1 -> OK
Field: 11, Record: 64, Len: 1 -> OK
Field: 11, Record: 65, Len: 1 -> OK
Field: 11, Record: 66, Len: 32 -> OK
Field: 11, Record: 67, Len: 32 -> OK
Field: 11, Record: 68, Len: 2 -> OK
Field: 11, Record: 69, Len: 2 -> OK
Field: 11, Record: 70, Len: 2 -> OK
Field: 11, Record: 71, Len: 2 -> OK
Field: 11, Record: 72, Len: 2 -> OK
Field: 11, Record: 73, Len: 2 -> OK
Field: 11, Record: 74, Len: 2 -> OK
Field: 11, Record: 75, Len: 2 -> OK
Field: 11, Record: 76, Len: 2 -> OK
Field: 11, Record: 77, Len: 2 -> OK
Field: 11, Record: 78, Len: 2 -> OK
Field: 11, Record: 79, Len: 2 -> OK
Field: 11, Record: 80, Len: 2 -> OK
Field: 11, Record: 81, Len: 2 -> OK
Field: 11, Record: 82, Len: 2 -> OK
Field: 11, Record: 83, Len: 2 -> OK
Field: 11, Record: 84, Len: 2 -> OK
Field: 11, Record: 85, Len: 2 -> OK
Field: 11, Record: 86, Len: 2 -> OK
Field: 11, Record: 87, Len: 2 -> OK
Field: 11, Record: 88, Len: 2 -> OK
Field: 11, Record: 89, Len: 2 -> OK
Field: 11, Record: 90, Len: 2 -> OK
Field: 11, Record: 91, Len: 2 -> OK
Field: 11, Record: 92, Len: 2 -> OK
Field: 11, Record: 93, Len: 2 -> OK
Field: 11, Record: 94, Len: 2 -> OK
Field: 11, Record: 95, Len: 2 -> OK
Field: 11, Record: 96, Len: 2 -> OK
Field: 11, Record: 97, Len: 2 -> OK
Field: 11, Record: 98, Len: 2 -> OK
Field: 11, Record: 99, Len: 2 -> OK
Field: 11, Record: 100, Len: 2 -> OK
Field: 11, Record: 101, Len: 2 -> OK
Field: 11, Record: 102, Len: 2 -> OK
Field: 11, Record: 103, Len: 2 -> OK
Field: 11, Record: 104, Len: 2 -> OK
Field: 11, Record: 105, Len: 2 -> OK
Field: 11, Record: 106, Len: 2 -> OK
Field: 11, Record: 107, Len: 2 -> OK
Field: 11, Record: 108, Len: 2 -> OK
Field: 11, Record: 109, Len: 2 -> OK
Field: 11, Record: 110, Len: 2 -> OK
Field: 11, Record: 111, Len: 2 -> OK
Field: 11, Record: 112, Len: 2 -> OK
Field: 11, Record: 113, Len: 4 -> OK
Field: 11, Record: 114, Len: 4 -> OK
Field: 11, Record: 115, Len: 1 -> OK
Field: 11, Record: 116, Len: 4 -> OK
Field: 11, Record: 117, Len: 4 -> OK
Field: 11, Record: 118, Len: 4 -> OK
Field: 11, Record: 119, Len: 4 -> OK
Field: 11, Record: 120, Len: 16 -> OK
Field: 11, Record: 121, Len: 4 -> OK
Field: 11, Record: 122, Len: 2 -> OK
Field: 11, Record: 123, Len: 2 -> OK
Field: 11, Record: 124, Len: 1500 -> OK
Field: 12, Record: 0, Len: 102 -> OK
Field: 44, Record: 0, Len: 1 -> OK
Field: 50, Record: 0, Len: 2 -> OK
Field: 54, Record: 0, Len: 2 -> OK
Field: 88, Record: 0, Len: 36 -> OK
Field: 92, Record: 0, Len: 11 -> OK
Field: 96, Record: 0, Len: 24 -> OK
Field: 107, Record: 0, Len: 21 -> OK
Field: 107, Record: 1, Len: 79 -> OK
Field: 107, Record: 2, Len: 79 -> OK
Field: 107, Record: 3, Len: 70 -> OK
Field: 107, Record: 25, Len: 132 -> OK
Field: 117, Record: 0, Len: 4 -> OK
Field: 117, Record: 1, Len: 3 -> OK
Field: 117, Record: 2, Len: 6 -> OK
Field: 117, Record: 3, Len: 1 -> OK
Field: 117, Record: 5, Len: 10 -> OK
Field: 117, Record: 6, Len: 8 -> OK
Field: 117, Record: 13, Len: 3 -> OK
Field: 117, Record: 14, Len: 3 -> OK
Field: 117, Record: 19, Len: 40 -> OK
Field: 193, Record: 2, Len: 8 -> OK
Field: 193, Record: 3, Len: 32 -> OK
Field: 193, Record: 4, Len: 32 -> OK
Field: 193, Record: 9, Len: 64 -> OK
Field: 308, Record: 0, Len: 1 -> OK
Field: 308, Record: 1, Len: 8192 -> OK
Field: 308, Record: 3, Len: 1 -> OK
Field: 308, Record: 4, Len: 1 -> OK
Field: 308, Record: 5, Len: 10 -> OK
Field: 308, Record: 6, Len: 1 -> OK
Field: 308, Record: 7, Len: 1 -> OK
Field: 308, Record: 8, Len: 1 -> OK
Field: 308, Record: 9, Len: 40 -> OK
Field: 309, Record: 0, Len: 4 -> OK
Field: 309, Record: 1, Len: 2 -> OK
Field: 309, Record: 2, Len: 12 -> OK
Field: 309, Record: 4, Len: 12 -> OK
Field: 309, Record: 5, Len: 12 -> OK
Field: 309, Record: 7, Len: 12 -> OK
Field: 309, Record: 8, Len: 12 -> OK
Field: 309, Record: 17, Len: 12 -> OK
Field: 322, Record: 0, Len: 1 -> OK
Field: 334, Record: 0, Len: 1 -> OK
Done!
but always he havn't netwotk i cheked again the pm and i found this :
Writing PM...
Field: 309, Record: 0, Len: 4 -> Error: Need SX4 auth..
Field: 309, Record: 1, Len: 2 -> Error: Need SX4 auth..
Field: 309, Record: 2, Len: 12 -> Error: Need SX4 auth..
Field: 309, Record: 4, Len: 12 -> Error: Need SX4 auth..
Field: 309, Record: 5, Len: 12 -> Error: Need SX4 auth..
Field: 309, Record: 7, Len: 12 -> Error: Need SX4 auth..
Field: 309, Record: 8, Len: 12 -> Error: Need SX4 auth..
Field: 309, Record: 17, Len: 12 -> Error: Need SX4 auth..
Done!
plz any help.
Old 02-02-2008, 21:43   #10 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,387
Erase NPC, write PM, REstore NPC
K770i HOW TO REPAIR GDFS AFTER FLASH FAIL? denard Cruiser Suite 5 03-25-2010 02:54
how to repair this n73-5 rm-132 prakashmborana MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 07-12-2009 16:55
How to repair "Phone start-up failed. Contact the retailer" with Cyclone Box? vanhh Cyclonebox 14 06-03-2009 12:52
Page generated in 0.46958 seconds with 8 queries
