Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Typhoon Dongle
Old 07-29-2007, 16:42   #1 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,683
Talking KarwosSuite DCT4/WD2/BB5 v3.1a Released
Hello, after hollidays, time for new stuff
KarwosSuite v3.1a Nokia DCT4 / WD2 / BB5 Service Software Released!
What's new?
1. (Almost) Full support for BB5 phones
2. Added Customization function, this is used to customize phone after flashing with needed WAP/MMS/GPRS, Wallpaper, Menu, Bookmarks, Tones, TLS Certificates, etc. This is experimental function, "CUS" files will be avaiable on support soon.
3. BB5 Certificate is now backed-up on PhoneAttach procedure
4. Reorganised GUI
5. Added support for writing *.BB5 backup files, made by Dejan Unlocker
6. Added function "Enter BB5 Nck". This is used to enter NCK code in phone, if keypad counter is blocked. You have 10 tries
7. Improved Multi-FTDI Configuration
8. Added function for repair Keyboard in RH-9 3510i. Just click tab "Repair" and click on ey1a_06 or ey1a_04 , depending on Your PCB Version, and Keyboard will be repaired
9. Full unicode support for Phonebook dumping (polish ęąłóżć, etc)
10. Added support for parsing new Phonebook items: Push-And-Talk address, UserID, Photo
11. Added support for backing-up new items: TLS-WAP Certificates, JAVA TIKU CONTENT, SMS, Equalizer Settings, Link Delegate, GPRS/WAP Settings, MMS Settings, Static Menu Settings
12. Added 'SMS RECOVERY' function, this saving all SMS to HTML. Can recovery deleted too i think
13. Internalization support added - soon Translation SDK will be published, so KS3 could be in Your language too.
14. Implemented phonebook dump in phones: ASIC 2xxx DCT4, TIKU;
15. Added support for Phonebook dump for BB5 based phones, Non Symbian based (tested on 6280). Supported Entries: First Name, Surname, Phone Number (Subentries: Common, Cellular, Video Call, Home, Office, Fax),WWW, UserID, PushAndTalk Address, E-Mail, Video SIP, Company, Job Title, Formal Name, Nickname, Address (Subentries: Street, City, State/Prov, Postcode, Country), UserID, Birthday, Note, Photo, Tone, Video.
16. Rewritten PM Write procedures, no more problems with writting bigger PM Objects
17. Fixed "Enable BB5 Downgrade'" Solution
18. Removed SAFE MODE, PHONE LIST, NEW PHONE CONNECTED Routine, Symbian Attach Timeout. No needed anymore.
19. Saved Certificates/RPLs/PMs have now timestamp to avoid rewriting of broken files.
20. Added FULL SUPPORT for Reading security code in nonsymbian BB5 Phones (Tested on 6280)
21. Added FULL SUPPORT for Writing Security Code in nonsymbian BB5 Phones (Tested on 6280)
22. Added FULL SUPPORT for Reading Security Code Counter in nonsymbian BB5 Phones (Tested on 6280)
23. Added FULL SUPPOT for Writing Security Code Counter in nonsymbian BB5 Phones (Tested on 6280)
24. Added support for reading following Extended Info, on attach: RETU, TAHVO, BOOTCODE VERSION, CAMERA VERSION, Content Package Version, APE Core SW, APE Variant, Ape TST, APE HW, Ape BLUETOOTH, APE ADSP, DVB HW Revision, DVB SW Revision, DVB BOOTLOADER Revision, Simlock Server Revision, Simlock Network, Simlock Active, Simlock Key Count, Simlock FBUS Count, Simlock Stat.
25. Added support for reading "SWITCH-ON" Counter in NonSymbian BB5 Phones, Tested on 6280. This is used to check how many phones was booted, if Lifetimer were erased.
26. Bruteforce reading "SwitchOnCnt" implemented.
27. Fixed many bugs: software hangup when writing Alien PMs, Writing BB5 NCK Code Problems, ProgressBars improved, ProgressBar is moving while writing big PM objects, Fixed double "http" in Phonebook WWW Site dump, Baseband selftests for 1600 and some BB5 corrected, Codes Calculator for DCT4 Improved,
28. Added Support for BB5 Bluetooth Repair (crc)
29. Many other internal changes and other which im don't remember.
Full changelog
Check Typhoon Updater
How to update
Since new installer is not yet ready, Run Typhoon Updater and update Your installation.
WARNING
Update your card firmware to v10 Using Typhoon Key Maintenance Tool. Also to use some BB5 Functions `BB5` service must be activated on card !!!
BR, karwos
Old 07-29-2007, 16:53   #2 (permalink)
dky_tel's Avatar
Member: 120328
Thanks Meter: 209
good work brother...
keep up the good work karwos..
br
Old 07-29-2007, 17:15   #3 (permalink)
GUDO-GSM's Avatar
Member: 216769
Sonork: 100.1576865
Thanks Meter: 225
What About For Multi Box It Is Support This Software?
Old 07-29-2007, 17:18   #4 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Same EXE, but will be released when Fillipp comes.
Old 07-29-2007, 20:02   #5 (permalink)
..::alexis::..'s Avatar
Member: 289200
Thanks Meter: 219
really good work my brother!!!
Old 08-01-2007, 02:32   #6 (permalink)
ll1221's Avatar
Member: 157800
Thanks Meter: 32
Can you support the E90?
Old 08-05-2007, 14:39   #7 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Read FULL PM and we'll see
Old 08-06-2007, 06:05   #8 (permalink)
Member: 244761
Sonork: 100.107029
I have multi-box. please it sends details for unloading or costs of activation, thank you very much.
BR.
EMIGSM
Old 08-07-2007, 06:48   #9 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
BR.
EMIGSM
Its free for Multibox customers.
Old 08-12-2007, 20:29   #10 (permalink)
Gump's Avatar
Member: 35776
Thanks Meter: 132
I've got powerflasher with a license for karwosuite from you?
Old 08-18-2007, 19:07   #11 (permalink)
Member: 323874
Thanks Meter: 2
Angry Reseller in Brasil NEEDED!
AAAAAAAAAHHHHH I NEED THIS TOOL, but I donīt see a reseller in Brazil anywhere.
Old 08-19-2007, 15:04   #12 (permalink)
Member: 226642
Thanks Meter: 3
i need this
i need this ............... i live in Pakistan ........can i anybody have idea how is distributor here !!!
Old 08-22-2007, 17:25   #13 (permalink)
snsoftkiller's Avatar
Member: 250468
Sonork: 100.110362
Thanks Meter: 89
@Troubleshooter & Taskeefoim
Buy Multibox if you dont find typhoon key.
Old 03-14-2008, 00:22   #14 (permalink)
Member: 257017
Thanks Meter: 4
thanks karwos thanks
Old 03-14-2008, 17:54   #15 (permalink)
samusprime's Avatar
Member: 189984
Thanks Meter: 111
Some reseller in America???
@@ All nokia pm file collections of dct4, wd2, bb5, dct4++ here...by mobi_soft @@ mobi_soft Nokia Base Band 5 ( BB-5 ) 25 05-22-2014 09:52
All nokia pm file collections from dct4, wd2, bb5, dct4++ here matnuacai Nokia Base Band 5 ( BB-5 ) 21 05-22-2014 08:31
PM files new collection dct4 wd2 bb5 and dct4+ shahabuddin Nokia Base Band 5 ( BB-5 ) 13 08-19-2010 10:38
NOKIA Flash files DCT4-WD2-BB5 (ppm :turkish,eng,span,it,fr,ger) NOKIA_TR Nokia Digital Core Technology 4 ( DCT-4 ) 58 10-29-2009 22:00
Page generated in 0.42624 seconds with 8 queries
