Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Typhoon Dongle
Old 12-16-2007, 02:31   #1 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Angry Ks 4.0c "next Shot" Ready ;-) Support All Latest Dct4.plus !!!!!!!!!!!!!!!
Hello all
Time to make new release!
v4.0c
- Fixed bugs with BB5 Downgrade option over USB
- Fixed bugs with writing bigger PM objects over USB
- Fixed bugs with reading bigger PM objects over USB
- Added unlock/relock/autolock for RH-93 1110i v6.93 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-93 1110i v6.46 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-93 1112 v6.93 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-93 1112 v6.46 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-94 1112b v3.30 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-97 2610 v6.70 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-97 2610 v5.90 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-97 2610 v5.65 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-98 2610b v6.70 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-98 2610b v5.90 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-98 2610b v5.65 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-64 1600 v6.46 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RM-189 2310 v5.90
- Added unlock/relock/autolock for RM-189 2310 v6.30
- Added unlock/relock/autolock for RM-189 2310 v6.33 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RM-189 2310 v6.50 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RM-291 2626 v4.61
- Added unlock/relock/autolock for RH-99 1200 v4.00 (new security MCU) - first in the world w/o using logs!!!
- Added unlock/relock/autolock for RH-99 1200 v4.11 (new security MCU) - first in the world w/o using logs!!!
- Fixed problems with partials recognition
- Added "Swap ASIC" option while unlocking DCT4plus phones, this used to repair phones with ST_SIMLOCK_TEST failed when unlocked with non-proper tool
- Fixed unlock problems when changed Simlock Profile table
- Removed all UNLOCK imaged and RESTORE images from redist package, from now all needed files will be downloaded real-time from our server
How to download?
Just update your installations using TYPHOON UPDATER and ENJOY!
And small reminder...
while unlocking "OLD SECURITY" dct4plus phones procedure is simple, first write unlock partial, unlock with KS, and then just reflash phone to latest aviable firmware OR write restore_img if thus exists - this is all...
In case of "new security" phones procedure is following: flash phone with "unlock partial" as mcu, TOGETHER with PPM, CNT and unlock with our tool. NO NEED TO REFLASH after unlock, phone WILL have signal, ST_FLASH_CHECKSUm and ST_SIMLOCK will be OK of course.
While unlocking make sure stable internet connection you have - bad signature means contact service
Supported models/versions for unlock:
RH-64 1600 v6.46
RH-86 2610 v3.71
RH-86 2610 v3.75
RH-86 2610 v3.77
RH-86 2610 v4.50
RH-86 2610 v4.51
RH-86 2610 v4.90
RH-86 2610 v5.65
RH-86 2610 v5.90
RH-86 2610 v6.70
RH-87 2610b v3.71
RH-87 2610b v3.75
RH-87 2610b v3.77
RH-87 2610b v4.50
RH-87 2610b v4.51
RH-87 2610b v4.90
RH-87 2610b v5.65
RH-87 2610b v5.90
RH-87 2610b v6.70
RH-92 1112i v5.03
RH-93 1112 v5.03
RH-93 1112 v5.50
RH-93 1112 v5.53
RH-93 1112 v5.54
RH-93 1112 v6.00
RH-93 1112 v6.01
RH-93 1112 v6.40
RH-93 1112 v6.41
RH-93 1112 v6.46
RH-93 1112 v6.93
RH-93 1110i v5.03
RH-93 1110i v5.50
RH-93 1110i v5.53
RH-93 1110i v5.54
RH-93 1110i v6.00
RH-93 1110i v6.01
RH-93 1110i v6.40
RH-93 1110i v6.41
RH-93 1110i v6.46
RH-93 1110i v6.93
RH-94 1112b v3.00
RH-94 1112b v3.11
RH-94 1112b v3.30
RH-97 6060 v3.03
RH-98 6060b v3.03
RH-99 1200 v3.12
RH-99 1200 v3.40
RH-99 1200 v3.44
RH-99 1200 v4.00
RH-99 1200 v4.11
RH-105 1208 v3.72
RH-105 1208 v4.00
RH-105 1208 v4.11
RM-189 2310 v2.10
RM-189 2310 v3.10
RM-189 2310 v3.21
RM-189 2310 v3.31
RM-189 2310 v5.10
RM-189 2310 v5.90
RM-189 2310 v6.30
RM-189 2310 v6.33
RM-189 2310 v6.50
RM-225 6030b v5.24
RM-225 6030b v5.25
RM-291 2626 v3.51
RM-291 2626 v4.61
ps. 1630,2630..etc will come ASAP, but cheap logs will be needed.
BR,
karwos
Old 12-16-2007, 02:39   #2 (permalink)
Member: 59794
Lightbulb
Thx karwos nice work !
B,R
Catik
Old 12-16-2007, 02:44   #3 (permalink)
ryumahon's Avatar
Member: 4021
as far as i know 2610b can be unlocked by some local softs here in our country but have you tried unlocking with karwos suite and made convertions already??? does it have signals???
coz im pretty sure if it is just like the 1200/1208 procedure of unlocking... you wont have any signal of it after you unlock it even if you write a good pm/ replace a good filter with the 2610b....
just want to make sure if your solution if is really is working... coz as of now.. ONLY UB unlocks it with LOGS has signal after unlocking and changing of filters...
br
Old 12-16-2007, 02:46   #4 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Small test
Product RH-93
MCU Version V 6.46
MCU Compilation Date 22-03-07
Product Manufacturer KARWOS!
Unlock started
IMEI: 356637008768227
Product: RH-93
ASIC: 11
MCU Version (V 6.46)
Local mode set
Unlock mode: Server Signed
Simlock Profile: 00000000000100
-> Connecting to Typhoon Server...
=> Typhoon Server v8.3, (c) 2004-2007 KarwosGSM
-> Sending Hash Request... OK
-> Received hash OK
-> Connection closed
Writing locks... OK, Status: Opened, MCC-MNC: 00101
Repowering...
Unlock finished
Old 12-16-2007, 02:47   #5 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
br
Sure, phone working and have signal! But patched MCU must be all time written in phone due to new security
I think that is not a problem
Old 12-16-2007, 02:53   #6 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Here is selftests result after unlocking
Old 12-16-2007, 08:37   #7 (permalink)
ryumahon's Avatar
Member: 4021
with the 2610b i mean.. not with the 1112 or 1200
Old 12-16-2007, 08:58   #8 (permalink)
hungco's Avatar
Member: 223718
Karwos can you give me this soft in PM? I'm MultiBox use!
Old 12-16-2007, 09:31   #9 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
@Karwos
nice work, keep it up, u done it in no time.
Take Care
ENJOY
Old 12-16-2007, 10:10   #10 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
If you mean additional secuirty pass of data integrity in first 1mbyte of flash, it was bypassed
Old 12-16-2007, 10:14   #11 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Lets wait for GSMTricks
Old 12-16-2007, 11:40   #12 (permalink)
elektroserwis's Avatar
Member: 87382
Sonork: 100.96303
Thx super update ;-)
Old 12-16-2007, 15:51   #13 (permalink)
Member: 248182
Originally Posted by karwos View Post
Hello all
v4.0c
How to download?
RH-64 1600 v6.46
RH-86 2610 v3.71
RH-86 2610 v3.75
RH-86 2610 v3.77
RH-86 2610 v4.50
RH-86 2610 v4.51
RH-86 2610 v4.90
RH-86 2610 v5.65
RH-86 2610 v5.90
RH-86 2610 v6.70
RH-87 2610b v3.71
RH-87 2610b v3.75
RH-87 2610b v3.77
RH-87 2610b v4.50
RH-87 2610b v4.51
RH-87 2610b v4.90
RH-87 2610b v5.65
RH-87 2610b v5.90
RH-87 2610b v6.70
RH-92 1112i v5.03
RH-93 1112 v5.03
RH-93 1112 v5.50
RH-93 1112 v5.53
RH-93 1112 v5.54
RH-93 1112 v6.00
RH-93 1112 v6.01
RH-93 1112 v6.40
RH-93 1112 v6.41
RH-93 1112 v6.46
RH-93 1112 v6.93
RH-93 1110i v5.03
RH-93 1110i v5.50
RH-93 1110i v5.53
RH-93 1110i v5.54
RH-93 1110i v6.00
RH-93 1110i v6.01
RH-93 1110i v6.40
RH-93 1110i v6.41
RH-93 1110i v6.46
RH-93 1110i v6.93
RH-94 1112b v3.00
RH-94 1112b v3.11
RH-94 1112b v3.30
RH-97 6060 v3.03
RH-98 6060b v3.03
RH-99 1200 v3.12
RH-99 1200 v3.40
RH-99 1200 v3.44
RH-99 1200 v4.00
RH-99 1200 v4.11
RH-105 1208 v3.72
RH-105 1208 v4.00
RH-105 1208 v4.11
RM-189 2310 v2.10
RM-189 2310 v3.10
RM-189 2310 v3.21
RM-189 2310 v3.31
RM-189 2310 v5.10
RM-189 2310 v5.90
RM-189 2310 v6.30
RM-189 2310 v6.33
RM-189 2310 v6.50
RM-225 6030b v5.24
RM-225 6030b v5.25
RM-291 2626 v3.51
RM-291 2626 v4.61
BR,
karwos
Dear Karwos
Can You Explain me About Typhone Dongle
what is the benfit ?
is it universal or only for nokia
or its addon some other tool
WBR
Bluffmaster
Old 12-16-2007, 16:04   #14 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
hi
this is dongle like PKEY and end usr price is 30usd
its works through UFS
or USB cable(bb5)
basicly is for Nokia but we have also some old Samsungs ready and of course will work on other brands also soon.
It have also"UFSxJOKER" addon
Old 12-16-2007, 16:16   #15 (permalink)
hungco's Avatar
Member: 223718
I'm in Vietnam, how to buy?
Get all latest DCT4 flash files here only mcu ppm cnt all by kailash_gm kailash_gm Nokia Digital Core Technology 4 ( DCT-4 ) 17 05-07-2012 11:09
:: all latest dcT4+ firmwares:: toutou_gsm Nokia Digital Core Technology 4 ( DCT-4 ) 5 10-06-2009 14:09
.:: New Release: Cruiser Suite PDA Flasher v1.08 supports all latest SE PDAs ::. Mizar GSM News & Updates 0 08-20-2008 19:50
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting. ()
Page generated in 2.13466 seconds with 8 queries
