Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Typhoon Dongle
Old 05-20-2007, 18:53   #1 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
Exclamation Typhoon Installer v1.1.1 Update 20.05.2007 - Discussion
Typhoon Key Installer v1.1.1 [20.05.2007]
* KarwosSuite DCT4/WD2 v3.0x
- Added support for resetting Security Code to 12345 on BB5 Units (crypted SecCode),
- Changed ASIC2 unlock method, now all DCT4Plus phones (both ASIC2 and ASIC11) needs internet connection in order to unlock
- Added support for unlock/relock/autolock of RM-189 2310 v5.10
- Added support for unlock/relock/autolock of RM-189 2310 v3.10
- Added support for unlock/relock/autolock of RH-93 1112 v5.03
- Added support for unlock/relock/autolock of RH-93 1112 v5.50
- Added support for unlock/relock/autolock of RH-93 1112 v6.40
- Added support for unlock/relock/autolock of RH-93 1112 v6.41
- Added support for unlock/relock/autolock of RH-92 1112b v5.03
- Added support for unlock/relock/autolock of RM-225 6030b v5.24
- Fixed "Simlock Server Denied, Code: 07" when unlock 6030b
- Fixed problems with UPP booting (bigger delays)
- Fixed bug when some locks levels wasnt removed on ASIC2 DCT4PLUS phones (GID1, GID2, IMSI)
- Fixed bug when IMEI wasnt recognized properly on some configurations, while unlocking
- Added hints while "Asic Recovery" procedure (which phone, which asic)
- Added support for autolock NET
- Added support for Typhoon Server v8 Protocol
- Added auto-repower after updating locks status. Note CORRECT CABLE with CORRECT BSI-GND resistor value is needed to proper work !
- If something goes wrong while DCT4plus unlocking (Simlock Server Denied), then probably Reason are being displayed
- Some internal prepares to direct unlock 1600, 1110
- Fixed bugs with "Wr Security" function, this procedure was rebuild
- Added Gro***** to select "WrSecurity" method, or Locks method (unlock,relock,autlock imsi, autolock net)
- Changed SmartCard connection mode to 'SHARED'. That means You can now freely use as many Typhoon applications as you want, simulatenously.
- Minor changes and bugfixes
* New HotSupport HDEFs included
* Typhoon Updater, updated (Divison 0, in some configurations fixed, due to bad ISP proxy rules)
* KarwosSuite 3 DCT4/WD2 Activation Tool Rev. D4
- Fixed problem with recognizing `HWK Pairment` status on some configurations
* KarwosSuite 3 BB5 Tool v1.0c
* CPT Access Tool, Rev A2
* UFSxJoker v1.3.4.1b
- Added small "TP" button. Its used to fast see TP used in phone. Just select model, and click TP.
- Default Baud is now 921k
- Some CPU optimalizations
- Support for EGOLD phones: Ax75, AF51, AL21, CF110
- Some minor GUI/Code changes
* Samsung 3G CR v1.0f
* Typhoon Key Calculator v1.0f
* UFSx INI Generator v1.4b
* UFSx SLD Generator DCT4/WD2 v2.0d
- Added support for ASIC 0B (11) phones
* Typhoon Updater Rev. 2
- Fixed "Floating point division by zero" problem on some network configurations (when users are behing Squid, or other transparent proxy)
* HotSupport v1.5.1
- Fixed "Invalid Operation" after HS Close
- Updated Typhoon key searching algorithm, now is possible to have _any_ other Smartcard reader connected
- "Password section" in Environment.ini is empty - fixed
- Fixed bug with GUI rewrite after hidding it into taskbar/tray
- Added Stop button - finally
- We are sorry but we cant add Progressbar at the moment, since it needs some server changes. We will try to take care of it and fix ASAP. So, while downloading flashes, cup of tea for all !!
- Known problem: if you are behind transparent proxy cache, "speedometer" may not work correctly
* Installer
- Added support for automatic updater just right after installation
Download whole installer from:
1) http://www.karwosgsm.pl/typhoonkeyinstaller.exe
2) http://www.karwosgsm.pl/typhoonkeyinstaller.exe
OR update your installations via Typhoon Updater
OR Run HotSupport - it will download and install Installer automatically!
br,
karwos
Old 05-20-2007, 18:58   #2 (permalink)
::. zine .::'s Avatar
Member: 161061
Thanks Meter: 568
wow great update thnx
Old 05-20-2007, 18:59   #3 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Sleep team? We not sleeping, just look at the 'Updates' Thread.
Old 05-20-2007, 19:03   #4 (permalink)
fonec's Avatar
Member: 11101
Sonork: 100.1641000
Thanks Meter: 1,783
great work go up and thanks for great support
Old 05-20-2007, 19:04   #5 (permalink)
Member: 161061
Thanks Meter: 568
exuse me i have rectified i think author team
Old 05-20-2007, 19:07   #6 (permalink)
HONEY's Avatar
Member: 44158
Sonork: 100.64344
Thanks Meter: 143
Good work Karwos, Thanks for the update ...
BR.
Old 05-22-2007, 17:36   #7 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Typhoon Key Standalone Update [22.05.2007]
- Added support for unlock/relock/autolock of RM-189 2310 v2.10
As ordinary, run TYPHOON UPDATER to update necessary files
HWK Release 23/05/2007 - Discussion Odia The Ultimate HWK 83 06-10-2007 10:53
HWK Release 10/05/2007 - Discussion Odia The Ultimate HWK 57 05-25-2007 01:09
Typhoon Installer v1.1.0 - Discussion karwos Typhoon Dongle 13 05-23-2007 09:36
HWK Release 14/05/2007 - Discussion Odia The Ultimate HWK 91 05-17-2007 22:57
**MT-box SE updates** - 20.03.2007 - DB2020 inside v1.6 realized SoftMobile MT-BOX 17 03-27-2007 07:35
Page generated in 0.24474 seconds with 9 queries
