12-23-2007, 17:39 | #2 (permalink) |
No Life Poster Join Date: Sep 2005 Location: UK, London Age: 35
Member: 177235 Status: Offline Sonork: 111568 Thanks Meter: 138 | Hi, This is not the cause of unlocking the phone, But just to confirm you can re-write the backup pm and reflash the phone, If the problem is still there then its a hardware issue, Use a microscope and see what you have damaged during unlocking. Best Regards, |
12-23-2007, 18:32 | #3 (permalink) | |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | Quote:
br khalid | |
12-23-2007, 19:33 | #4 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: MAROCCO TO MEKNES Age: 40
Member: 376587 Status: Offline Thanks Meter: 8 | Quote:
12-23-2007, 19:38 | #5 (permalink) | |
thanks for this reply brother | |
05-19-2009, 10:45 | #10 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Cape Town South Africa
Member: 617428 Status: Offline Thanks Meter: 52 | Guts now explain this to me as have had 3 of these units and they all have the same fault,display black changed lcd and flex assysembly and even replaced display ic's and still the problem is there. Had success with only one E65 thus far so what would you suggest checked with to oher advance technician's here at our certified nokia repair centre and still we are stumped for a zero not even nokia can explain this,all they say is replace pcb. |
03-27-2010, 12:43 | #11 (permalink) |
No Life Poster Join Date: Oct 2005 Location: INDIA Age: 38
Member: 186840 Status: Offline Thanks Meter: 103 | I have the same problem everything is working perfect but on blank screen i have changed flex and even those two ic's in the two bottom corner of the connector but still problem not solved pls advise |
2 Pieces NOKIA 6680 Blinking After Flashing Using MT-BOX | handilak | MT-BOX | 10 | 05-29-2007 06:19 |
working 6630 dead after flashing in mt box | gsmservices | MT-BOX | 3 | 06-12-2006 17:00 |
