02-23-2007, 19:32 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 23.02.2007 - MT Box Nokia - MTB NK v1.29.5 realised - New button 'BB5 Downgrade' – Button is located in the right-bottom corner of the application. It destroys the version control field, as described by Dejan. How to use it: Select flash files for the version you wish to flash the phone to. Press 'BB5 Downgrade'. Application will erase field, and flash phone. No additional actions needed. Tested on 6131, 6280. We recommend that you backup the security field before that (0x134:1). - Extended information, when bootinfo fails for BB5 phone. This should help diagnose what is wrong with BB5 phones. - Improved Certificate Backup/Restore. - Improved RPL writing for BB5 phones. - Extended information on what certificates are read/written to phone. - Added check whether EXE is used with correct installation. Some users copy exes to very old installations, and then have problems using the program. So this exe checks griffin.ini to see if the latest installation was used. To hack the check, open griffin.ini, and make under '[interface_options]' write 'installation=mtb_nk_setup1_29_5.exe'. This hack is needed if you insist on NOT using the installations we publish. - Bugfix: Autosave the checkboxes for 'BB5 308 Backup', 'BB5 IMEI Backup' Temporary download link: MTB NK 1.29.5 setup.exe |
02-23-2007, 19:53 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: U wont beleive Age: 43
Member: 275631 Status: Offline Thanks Meter: 408 | good update... thanx.... but i m facing a problem using mt.... i face this problem only in wd2 fons ... when ever i full erase n flash ... it always crupts imei..... why so??????? plz help... why it doestnt make imei backup as in jaf.... |
02-23-2007, 20:00 | #5 (permalink) |
No Life Poster Join Date: Feb 2003 Location: India Age: 39
Member: 20691 Status: Offline Thanks Meter: 20 | Nice Update from Griffin Team Thank You ! But need to ask that will i be able to repair my N91 "Phone start up Failed" problem with this update ??? Regards, Tanvir ! www.tanuelectronics.com |
02-24-2007, 04:28 | #15 (permalink) |
Insane Poster Join Date: Jul 2003
Member: 33029 Status: Offline Thanks Meter: 9 | Few months back I read a post wrong flash from model nokia 6680 to 6681 & during that time 6681 version is higher than 6680 so it can't be downgrade back to 6680 so with this BB5 Downgrade function introduced can this kind of problem be solve.Thanks in advance. |
MT Box Nokia - MTB NK v1.55.5 | rotelcam | Service Products News & Updates | 0 | 11-25-2008 15:45 |
MT Box Nokia - MTB NK v1.54.1 | sassa_01 | MT-BOX | 9 | 11-15-2008 05:16 |
17.12.2007 - MT Box Nokia - MTB NK 1.41.2 | Farrass | MT-BOX | 5 | 12-18-2007 06:15 |
<<< 15.12.2007 - MT Box Nokia - MTB NK 1.41 >>> | Faisal_Computer | MT-BOX | 52 | 12-17-2007 08:56 |
MT Box Nokia - MTB NK v1.25.3 | SoftMobile | MT-BOX | 31 | 12-01-2006 12:30 |
