07-14-2006, 17:59 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Age: 47
Member: 18855 Status: Offline Thanks Meter: 1,938 | MTb_Siemens Release For Unlock and Repair Egold based unlock time 1 second A Series: A31 A51 A52 A52M A52V A55 A57 A60 A62 A62C A65 A65C A70 A71 A75 AF51 AL21 AX72 AX75 C Series: C55 C60 CF110 CF62 M Series: M55 MC60 S Series: S55 S57 SL55 SL57 UM_SGold Supported Models: Sgold based unlock time 10 seconds C Series: C65 C66 C6C C6V C72 C75 CF75 CX65 CX70 CX75 CX7i C72V CX6C CX6V CX7C CX7V SL6C C70 M Series: M65 M75 ME75 M6C S Series: S65 SK65 SK6R SL65 S6V S6C S66 S75 SL75 S68 --------------------------------------------------------- Unlock With TestPoint. No Need To Cut TestPoint Unlock, Repair (direct unlock and codes generation) No battery needed, all unlock process are fully controlled by the box --------------------------------------------------------------------- Q: Can I update My MTb_Nk or Se to use with the Siemens by using log to activate the box? A: No. You have to buy New box for the Siemens Q: If I purchase MT-B Siemens Can i Update to Nk or SE A: No. For Every Siemens Box you can only activate for Alcatel only which u need to have 20 griffin log to activate it. For Your Information Every MTb_Siemens have Trail version for Nokia 10 times Sony Ericsson 10 times Alcatel 12 times This trail which is free after finish the trail ,your box will not open the Module again it will say MT-Box interface not found. only you can run for siemens Click Here To Purchase Package Contains : 1 x MT Box Siemens 3 in 1 Siemens cables 1 x Siemens adapter 1 x Sie X5X cable 1 x Sie A31 cable 1 x Sie X4X cable 14 pcs MT Box Alcatel cables ADAPTER cable OT525 OT715 E256 OT320 OT535/OT735 OT531 OT152 OT835 DB OT311/OT511 (2pcs) OT155/OT156/OT355 Test point cable EXE Avaliable for Download at support area also User Manual Here Some Log Of Unlock by MTb_Siemens AF51 ----- boot phone... Boot accepted detected phone Model: AF51 ASIC: PMB 7860 11E 3R G542 Flash device: 0001:227E(2221:2201) Phone ID: 07176A38 OTP IMEI: 35912100000000 EEPROM IMEI: 35912100000000 sending unlock data.. Done. Operation done in [0.922 sec.] --------------------------------------------- CF75 ----- Sgold detected... JBOOT: Start... JBOOT: Started... TP OFF BOOOTCORE ACTIVE MCU MANIFACTURER: Infineon MCU: PMB 8875 V1.1B G12 PHONE MANIFACTURER: SIEMENS PHONE MODEL: CF75 BOOTCORE IMEI: 356909000000000 BOOTCORE HASH: E9D50E7AE73A62A57A5A55EF0775A09A Flash ID: 880D Flash Manifacturer ID: 0089 Flash ID0: 0001 Flash ID1: 0001 Flash size: 32 mb. Flash chip: INTEL 28F256L18T OTP ZONE: 21469B01EB429106FFFFFFFFFFFFFFFF OTP IMEI: 356909000000000 ESN: 04FDE1F8 Reading security... Updating security... Using SLOW method. Please be patient... DONE. Leave boot... -------------------------------------------------- CF110 ------ Boot accepted detected phone Model: C110 ASIC: PMB 7860 11E 3R G542 Flash device: 0001:227E(2221:2201) Phone ID: 44C68E96 OTP IMEI: 35754700000000 EEPROM IMEI: 35754700000000 sending unlock data.. Done. Operation done in [8.109 sec.] boot phone... Boot accepted boot phone... Boot accepted detected phone Model: C110 ASIC: PMB 7860 11E 3R G542 Flash device: 0001:227E(2221:2201) Phone ID: 978F0082 OTP IMEI: 35754700000000 EEPROM IMEI: 35754700000000 sending unlock data.. Done. Operation done in [5.828 sec.] ---------------------------------------- CX70 ----- Powered by Griffinteam. MT-BOX SN:000Siemens CORE VER: CR v1.101 PLUGIN VER: SI v0.020 TP ON Sgold detected... JBOOT: Start... JBOOT: Started... TP OFF BOOOTCORE ACTIVE MCU MANIFACTURER: Infineon MCU: PMB 8875 V1.1B G12 PHONE MANIFACTURER: PHONE MODEL: BOOTCORE IMEI: BOOTCORE HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Flash ID: 880D Flash Manifacturer ID: 0089 Flash ID0: 0001 Flash ID1: 0001 Flash size: 32 mb. Flash chip: INTEL 28F256L18T OTP ZONE: 08769701A6415479FFFFFFFFFFFFFFFF OTP IMEI: 353542006888888 ESN: 7B34D29C BCORE IMEI DIFFERENT FROM OTP IMEI Reading security... Updating security... Using fast method. DONE. Leave boot... TP ON Sgold detected... JBOOT: Start... JBOOT: Started... TP OFF BOOOTCORE ACTIVE MCU MANIFACTURER: Infineon MCU: PMB 8875 V1.1B G12 PHONE MANIFACTURER: PHONE MODEL: BOOTCORE IMEI: BOOTCORE HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Flash ID: 880D Flash Manifacturer ID: 0089 Flash ID0: 0001 Flash ID1: 0001 Flash size: 32 mb. Flash chip: INTEL 28F256L18T OTP ZONE: 08769701A6415479FFFFFFFFFFFFFFFF OTP IMEI: 353542006888888 ESN: 7B34D29C BCORE IMEI DIFFERENT FROM OTP IMEI Reading security... Updating security... Using SLOW method. Please be patient... DONE. Leave boot... Last edited by MicrostarGSM®; 01-19-2007 at 13:48. |
07-14-2006, 19:41 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | I don't think that you can compete with the king Martech with that Unlock time of 1 sec. Can you tell us does this box unlock for example M55 v11, C60, A60, A70, etc without opening? BR |
07-14-2006, 19:57 | #3 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: Baltchik,Bulgaria Age: 50
Member: 47236 Status: Offline Thanks Meter: 58 | Quote:
not compare section mate so you cant do it with martech also without open and why you need dead models still? can you do them with one TP(like MT-siemens) with martech ? br | |
07-14-2006, 22:30 | #8 (permalink) | |
No Life Poster Join Date: May 2005 Location: Croatia Age: 42
Member: 144433 Status: Offline Thanks Meter: 49 | Quote:
A: No. You have to buy New box for the Siemens | |
07-14-2006, 22:53 | #9 (permalink) | |
No Life Poster Join Date: Nov 2003 Age: 42
Member: 45183 Status: Offline Thanks Meter: 474 | Quote:
Martech will stay everytime NO.1 | |
07-15-2006, 01:43 | #10 (permalink) | |
07-15-2006, 09:26 | #14 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: Serbia
Member: 82990 Status: Offline Thanks Meter: 106 | Quote:
http://www.i-phone.org/main/product/...d=11512&curr=2 | |
07-15-2006, 10:57 | #15 (permalink) | |
Every Team has his best side! Griffins best side is Nokia, Martechs best side is Siemens, Victors best side is Motorola, ....... br karabey | |
Samsung Qualcomm tool 4.1 release! Direct unlock and repair IMEI all MSL2 phones!!! | mk | Z3X-Team Products | 34 | 12-26-2008 18:19 |
all tools for unlocking and repairing | unlteam | Main Sales Section | 0 | 11-08-2005 13:50 |
All solutions for unlocking and repairing | unlteam | Main Sales Section | 0 | 09-27-2005 10:41 |
I Need to start with GSM where can by good interface/cable for unlock and repair | jame | Hardware Repair Item Wanted | 0 | 06-04-2004 19:41 |
