10-09-2007, 16:49 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | 6126 RM-126 Dead after flash Can you pease help me. My 6126 RM-126 dead after flash by usb. I try buy fbus give me error erasing flash. I use to flash them even change them to RM-115 without any problem. The phone is from AT&T. After phone flash screen comes white and shut down. Is there any hope to revive it. |
10-09-2007, 17:59 | #5 (permalink) |
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | I try both 5.60 and 5.61. Just have a look in 5.60 flashing Processing File: rm126__05.60.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Backup: \GSM_35765401086233_2.r3c Erase RAP3 [00000000 - 000006BF] Erase RAP3 [000006C0 - 0001FFFF] Erase RAP3 [00020000 - 0007FFFF] Erase RAP3 [00080000 - 000DFFFF] Erase RAP3 [00100000 - 001FFFFF] Erase RAP3 [00200000 - 002DFFFF] Erase RAP3 [002E0000 - 00EDFFFF] Erase RAP3 [00EE0000 - 00EF7FFF] Erase RAP3 [00EF8000 - 00EFFFFF] Erase[14.88 MB]... Waiting response for 320 Sec...in 61.75s Flash[12.91 MB]...in 46.39s * * Processed file in 119.59 seconds Processing File: rm126__05.60.image_ntm_tmobusa Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01460000 - 01FDFFFF] Erase[11.50 MB]... Waiting response for 320 Sec...in 56.50s Flash[3.69 MB]...in 12.48s * * Processed file in 96.42 seconds Extract content...fail Processing File: rm126__05.60.ppm_ntm Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00F00000 - 0145FFFF] Erase[5.38 MB]... Waiting response for 320 Sec...in 18.05s Flash[3.91 MB]...in 13.91s * * Processed file in 39.98 seconds * * * Phone flashing done in 5:39 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! WARNING: THE VERSION YOU SELECTED: 05.60 is NOT the highest installed!!! the highest available is: 05.61 VPP is DISABLED. BB5 PM back Phone is in: Phone is not responding! Processing File: rm126__05.60.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Backup: \GSM_35765401086233_3.r3c Erase RAP3 [00000000 - 000006BF] Erase RAP3 [000006C0 - 0001FFFF] Erase RAP3 [00020000 - 0007FFFF] Erase RAP3 [00080000 - 000DFFFF] Erase RAP3 [00100000 - 001FFFFF] Erase RAP3 [00200000 - 002DFFFF] Erase RAP3 [002E0000 - 00EDFFFF] Erase RAP3 [00EE0000 - 00EF7FFF] Erase RAP3 [00EF8000 - 00EFFFFF] Erase[14.88 MB]... Waiting response for 320 Sec...in 61.22s Flash[12.91 MB]...in 46.06s * * Processed file in 118.05 seconds Processing File: rm126__05.60.image_n_USdef_6133 Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01460000 - 01FDFFFF] Erase[11.50 MB]... Waiting response for 320 Sec...in 27.48s Flash[3.44 MB]...in 11.66s * * Processed file in 66.56 seconds Extract content...fail Processing File: rm126__05.60.ppm_n Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00F00000 - 0145FFFF] Erase[5.38 MB]... Waiting response for 320 Sec...in 18.59s Flash[3.76 MB]...in 13.44s * * Processed file in 40.02 seconds * * * Phone flashing done in 5: 8 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! |
10-09-2007, 18:14 | #6 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | if you are using 10 pin cable means...no problem..just selct "use Tx2 line" and try again... if you are using 8 pin cables means just we have to wait for the answer from the supporter ...whether this phone has to flashed with Tx2 line or not... if we have to use Tx2 for this fone means ..need to modify the cable... |
10-13-2007, 16:33 | #7 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | I have the same problem with A 6126 flashing. I use 6131 FBUS cable for flashing and I can flash it via this cable but in the end when software comes to Set Factory Defaults the software can not set defaults. Also I can not read Phone info with this cable. Maybe it is a different cable? I need to create ASK for this phone but with this cable I cannot do it. What modifications can I do to this cable so that I can make ASK for the phone? I tried to read ASK via USB but it is impossible. Thanks in advance |
10-13-2007, 16:45 | #8 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: NA & CN
Member: 99013 Status: Offline Thanks Meter: 52 | Quote:
1 Downgrade to any version lower than 5.61 or 5.60 via Fbus. 2.Flash to rm-133 v5.61 should help.Donnot flash to rm-115... Br Gsmdoctorca | |
rm-490 dead after flash with rm-394 | Mind Power | HWK | 4 | 05-04-2009 06:37 |
N95 8gb RM-321 dead after flash RM-320 | FedorovV | Nokia Base Band 5 ( BB-5 ) | 2 | 10-13-2008 01:10 |
