6500c Pinout needed Hi, I have a JAF Cable and modified it into UFS3 Cable with changing RX2 Cable to VPP. But MTBOX will not read it even if the Cable is connected to RX2. What am i doing wrong? What is the right Pinout? I saw in the Sticky the Pinouts but only Picture.. Error Make sure that phone is connected. VPP is DISABLED. BB5 PM back Phone is in: Phone is not responding! Processing File: rm265__04.80.mcusw Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. VPP is DISABLED. BB5 PM back Phone is in: Phone is not responding! Processing File: rm265__04.80.mcusw Boot... FAILED TO BOOT PHONE!!! Regards |
No one can help me?? |
mate please 1st read HERE! After that make search or go to section cable modffication. |
Search button.. Good idea! You should take a look also http:///vbb/search...rchid=29107338 All was found is this http:///vbb/showpo...4&postcount=16 Need help! |
Mate,do you have a 3250 cable??? If your 3250 cable is ready and working, just open your cable or from the battery pins, extend them to your 6500c battery pins.Just remember the BSI and the Negative pin.dont mixed them. Now observe well, the battery pins from your 3250 cable will be facing the down side of the 6500c.Ajuste the 7 pins of the cable to the seven pins from the phone.Et voila tu es la. Report. Tested 4 times so far. 100% |
Ok thanks.. Will try Could this be cause 7.5k on 6500c? 3250 = 5.1k on JAF and at UFS3 = 3.3k |
I always use 5.1 or 5.2k No problem at all. |
After changing 3 times all Pinout still the same Problem.. I try it with the 3250 way.. nothing... Now the cable has this situation... http://img176.imageshack.us/img176/8705/6500c2md0.jpg 5.1k and 68k resistors are on cable.. When i put cable on Phone the Lights are going on.. Result Selected Highest installed version: 04.80 VPP is DISABLED. BB5 PM back Phone is in: Phone is not responding! Processing File: rm265__04.80.mcusw Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. |
Need some help please... Phone is still damaged.. |
Yes He Will Stay Damaged! I Dont See Connected Tx2 Line Mate!!! Again Need To Use Search Button!! |
Pin2 (Gray) must go to RXD on 6500c or to other Point?? |
Is it normal on this Phone that the lights are going on when the Cable is connected?? |
TX2 Line is connected to RXD2.. If i put the cable into Phone Lights are going on and this is result Selected Highest installed version: 04.80 VPP is DISABLED. Using Tx2 Data line. BB5 PM back Phone is in: Phone is not responding! Processing File: rm265__04.80.mcusw Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. Using Tx2 Data line. BB5 PM back Phone is in: Phone is not responding! Processing File: rm265__04.80.mcusw Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. Using Tx2 Data line. BB5 PM back Phone is in: Phone is not responding! Processing File: rm265__04.80.mcusw Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. What am i still doing wrong? |
People i am going to be crazy.. I have connected TX2 Line (Pin2) from MTBOX to MTBOX Adapters VPP.. Nothing I have connected TX2 Line (Pin2) directly to RXD2 on Cable... Nothing |
