Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > Griffin Products > MT-BOX
Old 12-18-2007, 11:07   #1 (permalink)
Member: 642314
Sonork: 100.86843
6500c Pinout needed
Hi,
I have a JAF Cable and modified it into UFS3 Cable with changing RX2 Cable to VPP.
But MTBOX will not read it even if the Cable is connected to RX2.
What am i doing wrong? What is the right Pinout? I saw in the Sticky the Pinouts but only Picture..
Error
Make sure that phone is connected.
VPP is DISABLED.
BB5 PM back Phone is in: Phone is not responding!
Processing File: rm265__04.80.mcusw
Boot...
FAILED TO BOOT PHONE!!!
VPP is DISABLED.
Boot...
Regards
The Following User Says Thank You to htcode For This Useful Post:
Old 12-18-2007, 11:49   #2 (permalink)
Member: 642314
Sonork: 100.86843
No one can help me??
Old 12-18-2007, 14:22   #3 (permalink)
911GT's Avatar
Member: 409197
mate please 1st read HERE!
After that make search or go to section cable modffication.
Old 12-18-2007, 14:37   #4 (permalink)
Member: 642314
Sonork: 100.86843
Search button.. Good idea! You should take a look also
http:///vbb/search...rchid=29107338
All was found is this
http:///vbb/showpo...4&postcount=16
Need help!
Old 12-18-2007, 14:48   #5 (permalink)
blaiseid's Avatar
Member: 37735
Originally Posted by htcode View Post
Hi,
Error
VPP is DISABLED.
Boot...
VPP is DISABLED.
Boot...
Regards
Mate,do you have a 3250 cable???
If your 3250 cable is ready and working, just open your cable or from the battery pins, extend them to your 6500c battery pins.Just remember the BSI and the Negative pin.dont mixed them.
Now observe well, the battery pins from your 3250 cable will be facing the down side of the 6500c.Ajuste the 7 pins of the cable to the seven pins from the phone.Et voila tu es la.
Report.
Tested 4 times so far.
100%
Old 12-18-2007, 15:02   #6 (permalink)
Member: 642314
Sonork: 100.86843
Ok thanks.. Will try
Could this be cause 7.5k on 6500c?
3250 = 5.1k on JAF and at UFS3 = 3.3k
Old 12-18-2007, 15:11   #7 (permalink)
Member: 642314
Sonork: 100.86843
the picture
The Following 4 Users Say Thank You to htcode For This Useful Post:
Old 12-18-2007, 17:46   #8 (permalink)
blaiseid's Avatar
Member: 37735
I always use 5.1 or 5.2k
No problem at all.
The Following User Says Thank You to blaiseid For This Useful Post:
Old 12-18-2007, 18:35   #9 (permalink)
Member: 642314
Sonork: 100.86843
After changing 3 times all Pinout still the same Problem..
I try it with the 3250 way.. nothing...
Now the cable has this situation...
5.1k and 68k resistors are on cable.. When i put cable on Phone the Lights are going on..
Result
Selected Highest installed version: 04.80
VPP is DISABLED.
Boot...
Old 12-19-2007, 00:05   #10 (permalink)
Member: 642314
Sonork: 100.86843
Need some help please... Phone is still damaged..
Old 12-19-2007, 14:56   #11 (permalink)
911GT's Avatar
Member: 409197
Yes He Will Stay Damaged! I Dont See Connected Tx2 Line Mate!!!
Again Need To Use Search Button!!
The Following User Says Thank You to 911GT For This Useful Post:
Old 12-22-2007, 03:27   #12 (permalink)
Member: 642314
Sonork: 100.86843
Pin2 (Gray) must go to RXD on 6500c or to other Point??
Old 12-22-2007, 04:29   #13 (permalink)
Member: 642314
Sonork: 100.86843
Is it normal on this Phone that the lights are going on when the Cable is connected??
Old 12-22-2007, 04:45   #14 (permalink)
Member: 642314
Sonork: 100.86843
TX2 Line is connected to RXD2.. If i put the cable into Phone Lights are going on and this is result
VPP is DISABLED.
Using Tx2 Data line.
Boot...
Boot...
Boot...
What am i still doing wrong?
Old 12-22-2007, 05:01   #15 (permalink)
Member: 642314
Sonork: 100.86843
People i am going to be crazy..
I have connected TX2 Line (Pin2) from MTBOX to MTBOX Adapters VPP.. Nothing
I have connected TX2 Line (Pin2) directly to RXD2 on Cable... Nothing
6500c pinouts?? saidgoren Chinese Miracle & PinFinder 3 11-07-2008 13:58
>>> 6500c pinout neeeeeeeeeeeed help<<<< elaraby_Teem Chinese Miracle & PinFinder 4 04-21-2008 09:29
6500c pinout help elaraby_Teem SpiderMan 0 04-17-2008 13:05
Looking 6500c pinout Gsm-W MT-BOX 1 11-19-2007 18:04
Page generated in 1.34382 seconds with 11 queries
