02-27-2006, 18:00 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | why MT-BOX do not show flash ID for example UFS show flash ID when flashing like "K8S6415ETA" here is result of screen MT-BOX, there is not any this info. MT-BOX team hope you will see that: Processing File: Boot... ASIC ID: 2142 DCT4 u_2nd.fia u_st_i.fia Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 8826 0000 7121, 10 02000000: Unkown, 0090 0000 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[16.00 MB]... erasing region [01000000 to 0100FFFF] erasing region [01010000 to 017FFFFF] one more : I had 15 credit of Sony Ericsson when I bought MT-BOX, but I flashed 2 C62 and now my credits remined 1, becasue the screen of software was freezing and I had to rstart the software. each time restarted and lost credits. Now! MT-BOX team! is that fair to use 14 credit for only 2 C62?, if you say yes?, then I will not say anything.This just my critization about MT-BOX. Best regards. |
02-27-2006, 18:15 | #2 (permalink) | |
Member deceased !! Join Date: Mar 2002 Location: www.griffinteam.net Age: 54
Member: 10248 Status: Offline Thanks Meter: 25 | Quote:
this is your flash ID 01000000: SGS, 0020 8826 0000 7121, 10 for what you need to know what flash IC have this ID ? if really you need to know i will tel you how to find out BR GT | |
02-27-2006, 18:53 | #3 (permalink) | |
Member: 55026 Status: Offline Thanks Meter: 53 | Quote:
For example: one time I got one 6600, as you know there is 4 flashes, but the phone was white display. I know this is a logical problem, and I know Griffin is a powerfull flasher, I erased and flashed many times with griffin no result, then when flashed with ufs I saw there is blank 2 flash IDs of the phone, then I see that 1 st and 3 th flashes are not working (flash adresses can show us what flash chip is not working), after changed only those flashes everything good, without calculating RPL, because there is IMEI only in second flash. I can tell you many resons like that. we need flash ID by order.Dear Andro, after you builded that qualification on MT-BOX it will be more powerfull. Believe me! Regards | |
02-27-2006, 19:06 | #4 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Agree with you, brother Kubat1. Flash ID also flash address is necessary to be displayed. Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 267E 0002 0110, 10 <-- please add flash address info 02000000: Amd, 0001 267E 0002 0110, 10 <-- please add flash address info 04000000: Amd, 0001 267E 0002 0110, 10 <-- please add flash address info 06000000: Amd, 0001 267E 0002 0110, 10 <-- please add flash address info Best Regards |
02-27-2006, 19:31 | #5 (permalink) | |
really this info is not clear for you ?? first your phone have 4 identical flash chips AMD 1 flash 00000000: Amd, 0001 267E 0002 0110, 10 address info is from 00000000 to 02000000 2 flash from 02000000 to 04000000 and ... so what is not clear flash address info is on first place BR GT | |
02-27-2006, 19:55 | #6 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Yes sir, thats clear. But we need more specific address. Start and end. So when we use custom erase feature, we can erase it correctly. eg: Custom erase can do erase 02000000 to FFFFFFFF, but it takes too much time. Also actually there is out of chip address. Even if we select FFFFFFFFxxxx, it still processig erase for those address. But, yes, this undefined end address erase (commanded manually) is realy awesome. Powerful. We can thread this just like "format flash". Blank out the flash totally, nothing left. I like this feature. (watch out - ??????????????, backup first) Just need more specific start and end adress. Thanks Last edited by gbluez; 03-07-2006 at 19:43. |
02-28-2006, 05:58 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | like this one 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ET Fl1: 0x02000000-0x02FFFFFF,00EC22F8,Sam K8S2815ET Fl2: 0x04000000-0x047FFFFF,00EC22FA,Sam K8S6415ET |
03-05-2006, 16:35 | #10 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | yes is better to see 3 parameters like this 1) 0x00000000-0x00FFFFFF start-end adress 2) Sam K8S2815ET manufacturer/type 3) (16MB) size i think all this info is usable for us....... |
03-08-2006, 07:44 | #12 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Olympia
Member: 44950 Status: Offline Thanks Meter: 10 | yes showing the flash id and addresses helps a lot in diagnosting the phone if its software or hardware failure. its a big help for every mtbox user. hope andro consider this topic in developing the mt box capabilities. |
1200 Flashing but Local do not Show Please help | pradipbarua | Nokia Hardware & Hardware Repair | 3 | 10-06-2009 11:16 |
ub flash do not show incoming r outgoing numbers | talatmehmood | Universalbox | 2 | 10-17-2007 17:10 |
mt-box unlock sever show error message ''unable to locate MT-Box interfact'' | kaholukkk | MT-BOX | 5 | 01-16-2007 14:54 |
Why MT-BOX can not patch IMEI? | KUBAT1 | MT-BOX | 4 | 12-27-2006 19:02 |
Just a simple question: Why the producer of tornado boxes do not support customers? | Raskal | UFS2 + UFS3-Tornadoflasher | 17 | 09-07-2004 11:46 |
