01-30-2007, 11:03 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | 6680 do not accept any sim card, after chang the rap3g cpu in nokia 6680 from nokia 6630 the phone did not accept any sim card, Phone is in: RF Innactive mode Model: RM-36 ( RM-36) V 04wk47v35.1/14-04-05/RM-36 (c) Nokia. Production serial number SEH726623 Product code 0523766 Module code Basic production code 0516030 Flash code Order number Long production SN MCU SW V 04wk47v35.1/14-04-05/RM-36/(c) Nokia. HW 6010 PCI RFIC 150a160e DSP 04w47v18 Retu 32 Tahvo 41 IMEI: 354349007669073 WARNING: VPP pin is not connected, disabling VPP. V 04wk47v35.1/14-04-05/RM-36 (c) Nokia. IMEI: 354349007669073 Operator: FFFFFFFFFFFFFFFF Profile bits: FFFFFFFFFFFFFFFF Closed on GID1: 00101F self test Phone SelfTest status: Passed: TAHVOINT Passed: UEM_CBUS_IF Passed: EAR_DATA_LOOP Passed: SIM_CLK_LOOP Passed: SIM_IO_CTRL_LOOP Passed: BACKUP_BATT Passed: SLEEPCLK_FREQ Passed: SIM_LOCK Passed: SECURITY Passed: PWR_KEY Passed: CURRENT_CONS Passed: CMT_APE_WAKEUP NotExecuted: HOOKINT NotExecuted: BTEMP NotExecuted: CDSP_RF_BB_IF NotExecuted: CDSP_RF_SUPPLY NotExecuted: CDSP_TX_IQ NotExecuted: CDSP_TXC_DATA NotExecuted: CDSP_WCDMA_TX_POWER NotExecuted: CDSP_RX_PLL_PHASE_LOCK NotExecuted: CDSP_TX_PLL_PHASE_LOCK NotExecuted: CDSP_RX_IQ_LOOP_BACK NotExecuted: CDSP_PWR_DETECTOR_BIAS NotExecuted: CDSP_GSM_TX_POWER Summary: Passed(12), NotExucuted(12), OtherStatus(0) pls help |
01-30-2007, 11:23 | #2 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | write back 134(308) field, restart phone,check simlock state, if is ok then authorize phone with sx4 buton and write back 1 and 135(309) field PLEASE PEOPLE FIRST READ IN FORUM THEN QUEST THIS PROBLEM HAVE A 10 or more post i forum use SEARCH option |
02-02-2007, 13:34 | #4 (permalink) | |
Member: 39208 Status: Offline Thanks Meter: 152 | Quote:
BR BYTE | |
02-02-2007, 20:17 | #7 (permalink) | |
I do not understand , pls explain it more clear ..!!!m Does bb5 rpl will solve the sim lock in my case? I changed the rap3g ic and before i change it i backup the imei, after restore the imei, the phone become "start up failed , contact the retailer" , i write a pm file using sx1 emulator, now the phone works fine but does not accept any sim card .....!!! that's my story ..... pls help me BR BYTE | |
02-03-2007, 01:05 | #8 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Olympia
Member: 44950 Status: Offline Thanks Meter: 10 | Yes bb5 rpl will solve your problem if the problem is really isolated in rap3g. but if the case is somewhere in the simcard reader or filter then bb5 rpl will not help you. in your case, you change the rap3g so the bb5 rpl must use... |
ku990 unlock faild, and now do not accept any sim card | lifeng1205 | VygisToolbox | 1 | 11-09-2008 14:26 |
6680 dead .NOT ACCEPT ANY SIM CARD | endrinait | Nokia Base Band 5 ( BB-5 ) | 4 | 09-26-2007 00:04 |
6680 dead dont accept any sim card | endrinait | Nokia Base Band 5 ( BB-5 ) | 3 | 09-06-2007 19:34 |
BG3 (332) alcatel do not accepts any sim | !mendoza! | BF, BG, TH, BHx Series | 10 | 10-06-2004 14:39 |
N500 do not accept all Sim Card | kostin | VLSI, Conexant, Skyworks and Old Models | 0 | 06-03-2003 17:59 |
