01-15-2008, 16:09 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | 6680 phone stat-up failed after rpl trying to write rpl APE ADSP SW 52041 IMEI: 357617006929251 WARNING: VPP pin is not connected, disabling VPP. IMEI: 357617006929251 SKIPPED Certificate sent ============= Set FBus mode for info ============= VBat is 3.91V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-36 ( 6680) V 04wk47_m_v14/09-02-06/RM-36 (c) Nokia. IMEI: 357617006929251 Simlock send - SUCCESSFULL!!! SuperDongle send - SUCCESSFULL!!! but phone show startup failed |
01-16-2008, 11:40 | #3 (permalink) |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | and what 's your job ? u are a product supporter or not ?? i used solution to write pm after writing rpl and got the same problem |
01-16-2008, 12:55 | #4 (permalink) |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | Connect... Login... IMEI: 357617006929251 busy, waiting... Connect... Login... busy, waiting... PMM Authorize SUCCESSFULL Sending to phone Resource: 01 Sending to phone Resource: 02 Sending to phone Resource: 04 Sending to phone Resource: 08 Sending to phone Resource: 0B Sending to phone Resource: 11 Sending to phone Resource: 19 Sending to phone Resource: 1A Sending to phone Resource: 1B Sending to phone Resource: 1D Sending to phone Resource: 23 Sending to phone Resource: 2B Sending to phone Resource: 2C Sending to phone Resource: 32 Sending to phone Resource: 36 Sending to phone Resource: 58 Sending to phone Resource: 5C Sending to phone Resource: 5E Sending to phone Resource: 5F Sending to phone Resource: 60 Sending to phone Resource: 75 Sending to phone Resource: 76 Sending to phone Resource: C1 Sending to phone Resource: D4 Sending to phone Resource: D9 Sending to phone Resource: EF Sending to phone Resource: F6 Sending to phone Resource: F7 Sending to phone Resource: F8 Sending to phone Resource: F9 Sending to phone Resource:133 Sending to phone Resource:135 V 04wk47_m_v14/09-02-06/RM-36 (c) Nokia. IMEI: 357617006929251 Failed to Read Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_format.fg BOOT OK... CMT Send NPC Certificate Phone Type: BB5 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.88V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Unknown mode Model: RM-36 ( 6680) V 04wk47_m_v14/09-02-06/RM-36 (c) Nokia. IMEI: 357617006929251 Simlock send - SUCCESSFULL!!! SuperDongle send - SUCCESSFULL!!! V 04wk47_m_v14/09-02-06/RM-36 (c) Nokia. IMEI: 357617006929251 Operator: 2080100000000000 Profile bits: 0000000000000000 Closed on GID1: 20801F Closed on Mcc Mnc: 20801F Counters 0/10, 0/3 |
01-16-2008, 14:35 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | Quote:
i dont have another solution for you try erase full write rpl and pm 1,135 , sorry but i dont have another idea | |
01-16-2008, 16:57 | #8 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | no,mate need to read only : http:///vbb/showpo...9&postcount=32 |
6680 6680 phone star up failed contact the retailer | anvaranvar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 04-24-2010 03:32 |
N80 N73 Phone Start UP Failed After RPL Solution | delower10 | Nokia Base Band 5 ( BB-5 ) | 13 | 11-13-2009 12:34 |
N73 phone staru up failed after write rpl from server | M-taheri | Nokia Base Band 5 ( BB-5 ) | 7 | 04-29-2009 19:06 |
n73 phone start up failed after after write rpl | unlock & flash | Nokia Base Band 5 ( BB-5 ) | 3 | 09-16-2008 21:58 |
