Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 12-07-2011, 09:36   #1 (permalink)
Member: 37668
Thanks Meter: 15
Problem with N97 RM-507
The phone was fully working. I tried to flash it with HTI-box, but the phone became dead.
Now I'm trying to repair it with MT-Box. The PCB is in good condition, without any damage.
Here is the FBUS log:
Selected Highest installed version: 22.2.110
Mcu	RM-507_22.2.110_prd.core.C00
Ppm	RM-507_22.2.110_prd.rofs2.V28
Ppm	RM-507_22.2.110_C01_prd.rofs3.fpsx
Content	RM505_507_22.0.110_uda_9_001.uda.fpsx
Content	RM505_APE_ONLY_ENO_09w23_v0.072.fpsx
MemoryCardContent
	RM505_RM507_101_000_M021_32G.fpsx
                    Using Tx2 Data line.
BB5 PM back Phone is in: Phone is not responding!
Processing File:  RM-507_22.2.110_prd.core.C00
Boot...
RAPIDOv11_2nd.fg
FAILED TO RECEIVE DEVICE CONFIGURATION!
Can't find CMT Loader
%%%%%%%% ERROR BOOTING:
Here is the dead USB log:
Switched to USB BUS
Boot...
CONNECT PHONE to USB and Power ON phone!
Pooling for phone...
\\?\nmwcd#vid_0421&pid_0106&if_oth#6&77ca5e2&1&00#{4f919102-4adf-11d5-882d-00b0d02fe381}
Sending ULO code
Isa UPDAPP
RAP3NAND
PASUBTOC
UPDAPP
Pooling for device removal...
Device removed
Pooling for ADL device...
\\?\nmwcd#vid_0421&pid_0105&if_oth#6&1b06a9af&1&00#{4f919102-4adf-11d5-882d-00b0d02fe381}
CMT Certificates
NOT SUPPORTED
Erase[296.87 MB]...
erasing APE [00040000 to 00082FFF]
erasing APE [00083400 to 003FFFFF]
erasing APE [00800000 to 00D5FFFF]
erasing APE [00D60000 to 0AB9FFFF]
erasing APE [0ABA0000 to 0F71FFFF]
erasing APE [079A0000 to 09C9FFFF]
erasing APE [09CA0000 to 0AB9FFFF]
erasing APE [00400000 to 007FFFFF]
in 11.64s
Flash[106.34 MB]...in 41.69s
* * Processed file in 72.88 seconds
Processing File:  RM505_507_22.0.110_uda_9_001.uda.fpsx
Boot...
Erase[0.00 MB]...
in 0.13s
Flash[8.79 MB]...in 3.38s
* * Processed file in 3.63 seconds
Processing File:  RM-507_22.2.110_prd.rofs2.V28
Boot...
Erase[0.00 MB]...
in 0.31s
Flash[23.86 MB]...in 8.91s
* * Processed file in 9.34 seconds
Processing File:  RM-507_22.2.110_C01_prd.rofs3.fpsx
Boot...
Erase[0.00 MB]...
in 0.00s
Flash[0.01 MB]...in 0.03s
* * Processed file in 0.16 seconds
Processing File:  RM505_APE_ONLY_ENO_09w23_v0.072.fpsx
Boot...
Erase[0.00 MB]...
in 0.05s
Flash[2.75 MB]...in 1.14s
* * Processed file in 1.28 seconds
Restarting device...
Device disconnected.
* * * Phone flashing done in   1:31 minutes
 Post Flash serial tunning of phone....
Pooling mode for full factory set...
	Phone not responding, try to set manually!
Please, tell me if this is software problem !
Thanks in advance,
Ivailo
Old 12-07-2011, 09:45   #2 (permalink)
geraomobeem's Avatar
Member: 1612957
Sonork: 100.1607959
Thanks Meter: 51
flish with laest ver with clykon box
Old 12-07-2011, 14:48   #3 (permalink)
Member: 37668
Thanks Meter: 15
I have tried Cyclone via FBUS but with no success:
Initializing FBUS...
All initialized - Ready to work
Failed to read info -> Phone not detected
Retrieving Variants for Product RM-507 - wait...
3 Variants Retrieved
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing RM-507_22.2.110_prd.core.C00 (CMT)...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006400C192101031103
CMT_EM_ASIC_ID:		00000296
CMT_EM_ASIC_ID:		00000B22
CMT_PUBLIC_ID:		09B00014BBDA01583E709EA1121AF946A62E4C75
CMT_ASIC_MODE_ID:	00
CMT_ROOT_KEY_HASH:	CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC:	4B9B7510
CMT_SECURE_ROM_CRC:	3E691FF8
CMT Ready!
RM-507_22.2.110_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.24.0, Algo: BB5
Flashbus Write baud set to 650Kbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND
Requested Algorithm: XSR 1.5 (CMT)
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.24.0, Algo: XSR 1.5
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B
Flashbus Write baud set to 5.0Mbits
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND
EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND
EraseArea[0,CMT]: 0x00D60000-0x0AB9FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.984s
Writing all blocks...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 121.922s
Flashing Speed: 7316.69 kBit/S
Restarting MCU...
Processing RM-507_22.2.110_prd.core.C00 (APE)...
Processing RM-507_22.2.110_prd.rofs2.V28 (CMT)...
Booting CMT...
CMT Ready!
RM-507_22.2.110_prd.rofs2.V28, Type: Flash Image, Algo: XSR 1.5, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x079A0000-0x09C9FFFF, ONENAND
Erase taken 0.203s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 28.250s
Flashing Speed: 7086.38 kBit/S
Restarting MCU...
Processing RM-507_22.2.110_prd.rofs2.V28 (APE)...
Processing RM-507_22.2.110_C01_prd.rofs3.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-507_22.2.110_C01_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x09CA0000-0x0AB9FFFF, ONENAND
Erase taken 0.93s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 0.93s
Flashing Speed: 793.81 kBit/S
Restarting MCU...
Processing RM-507_22.2.110_C01_prd.rofs3.fpsx (APE)...
Processing RM505_507_22.0.110_uda_9_001.uda.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM505_507_22.0.110_uda_9_001.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x0ABA0000-0x0F71FFFF, ONENAND
Erase taken 0.422s
TurboCache Loaded!
All blocks written OK! Time taken 11.343s
Flashing Speed: 6500.53 kBit/S
Restarting MCU...
Processing RM505_507_22.0.110_uda_9_001.uda.fpsx (APE)...
Processing RM505_APE_ONLY_ENO_09w23_v0.072.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM505_APE_ONLY_ENO_09w23_v0.072.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND
Erase taken 0.32s
TurboCache Loaded!
Writing CMT SOS*ENO Certificate...
All blocks written OK! Time taken 3.297s
Flashing Speed: 6996.25 kBit/S
Restarting MCU...
Processing RM505_APE_ONLY_ENO_09w23_v0.072.fpsx (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
And here cyclone says that phone is not responding.
May be hardware problem ?
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:48
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.17237 seconds with 9 queries
