06-06-2007, 14:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | BB5 MT-box-PRO TP ok but have ERROR- SOLUTION!!!!!!!! TPs OK TESTPOINT FAILED - !!!! BIG LETTER !!! TestPoint Failed - !!!! small letter !!! You need to short GND(black) and DATA(green) on a TP cable 2 times from 20 to 10cm and all will be ok. tested and work 100% Last edited by 911GT; 01-16-2008 at 14:27. |
06-07-2007, 23:16 | #8 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | @neri_21shi Make 308 PM backup Connect all wires to phone Check sim lock state If all is ok press Unlock button Connect and hold CLK to TP first and then connect DATA |
12-10-2007, 14:01 | #11 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 562359 Status: Offline Thanks Meter: 39 | same error !! IMEI: 357603003101797 TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED UNKNOWN ERROR i ve do all thing no chance !! any other solution !!plz! |
12-10-2007, 14:14 | #13 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | mate, CPU IC you dont know! That you see is a FLASH iC who is soldered over mcu. you connect wrong TP may be and dont have another solution.Touch correct TP and short 2 times from 20 to 10cm green TP cable. and to dont forgot! check counters of simlock state |
Bb5 Box Or Mt-box Pro Lite Quick Question ! | PBBGuy | BB5BOX | 36 | 02-07-2008 18:13 |
My Box MT Box Pro Lite with error | edermix | MT-BOX | 3 | 10-30-2007 10:15 |
>> HOT << First on the world present Unlock BB5 MT BOX PRO - 100 CREDITS - ONLY !!! | gsminfo | Main Sales Section | 0 | 06-25-2007 22:57 |
