10-01-2007, 01:58 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 501877 Status: Offline Thanks Meter: 495 | Big problem mtbox lite D 03.81/09-05-06/RM-78/(c) Noki Auto backup SIMLOCK... ================================= bb5bckup\352265011*****.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 352265011*****. Operator: 8000000000000000 Profile bits: 2620100000000000 Closed on Mcc Mnc: 26201F =================================== Using Account: uMTPlite10367 Connect... Resp: o/0110/hello there Login... OK, available count 40; busy, waiting... e/312/Download latest version of MTB_NK software; Server error mt-box v 1_35 eror Phone is in: Normal mode Imei: 352265011*****. !!!!!!BOX ERROR!!!!! Check connector. mt-box v 1_36 eror Phone is in: Normal mode Imei: 352265011*****. !!!!!!BOX ERROR!!!!! mt-box v 1_37 eror Phone is in: Normal mode Imei: 352265011*****. !!!!!!BOX ERROR!!!!! Check connector. mt tool box update ok <App:CR> <Version:01.02.0001> <SN:0023**0001> <Name:0023**0001> Services List: #00<CORE > <Version:02.03.0000> #08<NOK > <Version:02.02.0000> <Activated:556> What is the problem bb5 not unlock plase help |
10-01-2007, 10:22 | #4 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | 1. For unlock have a restrictions of software version! need to be minimum 1.36 will be good to be 1.37 solution: download 1.36 installer after installation extract 1.37.exe in same directory. 2. i see after that you will take a error/401! solution: after step 1 open griffin.ini with notepad and under [interface option] add new row : revision=F warning: "F" is big "F" not a small "f" 3. BOX ERROR solution: clean good 2 connectors between 2 boxes and press it for good connection, also check THIS |
10-01-2007, 11:17 | #5 (permalink) | |
Member: 501877 Status: Offline Thanks Meter: 495 | Quote:
connect usb dku2 phone poweron one okşinfo ok pres unlock boxerror | |
10-01-2007, 12:09 | #6 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | this is only because of cheap quality connector used, clean the connector properly and push it hard and better put some pc of paper with rj45 so it will be tight, use it and will be 100% ok WBR Syed |
10-01-2007, 14:23 | #8 (permalink) |
Member: 19979 Status: Offline Thanks Meter: 116 | yes sure, and this is common problem, many of my friends faced this problem and fixed it by inserting some packing like paper in the rj45 connector to tighten the cable, 90% of the time i wont work for me if i just plug in the cable and my pin 1 and 10 are perfect WBR Syed |
10-05-2007, 07:31 | #12 (permalink) |
Junior Member Join Date: Sep 2004 Age: 51
Member: 81577 Status: Offline Thanks Meter: 0 | WHEN I PUSH PHONE INFO BUTTON IT S OK BUT WHEN I PUSH SIMLOCK STATE THE MESSAGE IS FAILED TO READ !!!!! i cant make unlock i have thi message: V 03.92/13-10-06/RM-174 (c) Nokia. IMEI: 35273101XXXXXX6 Failed to Read Simlock structure error -1 Simlock not initialized, can't continue! |
10-05-2007, 07:44 | #13 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: POLAND Age: 43
Member: 82759 Status: Offline Thanks Meter: 153 | Quote:
10-05-2007, 09:40 | #14 (permalink) | |
Member: 409197 Status: Offline Thanks Meter: 75 | Quote:
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
6085 big problem | kami1987 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 13:42 |
Big Problem with MTBOX lite doesnt unlock | Carlazos | MT-BOX | 3 | 01-27-2008 18:12 |
