11-20-2005, 18:35 | #2 (permalink) |
Product Manager Join Date: Oct 2004 Age: 44
Member: 85757 Status: Offline Sonork: 100.1581882 Thanks Meter: 23 | Hi This Error 0002 error battery You need battery full charge http://www.gti-forum.com/forum/ Br Wawe |
11-22-2005, 10:21 | #7 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Dubai Age: 43
Member: 80370 Status: Offline Thanks Meter: 3 | i have same error with k300i iit was cid 36 and after unlock cid 24 when i try to flash it this masseage appear Starting the phone... PID:80 00 03 01 FF FF FF FF Sending Loader1... Loader1 sent. IMEI:357xxxxxxxxxx CID:0024 PAF:01 Sending loader2 error:0002 and when press ??? button Starting the phone... PID:80 00 03 01 FF FF FF FF KEY:A1_DB2010_36_BROWN IMEI:357xxxxxxxxx CID:0024 PAF:01 br beka |
11-22-2005, 11:11 | #9 (permalink) |
Member: 80370 Status: Offline Thanks Meter: 3 | HI I READ AGAIN THE Sticky: MT-box NEW ARM inside quick tutorial AND I SEE THAT THE TRICK IS U MUST RPAIER THE PHONE WITH Recovery AND WHEN U TRY TO FLASH IT IT WILL FLASH WITHOUT ANY EPROPLEM THNX ALOT TO ANDRO AND HIS TEAM AND SPICIALY FOR SoftMobile I HOPE IT SOLVE U R PROPLEM @ ddhorn BR BEKA |
11-22-2005, 11:36 | #10 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Starting the phone... PID:80 00 03 01 FF FF FF FF KEY:A1_DB2010_36_BROWN IMEI:357xxxxxxxxx CID:0024 PAF:01 The KEY in our phone is BROWN (f*****d before connected to MT box) How to convert it back: Some phone models can be converted with just one click to UNLOCK button. For some phone models is required flash recovery file (*.rep), then flash MCU and DEC file. To UNLOCK conversion be sucessfull you must select right phone model. How to select phone model: Click to ??? button and read from software window what is the CID in your phone: CID: 0024 Select K300 CID 24 and press UNLOCK Click again to ??? button and see it is KEY:A1_DB2010_36_RED or not. If KEY is BROWN then flash *rep file to phone, after this flash MCU and DEC file. |
11-22-2005, 17:24 | #11 (permalink) |
Member: 80370 Status: Offline Thanks Meter: 3 | thnx man but i have j 300 cid 36 what can i do for unlock i unlock it normaly and when i try to input code to phone all i see it unlock but same masseage if i try to flash it like k300 using FLASH FILE FOR J300 br beka |
Can't flash NEC 338 | angel25dz | NEC | 0 | 03-29-2010 12:25 |
k750 phone dead n can't flash | davi yong | Sony Ericsson Hardware Repair | 1 | 05-03-2007 15:29 |
k750 can't flash with mt-box | lhakkaoui | MT-BOX | 2 | 11-15-2006 14:12 |
K750 Can't Flash | Ian | HWK | 7 | 09-23-2005 13:28 |
