05-04-2007, 15:30 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 48
Member: 101827 Status: Offline Thanks Meter: 23 | cant remove security code in 5200 Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! but after powering on it asks for security code again cant set factory defaults also help me out mt-box team thanx |
05-04-2007, 15:49 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | For thr 1000th time.Used modified cable so that ur phone would go to local\test mode in which u can do all factory settings and reset user code. |
05-04-2007, 17:05 | #3 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | Mate! @meisam If you connect your phone with cable and you phone get local mode or test mode then only press fulfactory. Or not then check you cable may be you cable resistance low kb change with 5.1 kb or 7.5 kb. |
Cant remove security code from ku990 viewty | shaheen15 | VygisToolbox | 2 | 03-25-2009 17:09 |
to remove security code in motorola v1050 | ToP DawG | Smart-Clip | 3 | 06-10-2006 21:19 |
WinDLS PPM MCU box, now removes Security Code in DCT4 8310 and more !!!! | sixkiller666 | Main Sales Section | 8 | 01-11-2002 19:18 |
