10-03-2007, 17:27 | #1 (permalink) |
Junior Member Join Date: Jan 2006
Member: 227318 Status: Offline Thanks Meter: 1 | CANT write pm to 6131 (even field 134) PMM Send File Warning: Failed to write 134:0000, 1bytes. Use SX4 button to authorize Sending SIMLOCK record... Warning: Failed to write 134:0001, 8192bytes. Use SX4 button to authorize Warning: Failed to write 134:0003, 1bytes. Use SX4 button to authorize Warning: Failed to write 134:0004, 1bytes. Use SX4 button to authorize Warning: Failed to write 134:0005, 10bytes. Use SX4 button to authorize Warning: Failed to write 134:0006, 1bytes. Use SX4 button to authorize Warning: Failed to write 134:0007, 1bytes. Use SX4 button to authorize Warning: Failed to write 134:0008, 1bytes. Use SX4 button to authorize Warning: Failed to write 134:0009, 40bytes. Use SX4 button to authorize Operation Completed When I try to authorise: Failed to locate SX4 on PC. Connecting server Connect... Login... e/400/command execution error; Server error How to write PM to almost death bb5? |
10-04-2007, 10:27 | #3 (permalink) |
Member: 227318 Status: Offline Thanks Meter: 1 | What to do, when it is impossible for phone to be in local mode due to bad pm area? Flashing all does not help, its still blinking after power up. How to wripe pm in that case? |
12-24-2007, 11:16 | #6 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Inside Your Mind Age: 38
Member: 97899 Status: Offline Thanks Meter: 46 | I have same problem........need to write PM sections 1,309 because the phone was with damaged SP Area, I recalculate RPL, but when cofirm to start phone without SIM it goes to Contact Service............my problem i the same: Failed to locate SX4 on PC. Connecting server Connect... Login... e/400/command execution error; Server error Any ideas from Mt supporters?!? BR TheBrain |
01-03-2008, 10:23 | #8 (permalink) |
Member: 97899 Status: Offline Thanks Meter: 46 | Yes I found the way! But so many tries you need to get success on authorization, but once you get it just press write pm and all is OK! BR TheBrain |
MT cant write PM with SX4 !! but MX-Key succesfully write PM with SX4 !!! | reaz.com | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 07-18-2009 05:37 |
Cant write PM in 6021 | SVH | MT-BOX | 5 | 09-18-2007 11:07 |
Why cant Write Pm on N70 | yousaf22us | Nokia Base Band 5 ( BB-5 ) | 1 | 05-23-2007 09:15 |
