## BE CareFull in using NEw version for MT box MTB NK 1.57.1.exe To all my friends pls be carefull to run new version from mt-box MTB NK 1.57.1.exe after using this version for unlocking phone goes into contact service. U need rpl to solved this problem. so pls care all necessary backup before doing anything. So here request to Great Griffin Team to Check this Bug. regards! Roopesh ved |
could u post logs which mobile griffin put into contact service and only urs |
sorry i am using 1.57 not 1.57.1 will make backup before using this version thanx for ur info |
Phone is in: Local mode Model: RM-240 (RM-240) V 08.30/03-07-08/RM-240 (c) Nokia Production serial number KUA027256 Product code 0556236 Module code 0203327 Basic production code 0543753 Flash code Order number Long production SN 0 MCU SW V 08.30/03-07-08/RM-240/(c) Nokia HW 2000 PCI RFIC 17141715 DSP ICPR71_08w22 LCD SHARP PPM V 08.30/03-07-08/RM-240/(c) Nokia /O Retu 15 Tahvo 22 Content Pack Content: ora_uk_v2/V 08.30/03-07-08/RM-240/(c) Nokia // IMEI: 353076029xxxxx WARNING: VPP pin is not connected, disabling VPP. 3530760290xxxxx V 08.30/03-07-08/RM-240 (c) Nokia IMEI: 3530760290xxxxx Operator: 8000000000000000 Profile bits: 2343300000000000 Closed on Mcc Mnc: 23433F Closed on Mcc Mnc: 23486F Backup simlock Backup SIMLOCK: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\3530760290xxxxx_n.pm 3530760290xxxxx Booting Phone... Searching loader rap3gv3_2nd.fg Operation SUCCESSFULL C:\Program Files\GriffinTeam\MT-Box\bb5bckup\last.pm Delay 5 seconds ... Phone is in: Local mode Imei: 3530760290xxxxx Send Eeprom 308:1 RestartPhone V 08.30/03-07-08/RM-240 (c) Nokia IMEI: Failed to Read #pw+038324295862212+7# Sending code to phone 3530760290xxxxx SIMLOCK NOT INITIALIZED! (empty board/no simlock record) Finished in 25s After that, I have CS. |
does it matter on the version of the fones or doing it to all versions i knw that if u try new version like v58 its rpl |
so i think best to just continue using 1.57 what do u say? |
Regards! Roopesh Ved |
this is a hardware matching problem with ur box use mprog and flash it good ept download from service and connect it again now it will fully support br |
that was a good info bro................ |
Saifali u are write ur solution work 100% |
Contact Service only occurs when phone is not in local mode for second stage where pm is wriitten back to phone. To save yourself the headache just make sure phone is fully in locol mode before you start unlock procedure. |
C:\Program Files\GriffinTeam\MT-Box\bb5bckup\3530760290xxxxx_n.pm.. Sometime CS Probelm comes from bad cable....bcoz during unlocking process software READ SIMLOCK Backup ..SO your pm won't readed completly and wrote it... See here ... Quote:
