Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 03-07-2009, 18:55   #1 (permalink)
roopesh_500's Avatar
Member: 100579
Sonork: 100.1578318
Thanks Meter: 106
## BE CareFull in using NEw version for MT box MTB NK 1.57.1.exe
To all my friends pls be carefull to run new version from mt-box MTB NK 1.57.1.exe
after using this version for unlocking phone goes into contact service.
U need rpl to solved this problem. so pls care all necessary backup before doing anything.
So here request to Great Griffin Team to Check this Bug.
regards!
Roopesh ved
The Following 12 Users Say Thank You to roopesh_500 For This Useful Post:
Old 03-07-2009, 19:26   #2 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,972
regards!
Roopesh ved
could u post logs
which mobile griffin put into contact service
and only urs
Old 03-07-2009, 19:32   #3 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 964
regards!
Roopesh ved
good to make full pm backup before unlock.... in some phones error in calculate 120 area in pm and phone show contact service
Old 03-07-2009, 19:32   #4 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,972
sorry
i am using 1.57
not 1.57.1
will make backup before using this version
thanx for ur info
Old 03-07-2009, 19:35   #5 (permalink)
Member: 23661
Thanks Meter: 29
Phone is in: Local mode
Model: RM-240 (RM-240)
V 08.30/03-07-08/RM-240 (c) Nokia
Production serial number KUA027256
Product code 0556236
Module code 0203327
Basic production code 0543753
Flash code
Order number
Long production SN 0
MCU SW V 08.30/03-07-08/RM-240/(c) Nokia
HW 2000
PCI
RFIC 17141715
DSP ICPR71_08w22
LCD SHARP
PPM V 08.30/03-07-08/RM-240/(c) Nokia /O
Retu 15
Tahvo 22
Content Pack Content: ora_uk_v2/V 08.30/03-07-08/RM-240/(c) Nokia //
IMEI: 353076029xxxxx
WARNING: VPP pin is not connected, disabling VPP.
3530760290xxxxx
IMEI: 3530760290xxxxx
Operator: 8000000000000000
Profile bits: 2343300000000000
Closed on Mcc Mnc: 23433F
Closed on Mcc Mnc: 23486F
Backup simlock
Backup SIMLOCK:
C:\Program Files\GriffinTeam\MT-Box\bb5bckup\3530760290xxxxx_n.pm
3530760290xxxxx
Booting Phone...
Searching loader
rap3gv3_2nd.fg
Operation SUCCESSFULL
C:\Program Files\GriffinTeam\MT-Box\bb5bckup\last.pm
Delay 5 seconds ...
Imei: 3530760290xxxxx
Send Eeprom 308:1
RestartPhone
IMEI:
Failed to Read
#pw+038324295862212+7#
Sending code to phone
3530760290xxxxx
SIMLOCK NOT INITIALIZED! (empty board/no simlock record)
Finished in 25s
After that, I have CS.
Old 03-07-2009, 19:35   #6 (permalink)
Member: 756103
Thanks Meter: 52
does it matter on the version of the fones
or doing it to all versions
i knw that if u try new version like v58 its rpl
The Following User Says Thank You to glasgowmobiles For This Useful Post:
Old 03-07-2009, 19:36   #7 (permalink)
Member: 756103
Thanks Meter: 52
so i think best to just continue using 1.57 what do u say?
Old 03-07-2009, 19:42   #8 (permalink)
Member: 100579
Sonork: 100.1578318
Thanks Meter: 106
yes Bro. u r right Use !.57 version only it's better.
Regards!
Roopesh Ved
Old 03-07-2009, 19:53   #9 (permalink)
saifali's Avatar
Member: 772820
Sonork: BE MASTERMIND
Thanks Meter: 123
this is a hardware matching problem with ur box use mprog and flash it good ept download from service and connect it again now it will fully support br
Old 03-07-2009, 19:54   #10 (permalink)
saifali's Avatar
Member: 772820
Thanks Meter: 123
regards!
Roopesh ved
The Following 2 Users Say Thank You to saifali For This Useful Post:
Old 03-07-2009, 19:59   #11 (permalink)
Member: 152547
Sonork: 100.1586021
Thanks Meter: 141
that was a good info bro................
Old 03-07-2009, 20:08   #12 (permalink)
Member: 756103
Thanks Meter: 52
Saifali
u are write ur solution work 100%
Old 03-07-2009, 20:21   #13 (permalink)
Member: 43140
Thanks Meter: 10
Contact Service only occurs when phone is not in local mode for second stage where pm is wriitten back to phone. To save yourself the headache just make sure phone is fully in locol mode before you start unlock procedure.
Old 03-07-2009, 20:31   #14 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,572
Module code 0203327
Flash code
Order number
HW 2000
PCI
RFIC 17141715
DSP ICPR71_08w22
LCD SHARP
Retu 15
Tahvo 22
3530760290xxxxx
Backup simlock
Backup SIMLOCK:
3530760290xxxxx
Booting Phone...
Searching loader
rap3gv3_2nd.fg
Delay 5 seconds ...
Send Eeprom 308:1
RestartPhone
IMEI:
Failed to Read
3530760290xxxxx
Finished in 25s
if phone goes to CS..don't worry then simply write backup with sx4
C:\Program Files\GriffinTeam\MT-Box\bb5bckup\3530760290xxxxx_n.pm..
Sometime CS Probelm comes from bad cable....bcoz during unlocking process software READ SIMLOCK Backup ..SO your pm won't readed completly and wrote it...
See here ...
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 03-07-2009, 20:59   #15 (permalink)
Member: 643472
Sonork: 100.96901
Full Video Repair CS For New BB5+
The Following 4 Users Say Thank You to ..::Angel::.. For This Useful Post:
please, when new update for mt-box SE new arm in ide enrikeparis MT-BOX 9 09-15-2007 00:34
bug in new version of mt-box ; plz report here patric MT-BOX 8 07-12-2007 08:40
new user for mt-box with SonyEricsson laythjg09 MT-BOX 2 10-01-2006 08:41
when, release new update for mt-box nokia ekel MT-BOX 0 02-05-2006 17:40
where is new update for MT-box Nokia ekel MT-BOX 5 01-23-2006 20:41
Page generated in 0.46569 seconds with 8 queries
