02-15-2006, 17:10 | #1 (permalink) |
Junior Member Join Date: Feb 2006
Member: 232846 Status: Offline Thanks Meter: 0 | Please Help. New MT box won't work. Please advise.. |
02-15-2006, 18:03 | #2 (permalink) | |
Member deceased !! Join Date: Mar 2002 Location: www.griffinteam.net Age: 54
Member: 10248 Status: Offline Thanks Meter: 25 | Quote:
HI after connect Your MT-box to PC windows XP must recognize new device install drivers and this is all. leds must be OFF BR GT | |
02-15-2006, 18:55 | #3 (permalink) |
Member: 232846 Status: Offline Thanks Meter: 0 | That is the problem, windows xp doesnt recognize the box...and the drivers are installed. I have tried uninstalling and re-installing (which should re-install the drivers) and still no response through the usb from the box.??? Please help!! |
02-15-2006, 19:39 | #4 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 17330 Status: Offline Thanks Meter: 15 | Problem is USB connector Clean the usb connector on the box Try to compress the usb connector, so that it makes proper contact If you can raise the pins, it will help Try and let us know |
02-15-2006, 22:48 | #5 (permalink) |
Member: 232846 Status: Offline Thanks Meter: 0 | Thanks for the suggestion. I tried raising the contacts. The box is brand new so it should have clean contacts. I tried 2 different brand new cables and still no recognition from windows xp. Any other suggestions? Will Griffin warranty the box if its faulty? |
02-15-2006, 22:53 | #6 (permalink) | |
HI if you not using usb hub contact your reseler for replace box BR GT PS any problems whit this send me PM | |
please help My mt box ..SN:BAD SC Answer... | ROEZT | MT-BOX | 2 | 02-21-2010 19:25 |
please help on mt-box SE | alknadir | MT-BOX | 2 | 06-26-2007 14:53 |
softmobile please help me mt-box nokia dead ???? | gadzetxp | MT-BOX | 1 | 10-12-2006 15:28 |
