02-13-2006, 07:30 | #1 (permalink) |
Junior Member Join Date: Feb 2006 Location: In my room with all 6 pc's...
Member: 232316 Status: Offline Thanks Meter: 1 | DCT4 NOKIA 8310 Problem.Please advice me. I have NOKIA 8310 code 0504485.Also,I have MT-BOX (nokia) with latest drivers and updates (1.16).I've tried to update only PPM file to change to language pack B.The phone version vas NHM-7 6.20.I didn't know that is necesary to have same version on PPM.I uploaded PPM file.The process was fine. After that, i open phone and I was seing not all caracters.Only operator logo and some numbers in top right corner.So, I read that MCU has i'ts own PPM.I downgrade the phone to mmc nhm75504.530 and ppm nhm75504.53b : Processing File: nhm75504.530 Boot... ASIC ID: 0120 DCT4 u_2nd.fia u_st_i.fia Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88BE 0000 FF42, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[7.00 MB]... erasing region [01000000 to 0100FFFF] erasing region [01010000 to 0157FFFF] erasing region [01670000 to 017EFFFF] in 82.61s Flash[4.94 MB]...in 30.52s * * Processed file in 118.89 seconds Processing File: nhm75504.53b Boot... ASIC ID: 0120 DCT4 u_2nd.fia u_st_i.fia Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88BE 0000 FF42, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.94 MB]... erasing region [01580000 to 0166FFFF] in 11.91s Flash[0.77 MB]...in 4.78s * * Processed file in 22.42 seconds * * * Phone flashing done in 2:23 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! After that,the phone doesn't work anymore.It doesn't start up and I don't seen Local Mode when I connect it to MT-Box.When I press Phone Info, Phone is in: Phone is not responding, power on phone! (adaptor connected,the steps for connecting,respected) I've tried also Patch File nhm-7_506.20.pff and my IMEI: Processing File: Kn4Btm116.tmp Boot... ASIC ID: 0120 DCT4 u_2nd.fia u_st_i.fia Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88BE 0000 FF42, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.06 MB]... erasing region [012D0000 to 012DFFFF] in 0.97s Flash[0.06 MB]...in 0.45s * * Processed file in 7.50 seconds * * * Phone flashing done in 0: 8 minutes Post Flash serial tunning of phone.... What should I do ? I'm beginner.Thanks in advice. NKV Last edited by NKV; 02-13-2006 at 23:34. Reason: Problem Solved |
02-13-2006, 12:45 | #2 (permalink) |
Member deceased !! Join Date: Mar 2002 Location: www.griffinteam.net Age: 54
Member: 10248 Status: Offline Thanks Meter: 25 | [QUOTE=NKV]Hello sir. I have NOKIA 8310 code 0504485.Also,I have MT-BOX (nokia) with latest drivers and updates (1.16).I've tried to update only PPM file to change to language pack B.The phone version vas NHM-7 6.20.I didn't know that is necesary to have same version on PPM.I uploaded PPM file.The process was fine. After that, i open phone and I was seing not all caracters.Only operator logo and some numbers in top right corner.So, I read that MCU has i'ts own PPM.I downgrade the phone to mmc nhm75504.530 and ppm nhm75504.53b : Processing File: nhm75504.530 Boot... ASIC ID: 0120 DCT4 u_2nd.fia u_st_i.fia Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88BE 0000 FF42, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[7.00 MB]... erasing region [01000000 to 0100FFFF] erasing region [01010000 to 0157FFFF] erasing region [01670000 to 017EFFFF] in 82.61s Flash[4.94 MB]...in 30.52s * * Processed file in 118.89 seconds Processing File: nhm75504.53b Boot... ASIC ID: 0120 DCT4 u_2nd.fia u_st_i.fia Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88BE 0000 FF42, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.94 MB]... erasing region [01580000 to 0166FFFF] in 11.91s Flash[0.77 MB]...in 4.78s * * Processed file in 22.42 seconds * * * Phone flashing done in 2:23 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! After that,the phone doesn't work anymore.It doesn't start up and I don't seen Local Mode when I connect it to MT-Box.When I press Phone Info, Phone is in: Phone is not responding, power on phone! (adaptor connected,the steps for connecting,respected) I've tried also Patch File nhm-7_506.20.pff and my IMEI: Processing File: Kn4Btm116.tmp Boot... ASIC ID: 0120 DCT4 u_2nd.fia u_st_i.fia Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88BE 0000 FF42, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.06 MB]... erasing region [012D0000 to 012DFFFF] in 0.97s Flash[0.06 MB]...in 0.45s * * Processed file in 7.50 seconds * * * Phone flashing done in 0: 8 minutes Post Flash serial tunning of phone.... What should I do ? I'm beginner.Thanks in advice. HI You select wrong files simple write 8310 click on Enter select product code and click flash post flashing log pls BR GT |
02-13-2006, 18:42 | #3 (permalink) |
Member: 232316 Status: Offline Thanks Meter: 1 | 100% Dead NOKIA 8310, revived. You are right sir ! I've instaled last NHM-7_dp_v_15.0_MCUSW6_20.exe ,even that I don't have Phoenix.Then, I connect all the cables, phones and everything.I started Nokia Flash/Repair v1.16 updated.Even that I didn't see Local Mode or something on screen, I was able with my MT-BOX to write the flash files and everything was OK. Now my NOKIA 8310 work perfectly and I'm thankful to Griffinteam. PS. The phone was completyl dead,no charge,no power on,no signs on screen. And the flashlog is here: (look at time! amazing!) Processing File: nhm75506.200 Boot... ASIC ID: 0120 DCT4 u_2nd.fia u_st_i.fia Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88BE 0000 FF42, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[7.00 MB]... erasing region [01000000 to 0100FFFF] erasing region [01010000 to 0157FFFF] erasing region [01670000 to 017EFFFF] in 82.89s Flash[5.06 MB]...in 31.45s * * Processed file in 120.03 seconds Processing File: nhm75506.20b Boot... ASIC ID: 0120 DCT4 u_2nd.fia u_st_i.fia Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88BE 0000 FF42, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.94 MB]... erasing region [01580000 to 0166FFFF] in 11.97s Flash[0.87 MB]...in 5.45s * * Processed file in 23.11 seconds * * * Phone flashing done in 2:25 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 06.20/16-04-03/NHM-7 (c) NMP. IMEI: 3515*********** Factory Default Settings...OK Conclusion: Don't downgrade your phone! Never ! And ATTENTION at files ! |
02-13-2006, 23:49 | #4 (permalink) |
Member: 232316 Status: Offline Thanks Meter: 1 | Solution: The solution is here.I'm beginner and maybe it is simple for others,I do this mini tutorial for others like me. You have to install and update your Flash/Repair sowftware.After that,instal Phone Data Package (like NHM-7_dp_v_15.0_MCUSW6_20.exe for NHM-7 for example).Look near IMEI label on your phone,you will find the product code.Then, write your phone model (1),hit enter.If everything is fine with instalation of your (last version) of Phone Data Package,the flash files should appear.Then chose your product code (2) . According to your model number,a PPM language pack will be selected.Look in your "Instalation Drive:/Program Files/Nokia/Phoenix/products/Nhm-7/" (I chose Nhm-7 like example,it could be other model) for others language packs (in this case nhm75506.20b - Language packs are identified by last letter).If there it is another language pack,other that Nokia Flash/Repair chose for your product code,erase the last letter and write the letter desired(3).Only if you are sure that is present on your Products directory. Then, flash your phone.Everything is normal and your dead phone is...ALIVE ! Sorry for my English and thanks to andro for his help.10x ! |
02-15-2006, 07:03 | #7 (permalink) |
Member: 232316 Status: Offline Thanks Meter: 1 | Details... I think that is not relevant to "DCT4 NOKIA 8310 Problem.Please advice me. " , i'ts paint brush. |
02-15-2006, 07:27 | #8 (permalink) |
Freak Poster Join Date: Aug 2004
Member: 77254 Status: Offline Thanks Meter: 9 | I've same problem with 8310, the phone can be flash normaly but could not enter local mode. I've tried using flash files download from MTBOX support with ver 5.10 and 6.20 but still could not enter local mode and the phone still dead. |
02-15-2006, 07:31 | #9 (permalink) |
Member: 232316 Status: Offline Thanks Meter: 1 | Mine was dead also.Local mode message isn't necesary.Even if phone info doens't work and software tell you to power on the phone.Just flash it with a good version. |
02-15-2006, 13:25 | #10 (permalink) |
Member: 77254 Status: Offline Thanks Meter: 9 | I've tried with 2 version from MTBox support, but in the end of progress, it doesn't shows like yours: Post Flash serial tunning of phone.... Pooling mode for full factory set... V 06.20/16-04-03/NHM-7 (c) NMP. IMEI: 3515*********** Factory Default Settings...OK It's always like this: Pooling mode for full factory set... Phone not responding, try to set manually! |
02-15-2006, 17:11 | #11 (permalink) |
Member: 232316 Status: Offline Thanks Meter: 1 | Have you.. Have you tried the last version? The same thing I've seen whe I downgrade the phone.Try with 6.20 wich is included in NHM-7_dp_v_15.0_MCUSW6_20.exe You can also disable automatic functions. |
02-16-2006, 05:26 | #12 (permalink) | |
Member: 77254 Status: Offline Thanks Meter: 9 | Quote:
Please advice me! Support area problem! | gsm8g | UST Pro II | 9 | 11-13-2008 11:47 |
D500 Tfs Erro Is This Hw Damage Please Advice Me! | gsm8g | NSPRO | 10 | 06-25-2006 11:44 |
Nokia 22 Problem, please HELP ME!!! | Actungu2 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-19-2005 22:23 |
Please advice me about www.cellular-cables.com | fox | Main Sales Section | 4 | 08-25-2001 11:32 |
Please advice me about www.cellular-cables.com | fox | Hardware Equipments for GSM | 0 | 08-23-2001 18:25 |
