Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 06-17-2007, 20:30   #1 (permalink)
Member: 8594
Thanks Meter: 13
E50-2 RM-171 can be unlocked with mt-box pro
Maybe this is usefull info for some mt-box pro owners: E50-2 RM-171 (without camera) can be unlocked with mt-box pro, even though according to the manual it is not supported. The trick is to convert it to the supported version of E50-1 RM-170. This is how to do it:
1: First, if needed, downgrade to v2.26.01 (=mcusw 6.27.01) with mt-box. Use RM-170 or RM-171 files on either fbus or normal/'dead' usb, it does not matter: mt-box (v1.33) does not change the phone type!
2: Use phoenix to flash to RM-170 v2.26.01, to do so you must:
2a: connect phone powered OFF to dku-2/ca-53 usb cable
2b: select open product and select rm-170
2c: go to firmware update
2d: select a product code
2e: use good old tnt/enforcer/gsm-magic program to enable dead usb option
2f: check dead usb and close enforcer program
2g: press start button. cancel on connection already opened error, then press start again.
2h: now when asked shortly press power on phone. if rom drivers are not installed yet, let in install and if timed out just repeat this step. phone will be flashed.
3: Now phone type is RM-170 and you can use mt-box to unlock the phone
4: Use phoenix again (same way) to convert the phone back to RM-171, use any same or newer version you like. (Leaving it at RM-170 will cause camera errors ofcourse).
Good luck!
EH
Old 06-27-2007, 18:31   #2 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
I hope very soon we have a easier way to support this model.
can 1200 unlock with mt box free Tanveer_city01 MT-BOX 4 03-14-2010 23:24
6680i (I-mode) can be unlocked by mt-box lite?? etersat MT-BOX 11 12-05-2007 19:36
BB5 UNLOCK with MT-Box Pro Version! pirilti Nokia Base Band 5 ( BB-5 ) 1 05-30-2007 08:09
Page generated in 0.14333 seconds with 10 queries
