02-04-2009, 07:12 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: GODS OWN COUNTRY Age: 38
Member: 433935 Status: Offline Sonork: 100.1575009 Thanks Meter: 32 | E50 local mode failed thats coming to me for resetting life timer after resetting life timer it given to customer c ustomer said bluetooth not worikjng,then i did UI settings after that bluetooth turned on,but once switched off then try to on again bluetooth its not on then I flashed with version 07.36.0.0 after that it didnt comes to ON it shows local mode failed ,in battery on with white display and goes off pls help me any one to solve my problem in abig treble plssssssssssssss |
02-05-2009, 10:50 | #2 (permalink) |
Member: 433935 Status: Offline Sonork: 100.1575009 Thanks Meter: 32 | SOLVED SOLVED SOLVED my set is e50-1 rm 170 I flashed with rm171 e50-2 file the set comes to local mode but not boot ,hanging in nokia then i backed up all cert and pm using HWK then i full erased the set with UB and flashed with rm170 file and written pm and cert back also then now set is working full ok also now bluetooth problem also solved thx |
E50 local mode failed | VIJEESH | Universalbox | 2 | 02-05-2009 10:47 |
E50 local mode failed | VIJEESH | HWK | 2 | 02-05-2009 10:46 |
E50 local mode failed | VIJEESH | Nokia Base Band 5 ( BB-5 ) | 4 | 02-05-2009 10:44 |
e50 local mode Failed!!! | jia_services | J.A.F. By Jafsupport.com | 1 | 04-01-2008 20:30 |
