Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 10-23-2005, 11:59   #1 (permalink)
harryzz's Avatar
Member: 9216
Thanks Meter: 21
external usb hub problems
Note: When connected to PC through external HUB:
On some cheap hubs, there are problems with communication serial and flashing. So if you are having problems with your MTBox, keep in mind it might be the HUB causing the problems. Good way to check if this is the problem is to connect box directly to your PC.
USB hub on Multi-box,how? gyuszko Multi-Box 4 09-19-2006 17:14
Flash works OK with USB HUB with power adaptor! ionelka NSPRO 3 06-06-2006 20:08
Huge USB-hub - 16+ ports? Does it exist? James_S Wanted Products 0 05-24-2006 07:23
Please Elco Cancel Usb Hub With External Power cobra02a NSPRO 2 01-10-2006 15:31
Why doesn't twister work when powered from external USB-hub? James_S Twisterflasher 0 06-07-2005 17:37
Page generated in 0.18178 seconds with 8 queries
