03-07-2009, 11:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | F.A.Q about MT BOX BB5+ Unlocking !!! Answer: No, you just need logs to activate your box for BB5+ and unlock is UNLIMITED 2.Customer: I press unlock button but is not work Answer: Do not use UNLOCK button use DK SL2 button 3.Customer: Can i use DK SL2 credits to activate BB5+ on my box Answer: No you cant, these credits are special credits and cant be used 4.Customer: Can i use my MT PRO LITE account logs to activate BB5+ on my box Answer: No you cant, these credits are special credits and cant be used for any service on GT server 5.Customer: Which cable i need to use FBUS or USB Answer: You need to use FBUS cable 6.Customer: MTB NK software crash when i press DK SL button. What is the problem? Answer: You MT box update tool v3.8 is out of software directory ... Run MT Tolls v3.8.exe from directory where is MTB_NK.EXE (i.e. where is located file griffin.ini in most cases C:\Program Files\GriffinTeam\MT-box) and click button 'Update'. Then try to unlock your phone 7.Customer: I am active for BB5+, and i get this on software Device:<\\?\usb#vid_a550&pid_xxxxxxxxxxxxxxx#{e6ef 7dcd-1795-4a08-9fbf-aa78423c26f0}> SN:xxxxxxxxxx Getting BOX Status...OK Getting INI File Update 1....[PIN:9542xxxxxxxxxxDE]OK Getting INI File Update 2...Server Error 1(8) SN:xxxxxxxxxx Server Login... OK Ask...OK Server I/O....OK Updating...BOX is Updated! can you advise me? Answer: Your box has now enabled BB5 wotp, you need to add more 100 logs to activate 8.Customer: Invalid response from RAP3 boot! I am trying to unlock 6500S and always keep on getting the error below. I already have changed machines, reinstall MT software few times, updated box 100 times (By putting in the updater in mt box folder). Changed cables and searched forums but no luck. PLEASE ADVICE. THANKS. 356400024345995 V 08.30/03-07-08/RM-240 (c) Nokia IMEI: 356400024345995 Operator: 8000000000000002 Profile bits: 2342000000000000 Closed on Mcc Mnc: 23420F Closed on Mcc Mnc: 23594F Backup simlock Backup SIMLOCK: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\356400024345995_n.pm 356400024345995 Booting Phone... Searching loader Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit !!!Operation Failed!!! Answer: Check your cable. |
The Following 39 Users Say Thank You to ..::Angel::.. For This Useful Post: |
03-08-2009, 10:01 | #2 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | 9.BB5+ work on one PC but on another one cant. Customer: BB5+ work on one PC but on another one cant. See my log: 355731023212690 V 08.30/03-07-08/RM-240 (c) Nokia IMEI: 355731023212690 Operator: 8000000000000000 Profile bits: 2343300000000000 Closed on Mcc Mnc: 23433F Closed on Mcc Mnc: 23486F Backup simlock Backup SIMLOCK: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\355731023212690_n.pm 355731023212690 Booting Phone... Searching loader rap3gv3_2nd.fg !!!Operation Has Failed!!! Answer: When you change PC you need to update box again, because there is no PIN in your Griffin.ini. Use this way: Download MT Tool v3.8 Connect your MT box to USB Run MT Tool v3.8.exe from directory where is MTB_NK.EXE (i.e. where is located file griffin.ini in most cases C:\Program Files\GriffinTeam\MT-box) and click button 'Update'. Do not use MT Box update tool v3.7 or older because will not work 10.Where are saved BB5+ unlock codes? Customer: Where are saved BB5+ unlock codes? Answer: C:\Program Files\GriffinTeam\MT-Box\bb5hash\codes.ini 11. I update my box but cant unlock BB5+ Customer: I update my box but cant unlock it. What is the problem? Answer: MT box update tool v3.8 MTB NK 1.57.exe Griffin.ini must be in same folder c:\Program Files\GriffinTeam\MT-Box |
The Following 19 Users Say Thank You to ..::Angel::.. For This Useful Post: |
03-09-2009, 08:38 | #3 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | 12.!!!Operation Has Failed!!! Customer: I try to unlock BB5+ phone but got this error: Quote: Booting Phone... Searching loader rap3gv3_2nd.fg !!!Operation Has Failed!!! Answer: Download MT Tool v3.8 Connect your MT box to USB Run MT Tool v3.8.exe from directory where is MTB_NK.EXE (i.e. where is located file griffin.ini in most cases C:\Program Files\GriffinTeam\MT-box) and click button 'Update'. Do not use MT Box update tool v3.7 or older because will not work Close all applications and restart your PC Do NOT USE USB hubs to connect MT box to PC Connect MT Box direct to PC if you can without LONG extension cable, cable need to be very SHORT Use shielded USB cables if you can 13.Unsupported RootkeyHash !!!Operation Has Failed!!! Customer: I try to unlock phone but this error appears: Quote: 353661014137568 V 04.11/24-06-08/RM-352 (c) Nokia IMEI: 353661014137568 Operator: 8000000000000000 Profile bits: 2082000000000000 Closed on Mcc Mnc: 20820F Backup simlock Backup SIMLOCK: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\353661014137568_n.pm 353661014137568 Booting Phone... Searching loader rap3gv3_2nd.fg Unsupported RootkeyHash !!!Operation Has Failed!!! Answer: The phone model and version is not supported yet 14.Found cached code in codes.ini, sending to phone CODE Error Customer: I have a problem to unlock my phone, this error appears: Quote: V 06.20/29-02-08/RM-364 (c) Nokia IMEI: 35344444444444444 Operator: 5150200000000000 Operator Name: Globe Telecom;Philippines Profile bits: 8000000000000002 Closed on Mcc Mnc: 51502F Counters 0/10, 0/3 35444444444444444 Found cached code in codes.ini, sending to phone CODE Error Answer: Close MTB NK software Go to C:\Program Files\GriffinTeam\MT-Box\bb5hash\ and delete codes.ini file Start MTB NK software Unlock phone again (press DK SL2 button) 15.Getting INI File Update 2... FAIL Customer: I try to update my box but got this error, see my log: Device:<\\?\usb#vid_a550&pid_f00d#000xxxxxxx#{e6ef 7dcd-1795-4a08-9fbf-aa78423c26f0}> SN:000xxxxxxx Getting BOX Status...OK Getting INI File Update 1....[PIN:39FC65757FE8FF6A]OK Getting INI File Update 2... FAIL SN:000xxxxxxx Server Login... OK Ask...OK Server I/O....OK Updating...BOX is Updated! Answer: Your box has not ready BB5+ activation Use MT Box update tool v3.8 or higher 16.How to reset code counters on BB5+ phones ONLY!! Customer: I try to unlock my phone but code counters are 10/10 and 3/3 and cant enter code. How to solve it? Se my log: Quote:
You can reset both counters in pm 120 !!! NO NEED RPL FOR THIS! go to pm edit and read: GROUP:120 INDEX:0 it should look like this: 80 00 00 00 00 00 00 00 26 80 10 00 00 00 00 00 00 18 01 00 00 00 00 00 00 20 00 00 01 FF FF FF 00 00 00 00 7F FF 6F 07 FF FF FF FF F8 00 00 34 03 00 05 02 26 80 1F FF look to the first string: 80 00 00 00 00 00 00 00 26 80 10 00 00 00 00 00 00 18 01 00 <- this is the counter fist 0 is f-bus counter and second 0 is key code counter! write both to 00 and write to phone = counter is 0/3 0/10! ONLY FOR bb5+ PHONES with pm fild 120 !!! DONT TRY IT ON NORMAL BB5!!!!! 17.Phone Goes TO CS during Unlock phones goes to CS See this video to repair ... http://forum.gsmhosting.com/vbb/show...93&postcount=1 thats all... Last edited by stanner_austin; 03-09-2009 at 08:47. Reason: counter corrected | |
The Following 58 Users Say Thank You to ..::Angel::.. For This Useful Post: |
About MT Box Nokia BB5 SL20 RPL module activation | TheFoXMK | MT-BOX | 4 | 01-26-2010 13:45 |
Its Finally Here. BB5+ Unlocking available on MT BOX - Unlimited UNLOCKS! | UnikGSM_Sha | Main Sales Section | 0 | 03-06-2009 16:34 |
Mt-box bb5 unlock without testpoint!! | Umbabaraumba | MT-BOX | 0 | 11-07-2008 15:12 |
how about MT Box Lite and MT Box (Nokia) | bgcolor | Nokia Base Band 5 ( BB-5 ) | 1 | 03-15-2008 18:50 |
