09-15-2007, 17:12 | #32 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 15.09.2007 - MT Box PRO update - 22 models supported without logs New supported models and software versions: 6136 RM-199 v03.71.2 12-09-06 5500 RM-86 v03.55 23-11-06 |
09-17-2007, 15:43 | #34 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 17.09.2007 - MT Box PRO update - 35 models supported without logs New supported models and software versions: 3110c [V_05.01_21-05-07_RM-237_(c)_Nokia.] 3250 [V__04.21_16-02-07_RM-38_(c)_Nokia.] 6086 [V_03.51_15-02-07_RM-188_(c)_Nokia.] 6151 [V_04.10_21-12-06_RM-200_(c)_Nokia] 7390 [V_03.84_23-10-06_RM-140_(c)_Nokia] 8600 [V_03.52_24-05-07_RM-164_(c)_Nokia.] E50 [V_3.37.23_11-10-06_RM-170_(c)_Nokia.] MCU: RM170p_06413.C01 [V_3.37.23_11-10-06_RM-171_(c)_Nokia.] MCU: RM171p_06413.C01 E61 [V_3.0533.6_31-10-06.RM-89_(c)_Nokia.] MCU: rm89_m128_h20_ks_prod_306330904_c00_combined.bin E62 [Vp_2.0618.06.17_10-08-06_RM-88_(c)_Nokia.] MCU: rm88_18.06.17.c00 (Nokia_Firmware_RM-88_DP1.0_APAC_18.06.17.exe) E65 [V_1.0615.25_10-01-07_RM-208_(c)_Nokia.] MCU: rm208_m128_h20_ka_prod_106331801_c00_combined.bin install: Nokia_firmware_RM-208_apac_1.0633.18.01_v1.0.exe N73 [V_05wk47v48.3_02-07-07_RM-133_(c)_Nokia] MCU: N73_4.0727.2.2.1_western_C00_PRD_cc.fpsx install: RM-133_ME_EMEA_4.0727.2.2.1_v3.0.exe N75 [V_06wk15v37_08-03-07_RM-128_(c)_Nokia.] MCU: RM128_10.2.055.C00 N80 [V_05wk33v33.1_22-06-06_RM-92_(c)_Nokia] MCU: N80_4.0623.0.41-prd_western_C00_cc.fpsx install: RM-92_EMEA_PR_dp_v13.00_SW4.0623.0.41.exe N93 [V_05wk47v28.2_03-07-06_RM-55_(c)_Nokia.] - MCU: RM55PE110034.C00 |
09-17-2007, 15:44 | #35 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 17.09.2007 - MT Box PRO LITE update - new 14 models added - total 35 models supported New supported models and software versions: 3110c [V_05.01_21-05-07_RM-237_(c)_Nokia.] 3250 [V__04.21_16-02-07_RM-38_(c)_Nokia.] 6086 [V_03.51_15-02-07_RM-188_(c)_Nokia.] 6151 [V_04.10_21-12-06_RM-200_(c)_Nokia] 7390 [V_03.84_23-10-06_RM-140_(c)_Nokia] 8600 [V_03.52_24-05-07_RM-164_(c)_Nokia.] E50 [V_3.37.23_11-10-06_RM-170_(c)_Nokia.] MCU: RM170p_06413.C01 [V_3.37.23_11-10-06_RM-171_(c)_Nokia.] MCU: RM171p_06413.C01 E61 [V_3.0533.6_31-10-06.RM-89_(c)_Nokia.] MCU: rm89_m128_h20_ks_prod_306330904_c00_combined.bin E62 [Vp_2.0618.06.17_10-08-06_RM-88_(c)_Nokia.] MCU: rm88_18.06.17.c00 (Nokia_Firmware_RM-88_DP1.0_APAC_18.06.17.exe) E65 [V_1.0615.25_10-01-07_RM-208_(c)_Nokia.] MCU: rm208_m128_h20_ka_prod_106331801_c00_combined.bin install: Nokia_firmware_RM-208_apac_1.0633.18.01_v1.0.exe N73 [V_05wk47v48.3_02-07-07_RM-133_(c)_Nokia] MCU: N73_4.0727.2.2.1_western_C00_PRD_cc.fpsx install: RM-133_ME_EMEA_4.0727.2.2.1_v3.0.exe N75 [V_06wk15v37_08-03-07_RM-128_(c)_Nokia.] MCU: RM128_10.2.055.C00 N80 [V_05wk33v33.1_22-06-06_RM-92_(c)_Nokia] MCU: N80_4.0623.0.41-prd_western_C00_cc.fpsx install: RM-92_EMEA_PR_dp_v13.00_SW4.0623.0.41.exe N93 [V_05wk47v28.2_03-07-06_RM-55_(c)_Nokia.] - MCU: RM55PE110034.C00 |
09-19-2007, 00:44 | #36 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 19.09.2007 - MT Box PRO user manual update v3.0 What’s new: - Nokia N75 test point picture added - Some explanations added - Updated supported phones and software versions list Download: MT Box Pro user manual v3.0 |
09-19-2007, 21:45 | #37 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: I am new MT PRO LITE user, i try to unlock phone but always some error. Answer: To start you need: - To receive login details from your box seller (user name with prefix MTPlite - On your account need to be 40 credits (this is the by default on each new LITE account) - Download and install latest MTB NK software version (which is latest check here) - Enter login details to software (how to can see in user manual) - There you can also find Test point pictures - To able unlock phones you need to edit your Griffin.ini, how to can find here - Check phone info to see it is phone versions supported for unlock (the list is here) - If phone version is not supported for unlock with MT box lite you need to downgrade or upgrade your phone to supported version - Now you can start Last edited by SoftMobile; 10-09-2007 at 00:36. |
09-20-2007, 23:32 | #38 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 21.09.2007 - MT Box PRO user manual update v3.1 What’s new: - Nokia 3110c test point picture changed - Nokia N93 test point picture added Download: MT Box Pro user manual v3.1 |
09-20-2007, 23:49 | #39 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: How to unlock N95 using standard phone USB cable? Answer: - Install Nokia connectivity drivers latest version (download it from here) - Start MTB NK 1.37 (download it from here) - Select USB connection - Connect battery to phone or use TP cables VBAT and BSI - Switch phone on - Connect phone to USB cable - Select PC suite mode when phone ask you - Select Local mode in software - Press phone info to check phone version or does have communication with software - Check sim lock status - Press unlock button - Connect Test points - Wait to software finish - If you unlock phones which is supported without logs don't forget to add necessary information in Griffin.ini file More about N95 Griffin.ini modification you can find here More about Griffin.ini modification for other models you can find here |
09-21-2007, 12:57 | #40 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 21.09.2007 - MT Box PRO update on server side Whats new: All known unlock able hardware versions of 5200, 5300 and 6300 are supported with revision=F No need for revision=D, if you add revision=D in Griffin.ini your account will be charged for 40 credits. All changes are on server side, so customers no need to change anything. BR GT Last edited by SoftMobile; 09-22-2007 at 23:42. |
09-23-2007, 11:18 | #41 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 23.09.2007 - MT Box PRO update - new model supported without logs New supported models and software versions: 6085 V_04.26_16-03-07_RM-198_(c)_Nokia |
10-02-2007, 18:35 | #42 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 02.10.2007 - MT Box PRO update - new model supported without logs New supported models and software versions: 5200 [V_05.00_27-04-07_RM-174_(c)_Nokia.] 5200b [V_05.00_27-04-07_RM-181_(c)_Nokia.] 5300 [V_05.00_27-04-07_RM-146_(c)_Nokia.] 5300b [V_05.00_27-04-07_RM-147_(c)_Nokia.] 6300 [V_05.00_27-04-07_RM-217_(c)_Nokia.] 7370 [V_04.13_16-05-06_RM-70_(c)_Nokia.] |
10-08-2007, 14:29 | #43 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 08.10.2007 - MT PRO and MT PRO LITE unlock all supported models and versions FREEEEEEEEEEEE From today all supported phone models and software versions can be unlocked without logs. Internet connection will be required for unlock operation, because of security. All new phones and software versions which will be supported in future and its not supported by othertools will be available for unlock by logs. To able unlock all supported versions without logs just edit your Griffin.ini. How to edit Griffin.ini: - Close MTB NK 1.38B software - Go to C:\Program Files\GriffinTeam\MT-Box\ - Open Griffin.ini add this data to interface options " revision=F " : For example: [interface_options] revision=F extras=1 extras_index=1 RPL_208=0 LogToFile=0 FlsaDisplayDetail=0 ProductProfile=1 GprsSettings=1 NvdAccess=1 AutoUnlock=0 UpdateProductCode=0 ResetUserCode=0 NvdNvd=1 SkipBluetooth=0 FactoryDefaultSettings=1 - Save ini file - Start MTB NK software v1.38B Note: To able use it you must have valid BB5 account minimum 40 credits. |
12-06-2007, 11:13 | #45 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | 06.12.2007 ADDED NEW VERSION OF E50: now you can try to unlock e50 : V_4.41.41_28-06-07_RM-170_(c)_Nokia. install:Nokia_firmware_RM-170_emea_lta_07.36.0.0_v6.0.exe MCU FILE IS:RM170p_0736.C01 |
About MT box PRO user manual v2.2 | begginer | MT-BOX | 3 | 06-12-2009 07:26 |
F.A.Q. about MT Box PRO and updates info | DIGITAL BABU | MT-BOX | 1 | 05-22-2008 16:26 |
how about MT Box Lite and MT Box (Nokia) | bgcolor | Nokia Base Band 5 ( BB-5 ) | 1 | 03-15-2008 18:50 |
***** MT Box PRO and MT PRO LITE server changes ***** | SoftMobile | MT-BOX | 164 | 10-04-2007 12:23 |
@andro MT-BOX PRO AND 5200 | chotky | MT-BOX | 35 | 09-05-2007 01:06 |
