12-04-2007, 15:46 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Turkey
Member: 60632 Status: Offline Sonork: 100.1616618 Thanks Meter: 48 | Griffin Team 6131 Bad RPL Help Me My RPL File sending ok. but Writting Phone serial number 12345610654321? Erase phone again RPl File Writting But not repair error show here and RPL File Please new calculated my RPL file Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... CMT Send NPC Certificate Phone Type: BB5 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.99V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-115 ( 6131/ 6133) V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 12345610654321? Simlock send - FAILED! SuperDongle send - SUCCESSFULL!!! |
12-04-2007, 16:19 | #2 (permalink) |
Member: 60632 Status: Offline Sonork: 100.1616618 Thanks Meter: 48 | 6300 RPL serial number not repair this two file RPL rpl writting okey but serial number not repair erase phone okey but not repair attachment RPL File new calculated please |
12-04-2007, 16:42 | #3 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | i thing you need to use search and will understand - bad rpl dont have ! HAVE A BAD MCU in your phone or bad try to write RPL,also have and post with procedure how to erase full this phone and write rpl. |
12-04-2007, 17:09 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | tedcen....... search in this forum u will find results about u r problem.. "simlock send -failed " try and post the result mate... or pm me.. |
12-05-2007, 07:05 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | just read it carefully u will find ur answer more clear.... http:///vbb/showpo...9&postcount=32 br khalid |
12-05-2007, 08:33 | #6 (permalink) |
Member: 60632 Status: Offline Sonork: 100.1616618 Thanks Meter: 48 | 6131 PPM clik and Erase 32 MB file okey Flashing 06.10 Serial number 12345.... okey writing RPL file show log here simlock send failed ------ RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.97V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-115 ( 6131/ 6133) V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 356432010290018 Simlock send - FAILED! SuperDongle send - SUCCESSFULL!!! what is problem ? SX4 service using but not repair this problem |
12-05-2007, 08:52 | #7 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | tedcen..... did you see the link given by Br Khalid... see that link and you will get the answer... answer is discussed already.... 1. erase it using the given file...select in Mcu. second flash it with latest version... and then downgrade the fone to last low version... and the try to write the RPL and then post the result... and then we will discuss here step by step...today...ok. |
The Following User Says Thank You to harim_1981 For This Useful Post: |
12-12-2007, 11:05 | #8 (permalink) |
Member: 60632 Status: Offline Sonork: 100.1616618 Thanks Meter: 48 | @911GT 6300 RPL ok. other 6131 RPL ok but this serial number IMEI: 356432010290018 RPl file here attachment please checked this RPL file error show here down JAF server using SX4 connect done writting 0-512 pm but not repair phone info bad product status and 4 close phone ------ RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.97V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-115 ( 6131/ 6133) V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 356432010290018 Simlock send - FAILED! SuperDongle send - SUCCESSFULL!!! |
12-12-2007, 11:23 | #10 (permalink) |
Member: 60632 Status: Offline Sonork: 100.1616618 Thanks Meter: 48 | link not working not open page this page erase section page ? because not open page yes erase but not repair friends please this RPL file good RPL file ? checked try again my RPL file or your 6131 308 pm attachment here please |
12-16-2007, 21:37 | #12 (permalink) |
Member: 60632 Status: Offline Sonork: 100.1616618 Thanks Meter: 48 | ok. 911GT thanks this phone new phone sending germany nokia central service but my post not edit this my post RPL file attachment deleting please and my post serial number tex edit XXXXXX writting please thanks goodluck |
6131 camera slow help me plz | jolie | Nokia Hardware & Hardware Repair | 3 | 06-11-2008 09:14 |
Can someone help me with this as Griffin Team dont seem to answer me | pearsonjohnboy | MT-BOX | 7 | 12-13-2006 17:15 |
Griffin team i need your help | GSM Deals | Griffin | 9 | 02-15-2005 02:40 |
griffin team i need ur help | ryumahon | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 06-12-2003 16:23 |
