08-01-2007, 08:53 | #346 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ROMANIA
Member: 188484 Status: Offline Thanks Meter: 117 | Server IP: 213.16.42.125, Box_SN: IrinelGT10 Connect... Resp: o/0110/hello there Login...OK, available count 60; busy, waiting... e/0/accepted; |
08-01-2007, 19:43 | #347 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 48
Member: 110088 Status: Offline Thanks Meter: 29 | please for recalculate "ask b5" that I didn`t get hello gryffin team two day ago i posted file to recalculate ask bb5 for rpl my login form program GT Online Access v1.34 is: username: :iph5345 its took logs form my account but I didn`t got RPL file please double check it again and eventualy return my 40 credits in email there is file readed form 6280 included for counting [email protected] ------ Last edited by SoftMobile; 08-01-2007 at 20:07. |
08-01-2007, 22:07 | #348 (permalink) |
Freak Poster Join Date: Dec 2004
Member: 101818 Status: Offline Thanks Meter: 2 | Phone is in: Local mode Model: RM-1 (Charlie ) V 04wk47_m_v14/09-02-06/RM-1 (c) Nokia. Production serial number Product code 0520270 Module code Basic production code Flash code Order number Long production SN MCU SW V 04wk47_m_v14/09-02-06/RM-1/(c) Nokia. PCI RFIC 150a160e DSP pb04w47v26 PPM 8617985 APE SW Core V 6.03.08/13-02-06/RM-1/(c) NOKIA. APE Variant 083 Retu 32 Tahvo 41 APE HW 256 APE ADSP SW 52041 IMEI: 12345610654321? IMEI: 12345610654321? Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_format.fg BOOT OK... Send NPC Certificate Phone Type: BB5 ------------------- SYSTEM ID Response: 12 blocks ------------- SYSTEM_ASIC_ID( APE ): 17100701 ASIC_MODE_ID( APE ): 00 PUBLIC_ID( APE ): 329815EE6D18A015D230D734335C522FE0798FF4 ROOT_KEY_HASH( APE ): 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM_ID( APE ): AB5E4ADB27A06946 SYSTEM_ASIC_ID( RAP ): 000000010000022600010006000C192101002100 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000341 PUBLIC_ID( RAP ): 0580001160964F570F632171EB2B9794524A1900 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): E9EFF4BFAA5393217CA6B17755FC3E14 ROM_ID( RAP ): F28A211FAC901AEE --------------- Device ID Response: 2 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Samsung, 00EC 22FA 0000 0011 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 --------------- Device ID Response: 2 blocks ------------- Storage Device: Owner Asic: APE Type: NAND Flash Index: 0 Flash: Samsung, 00EC 0035 00A5 00BD UNKNOWN BLOCK ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.91V Vpp pin has 1.40V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-1 (Charlie ) V 04wk47_m_v14/09-02-06/RM-1 (c) Nokia. IMEI: 356657000112653 Simlock send - SUCCESSFULL!!! SuperDongle send - SUCCESSFULL!!! ---------------------------------------------------------------------------Sent ask file and got back the RPL 40 credits Write Rpl --phone startup failed contact the retailer-- |
08-02-2007, 08:15 | #350 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | @Kaita! If you have back up pm then use “SX4” option and write it you phone or write working phone good pm 1.Connect phone. 2.Make sure it has serial communication ( recommend to see it responds to phone info in local mode). 3.Load the PM file ( load file, in Eeprom controls page). 4.Mark Section( resource) 308 (0x134) and press Write Selected. 5.Restart phone. Either disconnect and reconnect phone to MT, or change mode to Test. 6.Press SX4 button, and wait for it to display that authorization was successful. 7.Press Write All button. If no error are report, then you've successful restored the PM of the phone. |
08-03-2007, 14:21 | #352 (permalink) |
Freak Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL. Age: 43
Member: 116176 Status: Offline Thanks Meter: 23 | i have n73 iemi 12345 after write rpl iemi back and Simlock send - SUCCESSFULL!!! SuperDongle send - SUCCESSFULL!!! ok and s4x and write pm ailed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 355506018786xxx busy, waiting... Connect... Login... busy, waiting... PMM Authorize SUCCESSFULL PMM Send File Sending SIMLOCK record... Operation Completed V 05wk47v46.3/04-06-07/RM-133 (c) Nokia. IMEI: 355506018786xxx Operator: 0000000000000000 Profile bits: 2440700000000000 Sim Status: Not locked but phone still contact retailer what problem this info for my phone after all operation hone is in: Unknown mode Model: RM-133 (N73) V 05wk47v46.3/04-06-07/RM-133 (c) Nokia. Production serial number SBH144666 Product code 0529607 Module code 0202855 Basic production code 0527006 Flash code Order number Long production SN MCU SW V 05wk47v46.3/04-06-07/RM-133/(c) Nokia. HW 6000 PCI RFIC 17191719 DSP scarfe_05wk46v50 APE SW Core V 4.0723.2.0.1/06-06-2007/RM-133/ APE Variant V 4.0723.2.0.1-07/06-06-2007/RM-133/ Retu 15 Tahvo 21 APE HW 1 APE ADSP SW 256 IMEI: 355506018786xxx |
08-06-2007, 10:15 | #353 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 43
Member: 86034 Status: Offline Thanks Meter: 60 | help me Vpp pin has 0.12V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode Model: RM-217 (Piccolo 900 ) V 05.00/27-04-07/RM-217 (c) Nokia. IMEI: 35643*********** Simlock send - FAILED! SuperDongle send - SUCCESSFULL!!! CMLA send - SUCCESSFULL!!! WMDRM PD send - SUCCESSFULL!!! V 05.00/27-04-07/RM-217 (c) Nokia. IMEI: 356437********** Operator: 8000000000000000 Profile bits: 2320300000000000 Closed on Mcc Mnc: 23203F Counters 10/10, help me please Simlock send - FAILED! why error |
08-06-2007, 12:40 | #354 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | my griffin full account was stolen, received 2 accounts with 200 logs each from ipmart and someone in turkey used them, please dont do service for: User: amtb178 (26594) Current credit: 0 OwnerID: 6175 box id date/time plain IMEI service ip 000000005232BFD3 (Fri) 27 Jul 2007 - 14:10:26 3539270127411270 NK_BB5_CERT_REST 88.232.173.95 000000005A7A753F (Mon) 30 Jul 2007 - 23:35:05 3579270015852260 NK_BB5_CERT_REST 85.104.22.187 000000005232BFD3 (Sun) 29 Jul 2007 - 15:50:11 3555060193056600 NK_BB5_CERT_REST 85.104.21.51 000000005232BFD3 (Sun) 29 Jul 2007 - 15:50:12 3562600107896180 NK_BB5_CERT_REST 85.104.21.51 000000005A7A753F (Tue) 31 Jul 2007 - 20:10:19 3556610069020270 NK_BB5_CERT_REST 88.232.175.199 total logs: 5 I-Support (2007-08-06 01:01:03) User: amtb179 (26595) Current credit: 0 OwnerID: 6175 box id date/time plain IMEI service ip 000000005A7A753F (Tue) 31 Jul 2007 - 16:10:15 3522570120478740 NK_BB5_CERT_REST 88.232.175.199 000000005A7A753F (Tue) 31 Jul 2007 - 20:10:19 3556610069020270 NK_BB5_CERT_REST 88.232.175.199 000000005232BFD3 (Wed) 01 Aug 2007 - 01:35:07 3564360164835680 NK_BB5_CERT_REST 85.98.168.21 000000005232BFD3 (Wed) 01 Aug 2007 - 01:50:02 3555090153608530 NK_BB5_CERT_REST 85.98.168.21 000000005A7A753F (Wed) 01 Aug 2007 - 21:35:27 3539270136515150 NK_BB5_CERT_REST 85.104.15.203 total logs: 5 thank you |
08-08-2007, 08:09 | #355 (permalink) |
Major Poster Join Date: May 2007
Member: 505753 Status: Offline Thanks Meter: 0 | For Griffin Team RPL Problem I have sent ask file for Nokia 6270 to getting RPL file but after receiveing RPL file, when i want to write it with MT Box to Phone.The Box showes me the "INVALID RPL FILE" message the Phone IMEI is 35xxxxxxxxxxxx.And my 40 cradits has been gone. Please send me the good and valid RPL file.My Account User Name is "texxxxxxx" with best regards ------------------------ DO NOT POST ASK AND RPL IMEI ON FORUM http://forum.gsmhosting.com/vbb/show...6&postcount=29 Last edited by SoftMobile; 08-08-2007 at 11:06. |
08-08-2007, 20:25 | #356 (permalink) |
No Life Poster Join Date: Mar 2004 Age: 44
Member: 58764 Status: Offline Thanks Meter: 95 | PLZ REPAIRE MI MY RPL V 06.43/30-03-07/RM-78 (c) Nokia Do not post imei here Failed to Read V 06.43/30-03-07/RM-78 (c) Nokia Do not post imei here Failed to Read V 06.43/30-03-07/RM-78 (c) Nokia Do not post imei here Failed to Read Do not post imei here SKIPPED Certificate sent ============= Set FBus mode for info ============= VBat is 3.93V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-78 (6280) V 06.43/30-03-07/RM-78 (c) Nokia Do not post imei here Simlock send - FAILED! SuperDongle send - SUCCESSFULL!!! THX GT Last edited by SoftMobile; 08-08-2007 at 20:53. |
08-09-2007, 20:49 | #357 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 202954 Status: Offline Thanks Meter: 32 | hi friends: i still have problems with my mt box pro, i know and understand you, that i have to ask everything to my reseller, but one of my problem is that server got from my account 4 credits and do not unlock any of the 4 phones that i tryed to unlock, and now 3 of that 4 phones are dead, do not power on, and i am telling to my reseller and this is what are they telling me: On the credit part, we are not responsible for it. Credit was taken by the MT-Box ( Griffin ) teamYou can try to contact them about it. so friends, i am looking for help. thanks. |
08-10-2007, 08:17 | #358 (permalink) |
Freak Poster Join Date: May 2005 Age: 53
Member: 143133 Status: Offline Thanks Meter: 5 | Where my RPL?????? I send the ask file for 6630 exceed 3 days ,but now I can not receive the rpl file!!! Plese give back the credits!!! Thanks Server IP: 213.16.42.125, Box_SN: xxxxxxxxxxxxxxxxx Connect... Resp: o/0110/hello there Login...OK, available count 120; busy, waiting... e/0/accepted; Last edited by SoftMobile; 08-14-2007 at 00:11. |
08-10-2007, 08:27 | #359 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Aus. melbourne Age: 45
Member: 20639 Status: Offline Thanks Meter: 233 | Hi Members, i got N80 have imei 12345678..... but i dont have the original imei, still this can be done by ASK/RPL?? please advice thanks |
08-10-2007, 09:02 | #360 (permalink) |
Member: 20639 Status: Offline Thanks Meter: 233 | Hi members, in BB5 erase file, there are 6 files, which are the 4 files should i use for N91? BB5Erase_8MBrap.bin BB5Erase_16MBrap.bin BB5Erase_EE_8MBrap.bin BB5Erase_EE_16MBrap.bin MB BB5Erase_32MBrap.bin BB5Erase_EE_32MBrap.bin please advice thanks |
GTSAccess 1.37 BB5 ASK/RPL SERVICE | ambt | MT-BOX | 6 | 12-30-2007 12:55 |
MT-Box BB5 ask /rpl service again work as normal | MicrostarGSM® | MT-BOX | 39 | 06-22-2007 06:30 |
GTSAccess 1.34_1 BB5 ASK/RPL SERVICE | dharmdev | MT-BOX | 2 | 06-04-2007 12:28 |
newbie about bb5 ask rpl service. | mentari | MT-BOX | 0 | 02-10-2007 12:20 |
