10-05-2007, 16:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: The Arrivals
Member: 263993 Status: Offline Sonork: 100.1612432 Thanks Meter: 173 | how can i unlock this 6280 i try to downgrande but not possibel try unlock with log all so no possibel W 06.43/30-03-07/RM-78/(c) Noki Auto backup SIMLOCK... ================================= bb5bckup\357603003531050.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 Operator: 8000000000000006 Profile bits: 2229900093172790 Closed on Mcc Mnc: 22299F =================================== Using Account: byxxxxxx Connect... Resp: o/0110/hello there Login... OK, available count 3480; busy, waiting... Server Response OK. =================================== Connect TPs(D1) V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 XV 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 TPs OK TESTPOINT FAILED TestPoint Failed V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 Operator: 8000000000000006 Profile bits: 2229900093172790 Closed on Mcc Mnc: 22299F V 06.43/30-03-07/RM-78 (c) Nokia IMEI: 357603003531050 Operator: 8000000000000006 Profile bits: 2229900093172790 Closed on Mcc Mnc: 22299F Counters 3/10, 3/3 |
10-06-2007, 15:12 | #2 (permalink) |
Member: 263993 Status: Offline Sonork: 100.1612432 Thanks Meter: 173 | lose one log lose many time and no answer from griffin team!!! wats problem with this phone have to handsets 628 cant downgrade and unlock via log ebu mohammed-emin |
10-06-2007, 15:37 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | y not possible to downgrade.... can you please post the logs while downgrading... i have done lots.... just backup the IMEI and FIELD 308 and press DowngradeBB5 ..and try with free logs... and about this.. TPs OK TESTPOINT FAILED TestPoint Failed see in the FAQ of MT-PRO lite.... |
10-06-2007, 15:48 | #5 (permalink) |
10-06-2007, 16:23 | #7 (permalink) |
Member: 263993 Status: Offline Sonork: 100.1612432 Thanks Meter: 173 | i try with usb to downgrade not possibel give error and battery is full i try with fbus phone not connect i try with difrent box but cant downgrde first wenn i press unlock with log was counter 0/10 after firsst TPs OK TESTPOINT FAILED TestPoint Failed counter1/10 after second TPs OK TESTPOINT FAILED TestPoint Failed 02/10 etc i be shure gnd is connekted and i make alot of 6280 with out problem and downgrade with out probleb but the two handset not possibel ebu mohammed-emin |
10-06-2007, 16:32 | #8 (permalink) | |
Member: 263993 Status: Offline Sonork: 100.1612432 Thanks Meter: 173 | Quote:
and use pin look her | |
10-07-2007, 00:12 | #11 (permalink) |
Member: 263993 Status: Offline Sonork: 100.1612432 Thanks Meter: 173 | ok after modify my cabel can downgrade one of the 6280n is done but the second give me all time error and now is the counter by 5/10 3/3 how can i solve this problem F 03.81/09-05-06/RM-78/(c) Noki Auto backup SIMLOCK... ================================= bb5bckup\357603003531050.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 Operator: 8000000000000006 Profile bits: 2229900093172790 Closed on Mcc Mnc: 22299F =================================== Using Account: xxxxxxxxxx Connect... Resp: o/0110/hello there Login... OK, available count 3480; busy, waiting... Server Response OK. =================================== Connect TPs(D1) V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 TPs OK TESTPOINT FAILED TestPoint Failed V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 Operator: 8000000000000006 Profile bits: 2229900093172790 Closed on Mcc Mnc: 22299F V 03.81/09-05-06/RM-78 (c) Nokia IMEI: 357603003531050 Operator: 8000000000000006 Profile bits: 2229900093172790 Closed on Mcc Mnc: 22299F Counters 5/10, 3/3 gt team need advice since 2 day´s i post her log and ask advice but dont see any answer from u? is be nice wenn u can advice !!! thx in advance ebu mohammed-emin |
10-07-2007, 02:52 | #12 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Bosnia and Herzegovina
Member: 19493 Status: Offline Sonork: 100.1596420 Thanks Meter: 185 | Hi there You must read user manual carefully , here we go>: Customer: I try to unlock phone but got this error: Connect TPs(D1) TPs OK TESTPOINT FAILED TESTPOINT FAILED Answer: If errors after TP ok you need to short GND(black) and DATA(green) on a TP cable 2 times and all will be ok. W.B.R. |
10-07-2007, 03:34 | #13 (permalink) | |
i do it but not succes and counter now 8/10 wat i have to do gtteam@? ebu mohammed-emin | |
10-07-2007, 08:33 | #14 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | dont worry about counter ! you will restore it with backup of 134 field who soft make alone when you click on a unlock. you need to short 2 times (from 20 to 10cm) green TP and to be sure this cable s is ok. |
How can I unlock this Samsung L760v? I can´t see codes:::ANSWERED::: | Grupo MovilFree | PolarBox 3 | 13 | 09-01-2009 20:06 |
Plz help can i unlock this 6280 | mujahid_ali | BB5BOX | 3 | 04-11-2008 07:00 |
how can i unlock this a70 | .:bono:. | E-Gold Based Phones | 3 | 01-31-2006 21:08 |
e635 how can you unlock this phone? | junkiee24 | Samsung Flashers, Software, Firmware. | 0 | 01-27-2006 04:59 |
How Can I Unlock This Phone | sunrise gsm | VygisToolbox | 10 | 01-23-2006 15:31 |
