How We Can Flash C62 Hwo we can flash c62 . and what is methord for searching software version |
But i flash defirent version . c62 untill dead , so how we can dedect software version in dead set pleaz help me. |
Just flash latest version. If phone is dead : - Extra boot - Write all - Point to "Full_flash_v83_for _repair.bin" - Reconnect battery - Normal boot - Repair all CRC If not work: - Check battery voltage (must be 3.6V or more) - Must change Flash IC - Phone have HW problem |
Thanks a lot softmobile . c62 alive . THANKS |
c62 nothing happens hi all I have three working c62 but they can not be detected. ive tried extra boot, but still nothing seems to happen |
What cable you use? Does you use cable adapter to connect phone to box? |
SoftMobile I have tried both using the adaptor and without the adaptor. I am using c62 cable with an I Phone label on it. |
Connect cable to box direct without adapter Check cable Check pin 1 and pin 10 on box connector, it must be at same level as other pins. |
SoftMobile I will try tomorrow and post results |
SoftMobile cable is the same as the scheme. I have sonyericsson too cant be detected |
Are you check pin 1 and 10 ? |
SoftMobile pin 1 and 10 ok may be because i am using trial, but for c62 MTBOX: 00xxxxxxx - Nokia Flash/Repair v1.15 Box: CR V 1.001 256 Code: NK V 1.001 1034 SN: 00xxxxxxxx Nokia Unlimited: 63 times started SonyEricsson Trial: 0 left, each max 15min ------------------------------ Please do not post your box SN. |
Your tial is expired. also C62 inside use same trials. |
SoftMobile so what must i do to make it active.however i havent used any trial so far do i have to pay or must buy the one with the green logo. |
