Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > Griffin Products > MT-BOX
Old 02-06-2006, 16:20   #1 (permalink)
Member: 125366
Sonork: 100.1602649
How We Can Flash C62
Hwo we can flash c62 . and what is methord for searching software version
Old 02-06-2006, 16:24   #2 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
C62 Inside user manual
Siemens C62 language description
Old 02-06-2006, 17:36   #3 (permalink)
Member: 125366
Sonork: 100.1602649
But i flash defirent version . c62 untill dead , so how we can dedect software version in dead set pleaz help me.
Old 02-06-2006, 19:15   #4 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Just flash latest version.
If phone is dead :
- Extra boot
- Write all
- Point to "Full_flash_v83_for _repair.bin"
- Reconnect battery
- Normal boot
- Repair all CRC
If not work:
- Check battery voltage (must be 3.6V or more)
- Must change Flash IC
- Phone have HW problem
Old 02-07-2006, 09:54   #5 (permalink)
Member: 125366
Sonork: 100.1602649
Thanks a lot softmobile . c62 alive .
THANKS
Old 06-29-2006, 16:57   #6 (permalink)
calvinpower's Avatar
Member: 14229
c62 nothing happens
hi all I have three working c62 but they can not be detected. ive tried extra boot, but still nothing seems to happen
Old 06-29-2006, 22:29   #7 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
What cable you use?
Does you use cable adapter to connect phone to box?
Old 07-01-2006, 12:24   #8 (permalink)
Member: 14229
SoftMobile
I have tried both using the adaptor and without the adaptor. I am using c62 cable with an I Phone label on it.
Old 07-03-2006, 09:29   #9 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Connect cable to box direct without adapter
Check cable
Check pin 1 and pin 10 on box connector, it must be at same level as other pins.
Old 07-03-2006, 17:13   #10 (permalink)
Member: 14229
SoftMobile
I will try tomorrow and post results
Old 07-04-2006, 13:38   #11 (permalink)
Member: 14229
SoftMobile
cable is the same as the scheme. I have sonyericsson too cant be detected
Old 07-04-2006, 15:34   #12 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Are you check pin 1 and 10 ?
Old 07-04-2006, 18:11   #13 (permalink)
Member: 14229
SoftMobile
pin 1 and 10 ok
may be because i am using trial, but for c62
MTBOX: 00xxxxxxx - Nokia Flash/Repair v1.15
Box: CR V 1.001 256
Code: NK V 1.001 1034
SN: 00xxxxxxxx
Nokia Unlimited: 63 times started
SonyEricsson Trial: 0 left, each max 15min
Please do not post your box SN.
Old 07-05-2006, 08:48   #14 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Your tial is expired. also C62 inside use same trials.
Old 07-05-2006, 10:40   #15 (permalink)
Member: 14229
SoftMobile
so what must i do to make it active.however i havent used any trial so far
do i have to pay or must buy the one with the green logo.
how we can flash w550i by using universal box lolipolimobile Universalbox 2 10-20-2007 14:50
How we can flash 6600 DK2 mode aukonline MT-BOX 2 09-17-2006 20:25
S300 sendo How we can flash aukonline Multi-Box 9 05-22-2006 17:39
>>> How we can flash phone using ATRZ<<< farrukh mobiles Twisterflasher 0 03-12-2006 15:58
Page generated in 0.72288 seconds with 11 queries
