09-30-2007, 02:28 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Curacao ( the Caribbean )
Member: 200599 Status: Offline Thanks Meter: 0 | I won't to unlock N75 I have a N 75 that i need to unlock I check the pict how to set the test point CLK there no space for the needle so my question is if i use a tin wire to toch where supose to connect there is circul in front and grd is also very near if wile trying to connect this wire i toch one of this the phone can be damage why i ask because there is no space for error CLK pin i don't see it i think one toch if i'm lucky Please let me know if i cover it with tape to cover grd and the circul and try it or I'm open for suggestment:confused : |
10-01-2007, 17:28 | #5 (permalink) |
Member: 200599 Status: Offline Thanks Meter: 0 | Hi Thanx for your reply I upgrade this phone from 10.1.275 to 10.2.055 to unlock it with mt pro Phone is in: Local mode Model: RM-128 (CHX ) V 06wk15v37/08-03-07/RM-128 (c) Nokia. Production serial number YHA151638 Product code 0527376 Module code Basic production code 0527375 Flash code Order number Long production SN MCU SW V 06wk15v37/08-03-07/RM-128/(c) Nokia. HW 4200 PCI RFIC 17141714 DSP chx_06wk14v44 LCD 0 APE SW Core V 10.2.055/24-04-07/RM-128/(C)Nokia APE Variant V 10.2.055-02.03/26-04-07/RM-128/(C)Nokia Retu 15 Tahvo 21 APE HW 1 APE ADSP SW 256 Camera 1028 APE BT HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. Content Pack V 10.2.055/24-04-07/01/RM-128/ IMEI: 352288010046303 WARNING: VPP pin is not connected, disabling VPP. V 06wk15v37/08-03-07/RM-128 (c) Nokia. IMEI: 352288010046303 Operator: 0000000000000000 Profile bits: 3101700000000000 Closed on GID1: 310150 Closed on Mcc Mnc: 310150 Closed on GID1: 310170 Closed on Mcc Mnc: 310170 Closed on GID1: 310410 Closed on Mcc Mnc: 310410 Closed on GID1: 311180 Closed on Mcc Mnc: 311180 Counters 0/10, 3/3 Using Account: mtpro Connect... Resp: o/0110/hello there Login... OK, available count 3640/Added Panasonic X700 and VS3 and Alcatel E-xxx Download lates version from www.griffinteam.net / BB5_UNLC 40 NK_BB5_PM_AUTH 0 NK_BB5_PM_AUTH 0 NK_BB5_CERT_REST 40 --------------------- CREDIT COUNT: 3640; This what i get when pressing unlock itis not supported W 06wk15v37/08-03-07/RM-128/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\352288010046303.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 06wk15v37/08-03-07/RM-128 (c) Nokia. IMEI: 352288010046303 Operator: 0000000000000000 Profile bits: 3101700000000000 Closed on GID1: 310150 Closed on Mcc Mnc: 310150 Closed on GID1: 310170 Closed on Mcc Mnc: 310170 Closed on GID1: 310410 Closed on Mcc Mnc: 310410 Closed on GID1: 311180 Closed on Mcc Mnc: 311180 =================================== Using Account: mtpro100bb5c77 Connect... Resp: o/0110/hello there Login... OK, available count 3640; busy, waiting... e/401/command execution error; Server error What can i do now |
10-02-2007, 07:40 | #8 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | open griffin.ini with any editor like notepad. inside you will see: [interface_option] need under her to put revision=F and will be like this [interface_option] revision=F .... .... ... after that save file and unlock phone. at start of log need to have a F 06wk15v37/08-03-07/RM-128/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\352288010046303.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 06wk15v37/08-03-07/RM-128 (c) Nokia. |
10-05-2007, 18:55 | #9 (permalink) |
Member: 200599 Status: Offline Thanks Meter: 0 | Hi MT Team I won to let you know that i succesfully unlock the n75 Lots of work to connect the CLK but i make it The way to make the pin to connct to the pin is to use the pin of charger of samsung grin it to a thin flat kopper and soldeer it to the yellow connector but strong so when you push it in it wont bent This is my way to unlock it Hope it is helpfull That 911 GT for the revision=F Best regards |
please help me to unlock N97 [ANSWERED] | longgiang81 | Genie Universal | 2 | 03-30-2010 09:18 |
how to unlock n75 | tr3pplea | Nokia Base Band 5 ( BB-5 ) | 3 | 11-20-2009 13:02 |
how to unlock n75 nokia | sparshman | Universalbox | 6 | 05-22-2009 11:16 |
Easy To Unlock N75.thx 911gt,andro,to All | wiliam | MT-BOX | 2 | 01-04-2008 12:06 |
N75 Problem To Unlock May Be Nne Help | chiragp | BB5BOX | 3 | 10-30-2007 08:09 |
