04-16-2006, 08:11 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | J200,J210 Erase block problem 23. Detected phone:J200 Boot OK. Ready for commands. Writing: G:\MT-Box\SONY ERICSSON FLASHIS\ARM-INSIDE\J200i\DEF_125970_R2d.xarm ... Part 01 writing... Erase block problem 23. |
04-17-2006, 09:02 | #7 (permalink) |
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | Booting... Detected phone:J210 Boot OK. Ready for commands. Writing: C:\Program Files\MT-Box\ARM Inside\ARM inside repair files\j210-us1-ae-cf-xl-ae.xarmc ... Part 01 writing... Erase block problem 23. |
04-17-2006, 09:06 | #8 (permalink) |
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | when i use ARM 1.8 Booting... Detected phone:J210 Boot OK. Ready for commands. Writing: G:\MT-Box\SONY ERICSSON FLASHIS\ARM-INSIDE\J210\j210-europe3-fr-nl-en.xarmc Loader status problem. 0006 |
04-17-2006, 09:13 | #9 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Its cable problem 100%. There is a way to solve it: http://forum.gsmhosting.com/vbb/show...66&postcount=4 |
04-17-2006, 10:02 | #10 (permalink) |
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | But sir when i use without adapter . I able to flash phone . But sir when i purcheced Mt sony , that time i use ARM 1.6 and i flash many mobiles on this cable . How u can say cable is required modify ?????? Becouse still i using for flash K500 ............... |
04-17-2006, 14:38 | #11 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | There is some changes in software regarding flashing speed. There is a two options: 1. You can use ARM inside v1.6 and flash this phone for 10 minutes. 2. You can use ARM inside v1.7 or higher and flash this phone for 2:30 minutes (but you need to modify the cable). Your cable is not made by the schematics supplied by Griffin Team. Also with that cable without modification you cant flash P800, P900 and P910. |
04-17-2006, 16:46 | #12 (permalink) |
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | Ok sir now i faced knew problum i flash J210i with Arm 1.6 -1.7 flash .Flashing is 100% ok ,Unlocking 100% but set does not ON . |
04-18-2006, 01:31 | #15 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | The repair way is: - Download J210.repx file - Paste this file to software directory - Boot phone - Press Repair EE - Flash your phone with desired language pack |
solution for mic,spk,headphone symble problems J200,J210,j220,and other models | sree krishna | Sony Ericsson Hardware Repair | 86 | 05-07-2010 18:16 |
J200/j210 Mic/speaker Jumper Taken From Handfree Jack | HUM | Sony Ericsson Hardware Repair | 5 | 12-30-2008 09:52 |
J200-j210! | zeljko_c | NSPRO | 8 | 07-11-2008 00:31 |
How to Flash J200/J210 with Cruiser Tutorial | thoyyu | Cruiser Suite | 46 | 01-11-2008 09:37 |
==how to flash j200,j210 plz help== | rajabrotherscom | Cruiser Suite | 2 | 02-23-2006 13:02 |
