02-21-2006, 20:59 | #6 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | There is not help from any software. First you must "flash" your phone with hot air station and change resistor on TP1, because is broken. After solve resistor problem use TP v3 |
02-21-2006, 23:28 | #9 (permalink) | |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Quote:
The resistor signed like TP v1 is broken or is without contact with PCB. Try to desolder and solder it again (if is not too much glued) or just make one shortcut over this resistor. The resistor value is about 28 OHMS. | |
02-21-2006, 23:48 | #12 (permalink) |
No Life Poster Join Date: Apr 2002 Location: egypt Age: 54
Member: 11101 Status: Offline Sonork: 100.1641000 Thanks Meter: 1,783 | Starting the phone... PID:71 00 03 01 FF FF FF FF Sending Loader1... Loader1 sent. IMEI:35684100600746 CID (hex):0025 CID (dec):37 PAF:01 Mfrid0:20 Devid0:0C Sending prolog... Prolog sent. Sending loader... Loader OK. Init flash error:0001 and see that log when try make unlock |
02-21-2006, 23:49 | #13 (permalink) |
Member: 11101 Status: Offline Sonork: 100.1641000 Thanks Meter: 1,783 | Starting the phone... PID:71 00 03 01 FF FF FF FF Sending Loader1... Loader1 sent. Get OTP error:0001 and that log when try make repair |
02-22-2006, 00:41 | #14 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Desolder and solder that resistor on TP1 and you can see working phone. Now your phone can't power on right? Now you can't flash, unlock or repair it because is hardware problem. |
c975 dead when try to unlock | quickgsm | Motorola P2k | 2 | 10-30-2007 01:59 |
V975 dead when try to unlock in UL | celluniversal | Ultima Box Light | 9 | 07-02-2007 18:34 |
W810 dead when try to unlock | MoDeM | SonyEricsson (USB-Smart) | 4 | 06-10-2006 07:32 |
608i dead and that log file any hints for repair | fonec | Cruiser Suite | 3 | 02-22-2006 14:47 |
CX75 Dead when try to TP for UNLOCK ... | Aamir_Zia | S-Gold Based Phones | 2 | 11-30-2005 13:47 |
