11-01-2005, 19:02 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | MT-box ARM inside quick tutorial - Start ARM INSIDE v1.5 - Press BOOT butoon - Connect phone to cable - Press Read EE - Save *xarm file How to write eeprom - Start ARM INSIDE v1.5 - Press BOOT butoon - Connect phone to cable - Press Write flash button - Point to file How to repair eeprom - Download repair files from support area - Unpack files in same folder with ARM INSIDE v1.5 - DON'T CHANGE FILE NAMES - We recommend to backup eeprom before start to repair phone. - Start ARM INSIDE v1.5 - Press BOOT butoon - Connect phone to cable - Press Repair EE button - Wait to software finish, Time nedded for operation is from 10 seconds to 1 minute, depend from phone model - Diconnect phone and remove battery - Attach battery and try to power on the phone - If phone can't power on, then upgrade phone firmware to latest version - After firmware upgrade phone can't power on, then phone need hardware repair When you make EE repair got error "Open device problem" then Flash IC is damaged and need to replace it. New flash chip need to be programmed using Flash programmer (UP 48, Needhams EMP30 etc...).After this we recommend Repair EE. When you try to Repair EE and button is not accesible, then check does repair file exist in ARM INSIDE folder. When you want to flash J210 need to select file type - XARMC, if you select XARM file type then J210 files will be invisible. |
MT-box NEW ARM inside quick tutorial - How to unlock K608i CID 31 (CID 49) by TP | SoftMobile | MT-BOX | 4 | 11-25-2005 22:13 |
MT-box LG inside quick tutorial | SoftMobile | MT-BOX | 1 | 11-15-2005 21:14 |
MT-box Sharp 3G inside quick tutorial | SoftMobile | MT-BOX | 1 | 11-15-2005 21:11 |
MT-box AVR inside quick tutorial | SoftMobile | MT-BOX | 2 | 11-01-2005 18:58 |
