11-01-2005, 20:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | MT-box LG inside quick tutorial - Start LG 3G inside v1.3 - Connect phone to cable - Select phone model - Press "Selected phone info" button - Press "PATCH" button - Wait to software finish (less then 10 seconds) - Disconnect phone from cable - Insert Sim card - Power on the phone How to use Test point: - Start LG inside v1.3 - Select Test point - Make TP - Press Reset codes button - When software tell you please remove TP from GND - If phone is locked after this use PATCH button Test point pictures available in LG support section Do not try to unlock 8110, 8120,8130 and 8138 using PATCH button , for these phones use unlock methods from LG user manual. |
11-15-2005, 21:14 | #2 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | How to change IMEI on 8110, 8120, 8130, 8138 Download Plugin and unpack it to software directory Go to LG inside plugin folder Go to 8110 folder and rename "LG8110plugin.ssw" for example "12345678901234.ssw" (14 digits) Start LG inside v1.5 Select phone model 8110 Go to Read/Write tab Press Backup EE and save file Go to flash tab Click to Phone file ... and select "12345678901234.ssw" Click to flash Wait to software finish Disconnect phone Insert SIM card Power on the phone If phone is locked enter 2945#*88110# Network code is 00000000 Type *#06# to check it is all ok To restore original imei on 8110 just press Reset Code button To restore original imei on 8120, 8130 and 8138 just press Generate Codes button How to change IMEI on 8180, 8330, 8360, 8380 Download Plugin and unpack it to software directory Go to LG inside plugin folder Go to 8180 folder and rename "LGTESTPOINTplugin.ssw" for example "12345678901234.ssw" (14 digits) Start LG inside v1.5 Select phone model 8180 Go to Read/Write tab Press Backup EE and save file Select phone model TestPoint Go to flash tab Click to Phone file ... and select "12345678901234.ssw" Connect test point to GND Click to Flash button Remove Test Point from GND Click to YES Wait to software finish Disconnect phone Insert SIM card Power on the phone If phone is locked: Select phone model 8180 Go to Unlock tab Press Patch button Power on phone Type *#06# to check it is all ok How to restore original imei: Select phone model Test Point Connect test point to GND Click to Flash button Remove Test Point from GND Click to YES Wait to software finish Disconnect phone Power on phone Type *#06# to check it is all ok |
MT-box NEW ARM inside quick tutorial - How to unlock K608i CID 31 (CID 49) by TP | SoftMobile | MT-BOX | 4 | 11-25-2005 22:13 |
MT-box Sharp 3G inside quick tutorial | SoftMobile | MT-BOX | 1 | 11-15-2005 21:11 |
MT-box ARM inside quick tutorial | SoftMobile | MT-BOX | 0 | 11-01-2005 19:02 |
MT-box AVR inside quick tutorial | SoftMobile | MT-BOX | 2 | 11-01-2005 18:58 |
