12-01-2005, 02:51 | #16 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | In the New ARM inside documents you can find: k608i_TP_v1.jpg k608i_TP_v2.jpg K608i_TP_v3.jpg K60x_Test_Point_and_disassembling_manual_v2.pdf There is added Test Point v3 (new K608i hardware version) Use this Test Point when TP v1 give you error or work unstable, or in the case when TP resistor has too much glue over. Use New ARM inside v1.9 with selected K600 CID31 (CID49) |
12-16-2005, 21:28 | #17 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 16.12.2005 - NEW ARM inside v2.1 Whats new in NEW ARM inside v2.1: - Added full support for: W550 CID 31 by Test Point, V600 CID 31 by Test Point, Z520 CID 24 without Test Point - Added IMEI change plug ins for : W550 CID 31 by Test Point, V600 CID 31 by Test Point, Z520 CID 24 without Test Point If IMEI is patched (OTP IMEI <> *#06#) and you want to flash phone, first press unlock, then upgrade phone software. After phone upgrade you can patch IMEI again (using Plug in). - Added New option FS (File System) explorer Using FS explorer you can: - Read FS files - Write FS files - Create new folders in FS - Delete FS folders (bee careful) Similarly as Windows explorer Using FS explorer you can make full backup of FS, melody, pictures, video, wap settings, start-up screen, themes, games All allowed files can be changed, just setup your imagination) To use this option you DON'T need to install any phone drivers, no need to spend so much time. FS explorer manual: Connect phone, Press ??? button, Select phone model, Extra, Show Explorer, Connect Wait to phone be ready On the right explorer window you can see phone folders: - Tpa - ifs - system - smsdata - queue When you click on any folder, in left window you can see all files from selected folder (like in Windows) - Right mouse click to FOLDER and you will see available options: New - make New folder in selected folder Import - import files and folders from ZIP archive (use only ZIP files produced by New ARM inside) Export - selected folder, all files and sub-folders will be packed to an ZIP file (with path) Delete - erase selected folder (only if is empty) - To rename selected folder need to click and hold mouse over, write new name and press Enter - Right click to FILE and you will see available options: Load - file from HDD write to selected phone folder Save - save selected file to HDD Import - import file from previously saved ZIP archive (see export folder) Export - export selected file to an ZIP archive. If ZIP archive already exist you can add selected file to it, or delete old and make new ZIP with selected file on it. Delete - delete selected file To rename File use same method as for Folder rename FS contains audio, video and other multimedia files, phone settings files, LCD drivers, camera drivers, audio drivers, languages, sms and mms data, games, w@p data, T9 definitions and many other things. Just take some time to play with it and you will see what is this really)) Note: You can change XML files from phone (contains some interesting settings), but you can also harm your phone FS. Make FS backup before you start to play with it. Of course if you harm it , just import backup file and phone is functional again. If Mounting FS cant be done just make decustomisation (flash Tab). For example we explain how to backup sms data: - Select desired option and press RUN button Also you can solve many software problems without need to flash the phone. For example Z520 camera problem (if is not Hardware problem). If you have phone with configuration error or similar, this mean your phone folder /tpa/preset/custom is empty. If you have this folder backup from other phone, just import it to your and problem is solved. Same problem you can solve when select proper REP file using option Repair (Flash tab) If your phone show message "Configuration Error" write ConfigurationRepair.rep Please note: Using not proper REP file can make you troubles!! To access to other software TAB you need to Disconnect and Hide Explorer. After finish work with FS Explorer, need to click to Disconnect button and then disconnect phone from cable. Note: In some cases you can make sms data backup, write to other phone, but because some SE FS is not compatible your sms will be in some other folder. Same for other other things. Other news in New ARM inside: - Added new TP solution, connect Test Point when software tell you to, and Remove it also when software tell you. - New flash file concept called "ALL in ONE".What this mean? When you want to change language, repair phone or upgrade phone software need to download and use only one flash file. When you write this file, power on the phone and please wait to phone finish initialisation (Please wait message) After this all available languages for this phone will be displayed. If you don't want to have all this languages, use explorer to delete it (TPA/preset/system/languages/ After flashing process, please reconnect battery and then power on the phone! Because www.mt-box.org move to another faster server please download this update from here: New ARM inside v2.1 Have a nice day |
12-20-2005, 22:24 | #18 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 20.12.2005 - New flash files available on support Z520 CID 24 - R3C035 W800 CID 24 - R1NA005 K750 CID 24 - R1N035 W550 CID 31 - R4AB048 K608i CID 31 - R2J005 This is the new flashing concept files. Need to flash only one file for change languages, repair dead phone or upgrade software. When flashing CID 31 phones you need to use TP only one time (software will ask you to connect TP) Also available : ConfigurationRepair.rep Flash this file to phone with Configuration error message and that's all. Phone is alive and fully working. More All in one files under development. Best Regards GT Last edited by SoftMobile; 12-21-2005 at 10:54. |
01-21-2006, 01:14 | #21 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 20.01.2006 - New ARM inside v2.2 - Added support for CID 31 (CID49) without TP (for K60x some HW versions must use TP) - Added new NO TP flash files: k600_cid31_noTP_AllInOne.mcu w550_cid31_noTP_allInOne.mcu Note: Use these files only in the way you not use TP. Do not flash other files with selected no TP phone models!!! - Added new repair files: DB2000-CID31-RED.rep DB2010_CID31-RED.rep Last edited by SoftMobile; 01-22-2006 at 02:00. |
01-25-2006, 11:54 | #22 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 25.01.2006 - New ARM inside v2.3 - W900 full support added Added: - Full support for W900 by Test Point (unlock, flash, backup, restore, repair, change language) - Imei change plugin for W900 (to change imei without flashing the phone) - Test point 1,2,3 picture - Repair files for W900 - Conversion file from Brown to RED key - All in one flash file (w900AllInOne-r5ag001.mcu) - Using "All in one" files you can decustomize, upgrade, change language and repair your phone with just one flashing process How to unlock and flash W900 Press ??? button to see phone info (phone has RED key inside) Press selected phone info and connect TP when software ask you for it. Discconect when software tells you to. Now press again ??? button to see phone info (phone now has BROWN key inside) Now you can operate with your phone If you want after operation to convert BROWN to RED key just write "w900-cid 31-brown2red-erom.mcu" BR GT |
01-28-2006, 12:37 | #23 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 28.01.2006 - New files available on support area New ARM inside repair files k500-k300-formatFS.rar k600-formatFS.rar k700-formatFS.rar k750-formatFS.rar How to use it? Write "formatFS" file using option RESTORE, wait to software finish and then flash the phone with "all in one" or with MCU and DEC file. |
01-30-2006, 21:12 | #24 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 30.01.2006 - ARM inside v1.6 SonyEricsson Z300 fully supported: - READ CODES - Read eeprom/Write eeprom - Read flash/Write flash Read/Write speed (little ) increased (8MB under2 minutes!!!) for all ARM inside supported phones. MT box useres can download software from http://www.griffinteam.net |
04-14-2006, 08:18 | #25 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 14.04.2006 ARM inside v1.9 SonyEricsson J230i, J230a and J230c full support added Features: - Read unlock codes - 5 seconds - Read lock codes - Read user lock - 5 seconds - Full flash for only 150 seconds ! - Change language for only 150 seconds ! - Read/Write eeprom Flash files available: j230-apac1-in-en.xarmc j230-china.xarmc j230-emea1-et-lv-lt-pl-ru.xarmc j230-emea2-hr-cs-sr-en-sl-sk.xarmc j230-emea3-en-el-sq.xarmc j230-emea4-hu-en-ro-bg.xarmc j230-emea5-iw-en.xarmc j230-emea6-ar-fa-en-fr.xarmc j230-emea7-en-ru-tr.xarmc j230-europe1.xarmc j230-europe2-en-de-fr-st-zu-pt.xarmc j230-europe3-fr-nl-en.xarmc j230-europe4-fi-sv-no-is.xarmc j230-europe5-it-de-fr.xarmc j230-hongkong-zh-en.xarmc j230-india-en-hindi.xarmc j230-thai-th-en.xarmc NEW CABLE check box must be checked in ARM inside when you work on phones with NEW cable connector MT box users don't forgot to update your box using MT box update tool v3.4 If you see message "Box is updated!!" this mean your box has latest update. GTI users can download ARM inside v1.9 from support site also. Support for CID 49 phones without TP will be available ASAP Last edited by SoftMobile; 04-14-2006 at 11:11. |
04-22-2006, 16:18 | #26 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 22.04.2006 ARM inside v2.0 SonyEricsson J220i, J220a and J220c full support added Features: - Read unlock codes - 5 seconds - Read lock codes - Read user lock - 5 seconds - Full flash for only 150 seconds ! - Change language for only 150 seconds ! - Read/Write eeprom - Added WARNING message for non updated MT boxes - If you see WARNING message this mean you need to update your box using MT box update tool v3.4 - If you see message "Box is updated!!" this mean your box has latest update. Flash files available: j220-apac1-in-en.xarmc j220-china.xarmc j220-emea1-et-lv-lt-pl-ru.xarmc j220-emea2-hr-cs-sr-en-sl-sk.xarmc j220-emea3-en-el-sq.xarmc j220-emea4-hu-en-ro-bg.xarmc j220-emea5-iw-en.xarmc j220-emea6-ar-fa-en-fr.xarmc j220-emea7-en-ru-tr.xarmc j220-europe1.xarmc j220-europe2-en-de-fr-st-zu-pt.xarmc j220-europe3-fr-nl-en.xarmc j220-europe4-fi-sv-no-is.xarmc j220-europe5-it-de-fr.xarmc j220-hongkong-zh-en.xarmc j220-india-en-hindi.xarmc j220-latin_america1.xarmc j220-taiwan-zt.xarmc j220-thai-th-en.xarmc NEW CABLE check box must be checked in ARM inside when you work on phones with NEW cable connector |
05-10-2006, 18:36 | #28 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 10.05.2006 - New ARM inside v2.5 available What’s new? - Added full support without test point for K600, K608, V600 CID 31 hex (CID 49) - Added full support without test point for W550 CID 31 hex (CID 49) - Added full support without test point for W900 CID 31 hex (CID 49) - Added full support without test point for K750 CID 31 hex (CID 49) - Inreased FS Explorer speed - Restore - "FLR" files for phones flashed with "AllInOne" available in FLR folder - New option added to Extra tab "Make Restore File" - New flash files "NOtp2" available on support - New user manual for "NOtp2" phones - Unlock time if you have proper FLR file its 15 seconds per phone Flash files available: k608AllInOne - NOtp2 - R2J005 w550AllInOne - NOtp2 - R4AB048 w900AllInOne - NOtp2 - R5AG001 For k750 you can use all available "AllInOne" flash files Last edited by SoftMobile; 05-10-2006 at 20:10. |
05-18-2006, 01:58 | #29 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 18.05.2006 - New ARM inside v2.6 What’s new? - Added support without test point for W810 CID 31 hex (CID 49) - Added support without test point for Z530 CID 31 hex (CID 49) - Restore - "FLR" files for phones flashed with "AllInOne" available in FLR folder - New flash files "All in One" available on support - New user manual for "NOtp2" phones - Unlock time if you have proper FLR file its 15 seconds per phone Be sure you have updated box to latest version using MT Box update tool v3.4 Flash files available: w810-r4ck003-AllInOne.rar z530-r6ac001-AllIneOne.rar FLR files available: z530 z530-r6ac001-eu.flr z530-r6ac001-china.flr w810 w810-r4ck003-taiwan.flr w810-r4ck003-hongkong.flr w810-r4ck003-eu.flr w810-r4ck003-china.flr w810-r4ce012-generic.flr w810-r4ce012-hongkong.flr w900 w900-r5bc004-taiwan.flr w900-r5bc004-eu1.flr w900-r5bc004-china.flr w900AllInOne-r5ag001.flr w550 w550-r4cb020-taiwan.flr w550-r4cb020-eu1.flr w550-r4cb020-china.flr w550-AllInOne-r4cb020.flr w550-r4cb020-hongkong.flr w550AllInOne-r4ab048.flr w600 w600-r7b039-nam1.flr w600-r7b039-eu.flr w600-r7ca017-nam1.flr w600-r7ba011-generic.flr w600-r7b049-cmcc.flr w800 w800-r1bc002-hongkong.flr w800-r1bc002-eu1.flr w800-r1na005-eu1.flr w800-r1na005-taiwan.flr w800-r1na005-china.flr w800-r1aa008-AllInOne.flr w800-r1ba013-AllInOne.flr k750 k750-r1bc002-AllInOne.flr k750-r1bc002-china-thai.flr k750-r1bc002-hongkong.flr k750-r1bc002-eu1.flr k750-r1aa008-hongkong.flr k750-r1n035-eu1.flr k750-r1n035-taiwan.flr k750-r1n035-china.flr k750-AllInOne-r1aa008.flr k750-r1ba013-AllInOne.flr k600 k600-r2t002-china.flr k600-r2t002-hongkong.flr k600-r2t002-eu1.flr k600-r2t002-taiwan.flr k600allInOne-r2j005.flr |
06-21-2006, 20:04 | #30 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | 21.06.2006 - New ARM inside v2.7 - Added support without test point for W700 CID 31 hex (CID 49) - Added support without test point for K510 CID 31 hex (CID 49) - Added support without test point for W300 CID 31 hex (CID 49) - Added support without test point for W600 CID 31 hex (CID 49) - Restore "FLR" files for phones flashed with "AllInOne" available in FLR folder – Updated - “All in one” for W700 available, for the rest new added phones MCU and PPM support - Configuration repair files added for some phone models - Unlock time if you have proper FLR file its 15 seconds per phone - User manual for New ARM inside v2.7 available - Full backups for all added phones available - EEPROM backups for all added phones available Be sure you have updated box to latest version using MT Box update tool v3.5 |
**MT-box SE updates** 04.06.2008 - DB2020 inside v4.8 - JAVA UNLOCK ADDED | irfanamin2 | MT-BOX | 6 | 07-19-2008 13:23 |
**MT-box SE updates** 05.07.2008 - DB2020 inside v4.9a | babbu | Service Products News & Updates | 0 | 07-05-2008 08:46 |
**MT-box SE updates** 04.06.2008 - DB2020 inside v4.8 - JAVA UNLOCK ADDED | irfanamin2 | Service Products News & Updates | 0 | 06-04-2008 07:40 |
**MT-box SE updates** 30.05.2008 - DB2020 inside v4.7a - JAVA UNLOCK ADDED | irfanamin2 | MT-BOX | 0 | 05-30-2008 17:36 |
**MT-box SE updates** 30.05.2008 - DB2020 inside v4.7a - JAVA UNLOCK ADDED | irfanamin2 | Service Products News & Updates | 0 | 05-30-2008 17:32 |
